115 V AC power in console not working
Manderson80
Hi everyone, I've got a 2004 SR5 and the AC power outlet in the center console doesn't work even when I press the AC power button to the left of the steering wheel. Should the button light up? Fuse blown possibly? Any ideas? Thanks all!
It should have a self resetting fuse, however I suppose those can go bad as well. The switch is supposed to be illuminated when the dash lights are turned on. also when turned on it should have an LED light indicator on the button lit up indicating it's in the on position. Start by checking the fuse's. If it's not a fuse check all the wiring and make sure it's all proper.
