Hub bearing assembly loose
joeyporter
I was had my 04 in the shop today replacing the front struts and the mechanic said that "RH front hub bearing assembly slightly loose" and quoted my 470 to fix. Has this happened to any of you? should i take care of it? any advise?
Thanks
Just take off your wheels and brake caliper then rotor and tighten the 4 Hub bolts with a wrench. But before doing so look behind the rotors. You should be able to see the hub bolts on the corners, but sadly nothing can reach them without disassembling above. Save your money. Paying 470 to tighten nuts is such a waste
Just replaced both of my fronts. you have to press the new bearing in one you take it off the truck. Very easy and not very time consuming. My left front was lose and the right was making a noise so i did them both with napa lifetime bearings.
