Old 09-21-2015, 12:13 PM #16
Asmara Asmara is offline
Asmara is on a distinguished road
Originally Posted by RUN-4-LIFE View Post
How did you do the wires I'm lost. You spliced or tapped into the fuse box?
You cut it from behind the junction box (basically where I have it circled in the photo). There is no connector in the side of the harness that you can see so this is the end of the line for that wire.
For those who wanted a picture, this thread has a photo. The only difference in mine is that I moved the DAC switch to the center so that each seat heater switch is near the seat it controls.
2004 4Runner SR5 SR5 - V6, 4X4, Moonroof , JBL, Leather, Stratosphere Mica
Installed Mods: Spoiler, HIR bulbs, Kenwood DNX6960 Nav, Back Window Up with Remote Mod, Rear Camera, LED Tails, Key Reminder Disable, OEM Automatic Headlights, Rear USB Ports, Seat Heaters, Aftermarket Third Row, Heated Side View Mirror
Locations: VA
Asmara is offline   Reply With QuoteReply With Quote
Old 11-27-2015, 07:07 PM #17
TheTurboMRT TheTurboMRT is offline
TheTurboMRT is on a distinguished road
I just wanted to say thank you for these instructions! Switched the relay over, ordered a 2nd relay because I do tow with the 4runner, and cut/soldered the green wire to main power. Works great! Thanks!
TheTurboMRT is offline   Reply With QuoteReply With Quote
Old 11-27-2015, 07:34 PM #18
Glad to hear it. Always nicer when things are kept as stock as possible for these types of things. Enjoy the heated seats. I use them all the time in the winter.
Locations: VA
Old 12-31-2015, 11:21 AM #19
hendy.27 hendy.27 is offline
hendy.27 is on a distinguished road
Originally Posted by Asmara View Post
I just put in aftermarket seat heater in my '04 4Runner (tip make sure you have hog rings and hog ring pliers - makes the job easier).
I wanted to use the factory fuse to wire the heaters. The fuse is in the engine compartment fuse box. It was in place so I figured the wiring may be too. To shorten the story a bit; There is a wire that goes from the factory fuse to position A6 of IC4 which is located behind the drivers side kick panel. Unfortunantly, it dies there. The other side of IC4 is blank. I decided to run my wiring to there and tap into the harness anyway so I could use the factory fuse. I soon learned there was no power there. I checked the fuse. It was fine. I looked at the schematics again and realized that power to this fuse is controlled by the IG relay in the fuse box. That location was empty. I pulled the relay from the 'towing tail relay' since I don't tow and put it in the IG Relay slot. Now I had power going through the fuse and to the wire in IC4.
I figured I put the info here in case anybody else is doing something similar.
Probably going to install my heaters this weekend. Have many other people done it this way? Any ill effects from moving the relay? Do you lose power to other essential places?
hendy.27 is offline   Reply With QuoteReply With Quote
Old 12-31-2015, 01:09 PM #20
luke87gt's Avatar
luke87gt luke87gt is offline
luke87gt is on a distinguished road
luke87gt's Avatar
what seat heater are you guys using?
I'd like to learn more about this for my 2006 4Runner
thanks
2006 4-Runner XSP V6
SCS Ray10 17x8.5 (Matte Black)
Falken ATW3 Wildpeak 265/70/17
Daystar 2.5/1.5
luke87gt is offline   Reply With QuoteReply With Quote
Old 12-31-2015, 02:03 PM #21
thanks
I bought these ones. With very minimal modification, they fit into the factory blanks on the center console.
Car Seat Heater 2 Seats Heated Seat Rectangle Rocker Switch Fit All 12V Cars | eBay
Old 01-02-2016, 10:36 AM #22
Anyone? Bueller?
Old 01-02-2016, 11:35 AM #23
Anyone? Bueller?
I've done it. No loss of functionality to other areas of the car, becauseI bought a new relay that was the same part # as the tow relay, so I maintained my tow lights as well.
Old 01-03-2016, 11:07 AM #24
No negative effects. I purchased a used relay off of ebay and put it in the slot, just because.
Locations: VA
Old 01-04-2016, 01:40 PM #25
luke87gt's Avatar
luke87gt's Avatar
Thank you for the link, I will have to give those a shot.
You just place those heating pads under the seat cover? Or under the seat foam? Or?
Thanks.
Daystar 2.5/1.5
Old 01-04-2016, 01:43 PM #26
Thanks.
On top of the foam, below the seat cover. Good luck!
Old 01-04-2016, 06:31 PM #27
luke87gt's Avatar
luke87gt's Avatar
Asmara, thank you again for the input. It sounds like your China made seat heaters are working well. No issues with the switches themselves?
Given that there are two seat heaters, two switches, a fuse box, a fuse, a relay, and the green kick panel power wire, I think it would be very helpful if you could draw up a simple circuit diagram that shows how everything is wired so it's totally clear.
Any chance you would be able to do that for us all? I'm sure this will be invaluable to me and many other members that will be doing this job in the future.
Thanks much!
Daystar 2.5/1.5
Old 01-07-2016, 08:19 PM #28
Blowing fuses..
So I did the install over the weekend. My driver side works great, but my passenger side wasn't working. And after scratching my head, thinking that I didn't splice the power wire on well, I realized that the inline fuse for the passenger side blew. I thought maybe I got shipped a dud, so I replaced it, and turned it on and it blew the fuse.. I'm pretty novice when it comes to electrical circuits, so if anyone can give me any ideas of what is going on that would be great.
Old 01-08-2016, 10:31 AM #29
Although it helped you in this case as far as troubleshooting, I would have pulled out the inline fuses when you did the install. It's not normally good to have multiple fuses on one circuit. Especially ones that will be hidden.
You might have a problem with a heating elements having a direct short. Quickest way to check would be to swap the plugs from the drivers seat and passenger seat. If you swap the wiring, replace the fuse, and turn on the driver's seat heater using the passenger switch, does the fuse blow?
If you have a multi-meter put the meter on ohms and check the resistance of the drivers seat heating element and compare to the passenger seat. If you get zero ohms you have dead short and the element will need to be replaced.
Try these things and report back.
Locations: VA
Old 01-10-2016, 01:38 AM #30
Did as you recommended and swapped the switches. So then I knew there was something going on with the heating element. Sure enough there was a short on the element. I had cut a hole in it in two spots to allow me to attach the seat cover back to the foam, but I forgot to cover the exposed heating element where I cut and that was contacting the metal that you zip tie the seat covers to. I covered up that exposed edge with some duct tape, put in a new fuse and it worked perfectly. Thanks for your help!
Seat Heater Install Mijfwb23 5th gen T4Rs 218 07-24-2023 04:43 PM
Electric seat Fuse question. KingMedicine 3rd gen T4Rs 4 04-08-2011 06:08 PM
I want the rear seat heater! gapboi210 3rd gen T4Rs 2 09-18-2006 01:56 PM
2006 Seat Heater SPRUNNER 4th Gen T4Rs 14 02-03-2006 03:18 PM
Seat Heater Install ZeroC00l 3rd gen T4Rs 5 12-22-2005 09:45 AM
