Old 01-05-2013, 03:43 AM #1
Black4thgen05's Avatar
Black4thgen05 Black4thgen05 is offline
Black4thgen05 is on a distinguished road
Known issues...
Okay, so I have had my 05 sport edition 4x4 V8 for a few months now.
Some of the issues I have are the dash cracking, a weird transmission clunk thing, an alignment issue, and some of the interior lights on the clock/mpg display are out. Also I need a new amp and sub because the sub is blown.
I see the sticky about the dash and what I can do to fix it are.
I need help with this clunk thing. When I'm at a stop and I let off the brake it clunks really bad and then starts moving. I think I have read that its common in the full time 4x4 t4r's...any truth to this?
Does anyone know where to buy a new stock JBL sub? I know its all connected to the amp in a big enclosure...I had to cut the wires on the actual sub just so I could listen to the radio.
I saw a thread with the replacement and how to, to change out the interior ights.
The alignment...I tried to have one done but they said the camber? bolts were seized and they could not do the full alignment.
Also I now have this weird popping noise. I am going to try and locate it and start by greasing all the zerks. It has 112,xxx miles so I think it might be the ball joints or the cv axles. I will keep this thread up to date as I find more isurs and solutions.
I LOVE the t4r...I'm just trying to play catch up on all the maintenance that has not been done on the truck for quite some time. The previous owner did not exactly care about it. I did pick it up for a decent price. I already changed the oil, air filter, cabin filter, and spark plugs. Definitely the EASIEST plug change I have ever done!
Sorry for the long read and thanks for all the help and such a great forum for t4r's!!!
2005 Toyota 4Runner, Sport Edition, 4x4, 4.7 V8...the wifey's ride.
After my upcoming 10 month deployment...Race Red SVT Raptor Supercrew with all the goodies!
Black4thgen05 is offline   Reply With QuoteReply With Quote
Old 01-05-2013, 08:41 AM #2
ChaosStarter ChaosStarter is offline
ChaosStarter is on a distinguished road
Common on a lot of vehicles:
-Exhaust manifolds
-Front calipers
-Front wheel bearings
-Sometimes low gear actuator if it was used infrequently
-The air pump/secondary air injection system is getting more common
That's off the top of my head at 744am with 3 hours sleep.
2005 4R V8 4x4 Limited - LEDs, FX-Rs, Gibson exhaust, TRD Red Front/Rear shocks, OME front springs, Toyotec rear springs, BF Goodrich 275/70/17 K02s, 1.25" Spidertrax. Front/Rear Polyurethane sway bar bushings, Total Chaos lower control arm alignment tabs. 150k miles and counting
2005 Prius - DD/Grocery getter. 250k miles and counting.
ChaosStarter is offline   Reply With QuoteReply With Quote
Old 01-05-2013, 09:50 AM #3
OzarkRunner's Avatar
OzarkRunner OzarkRunner is offline
OzarkRunner is on a distinguished road
Yes, the clunk is very common, but it's also very easy to take care of. Check out the link below for info.
http://www.toyota-4runner.org/mainte...ting-pics.html
2008 Sport / V8 / Bright Silver FN FX Pro / 255/75 Duractracs / Fox 2.5" Factory Front Coilovers / JBA / Superpro / Fox 2.0" Rear / Wheeler's T12 / Limited Grill / Rigid Duallys / Flowmaster 70 Series / ScanGaugeII on Blendmount / 5k LEDs / Homelink Upgrade
OzarkRunner is offline   Reply With QuoteReply With Quote
Old 01-05-2013, 12:10 PM #4
Thanks for all the info!
Old 01-05-2013, 01:33 PM #5
NJshadow93's Avatar
NJshadow93 NJshadow93 is offline
NJshadow93 is on a distinguished road
NJshadow93's Avatar
You may want to have the timing belt and water pump done too. If it was not done yet, it is overdue. It is recommended at 90,000 miles.
2006 Toyota 4Runner SR5 V8 4x4-Nautical Blue Metallic
1986 Toyota MR2 AW11 NA 5 Speed
NJshadow93's 2006 SR5 Build
NJshadow93 is offline   Reply With QuoteReply With Quote
Old 01-05-2013, 05:07 PM #6
Rattlecanpaint Rattlecanpaint is offline
Rattlecanpaint is on a distinguished road
The lights in the clock/A/C panel are very easy to do also. There are 3 bulbs in the back. Cost about $6-8 here in the states. Open the door under the clock panel and remove the 10mm screw and the piece pops off. Get a small flat head screw driver and turn your bulbs 1/4 turn to remove. X2 on the timing belt. I've got all that and the plugs still to do on mine.
Rattlecanpaint is offline   Reply With QuoteReply With Quote
Old 01-05-2013, 06:05 PM #7
Bob J Bob J is offline
Bob J is on a distinguished road
Awesome! Thanks for this note..... Mine has been out for a while on the clock side.... Do you (by any chance) know the part number of the bulb?
2003 V8 Limited
aFe filter, V-Led interior lights, RCI skid plates, Brembo rotors, NAPA lifetime reman calipers, Stoptech brake lines, WMW "fedrlbiker" roof rack
Bob J is offline   Reply With QuoteReply With Quote
Old 01-05-2013, 07:22 PM #8
I know the timing belt was done...there is a sticker that says it was replaced. IIRC it was done at 82,000. I can only hope the water pump was done at the same time.
Thanks for the heads up about the lights. Is there a thread with any part numbers around? Tried searching and didn't find any results.
Also who do you guys use for the HID retrofits around here? I also want to switch out to LED tail lights. Look way better IMO.
I plan on installing a basic CAI, cat back exhaust, and is there a tuner company you guys like for the v8? I'd prefer custom tunes but, if there isn't any available canned tunes will work foe me. Just wanting a little extra power and everyone's opinion about the subject of tuners.
Thanks again! You guys have been a great help!
Old 01-05-2013, 08:58 PM #9
NJshadow93's Avatar
NJshadow93's Avatar
Cold air intakes in these trucks are a waste. The stock intake is already a true cold air intake. Just remove the Hydrocarbon Filter, drop in a high flow filter, and you're set.
Old 01-05-2013, 09:24 PM #10
Awesome! Thanks for the tip! I just removed the carbon filter and will be looking for a aftermarket dry element filter. Saves me about 300 bucks.
Old 01-05-2013, 10:16 PM #11
Don't know the part number on the light bulbs but I just went to the dealer and told them I wanted all 3 bulbs for the A/C and outdoor temp display. One is green and 2 are clear. The green one does the reset/mode button. Not sure why green because it doesn't show up green.
Old 01-05-2013, 11:33 PM #12
NJshadow93's Avatar
NJshadow93's Avatar
That's what I'm going to do. I will probably get the AFE Pro Dry filter. I had a K&N but once it got dirty I took it out. I don't want to risk over oiling it and fouling my MAF sensor.
Old 01-06-2013, 03:38 AM #13
etom's Avatar
etom etom is offline
etom is an unknown quantity at this point
etom's Avatar
You can find the part #'s here:
Hey guys how do you change the light on the Drivers Info
2005 Limited Titanium w/Stone V8 4WD NAV
TRD dual cat-back exhaust, TRD Pro Wheels (Matte Gray), K&N intake (63-9029) w/amsoil dry filter, Amsoil fluids, 265/70/17 Toyo Open Country AT III, Bilstein 5100 @ .85", Sprint Booster V3
etom is offline   Reply With QuoteReply With Quote
Old 01-06-2013, 11:03 AM #14
Awesome! Thanks! Will put the bulbs on order......
2003 V8 Limited
rear driveshaft issues.....Big issues CRIVRUNNER Classic T4Rs 9 01-10-2011 02:04 AM
HELP PLEASE 4WD Issues giovannyc 3rd gen T4Rs 1 03-30-2010 11:56 PM
A/C issues bgthngs Classic T4Rs 1 04-30-2009 12:22 AM
95 3.0 issues Runslikecrap Classic T4Rs 3 01-15-2008 09:43 PM
Odd issues GarageAlchemist Classic T4Rs 1 10-17-2007 03:10 PM
