Old 05-17-2020, 07:13 AM #421
PolkaSaucy PolkaSaucy is offline
PolkaSaucy is on a distinguished road
Hey guys,
New on the forum so, apologies in advance if I'm making any rookie mistakes.
Have a 2005 Sr5 4x4
Recently did a taco swap up front from a 19 TRD off road set up. Got the whole kit under 2k miles for $140. It lifted the front up way more than I thought it would, to the point where I had some serious negative rake. Couldn't source any fj coils, but I did find a set of 14 4runner coils, paired with 1.5" Daystar spacers for $80, so I went that route instead. The coils were actually a little shorter than mine, but thicker and stiffer, so it all worked out and she sits pretty level now, gotta say I'm really happy with this set up, no more mushy suspension. Have no idea how much lift I got, as I didn't really take any measurements, just kinda winged it while we were rebuilding the front CV axles.
I have yet to put in the TRD off road billsteins in the back, but have a quick question about the bushings before I swap em in. I'm looking between the 9.8108G and the 9.8140R, but I can't seem to find the rest of the hardware to go with it (metal sleeves, washers, ect).
Are you guys just swapping the sleeves out of the old bushings into the new bushings? Or do they come with and just aren't shown? Sorry if this was already covered in the thread, I read through as much as I could. Thanks in advance!
Tacoma Suspension Swap-20200517_020201-jpg  Tacoma Suspension Swap-20200517_015841-jpg
PolkaSaucy is offline   Reply With QuoteReply With Quote
Old 05-17-2020, 09:24 AM #422
Jpilot Jpilot is offline
Real Name: Joe
Jpilot will become famous soon enough Jpilot will become famous soon enough
Real Name: Joe
Originally Posted by PolkaSaucy View Post
Hey guys,
Have a 2005 Sr5 4x4
Go with the 9.8108G and there is no need for the sleeve, fits right onto the shock mount.
Jpilot is offline   Reply With QuoteReply With Quote
Old 05-23-2020, 07:44 AM #423
Thanks for the info. Idk about fitting right onto the shock mount, was quite the tight squeeze that took some muscling, but eventually it went on lol. I'm assuming it's because it's a poly fitting rather than metal to metal like the stock bushings? That or it's cause I mistakenly bought the red bushings and not the black hourglass, but I was under the impression that they both worked the same. Either way, they're on now, and she rides nice. Thanks again!
Old 12-03-2020, 10:58 PM #424
Mmarzilli Mmarzilli is offline
Mmarzilli is on a distinguished road
Hi,
This was a great thread, thanks for all the info. I have a 2007 4Runner V8 2wd with Xreas. I just removed it all today and have a set of blisteins from a 2019 Tacoma. The rears are 48530-04110 and I replaced the lower bushing with the one suggested and that fits great. My issue it with the upper bushings on the stem. The have a 5/8 lip and the hole in the frame that it sits in is 3/4. There is some play in the fit. Did all of you have that same issue or did you replace the stem bushings as well with ones that fit better? Any help would be greatly appreciated.
Mmarzilli is offline   Reply With QuoteReply With Quote
Old 12-17-2020, 04:00 PM #425
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
I've been a proponent of the Tacoma swap since I installed the gear off a 2015 Tacoma TRD OR on my 2007 Sport Edition 2 years and nearly 50K miles ago, and still am based on my experience with the ride on and off the pavement. In fact, I recently picked up another OR Tacoma set taken off a 2020 at 3,700 miles. But...read on.
The fronts are a no-brainer b/c the two vehicles are essentially the same up there, and I never bought into the argument that the Tacoma rears are too soft b/c that wasn't my experience. But I did wonder whether it matters that the Tacoma has leaf springs. I decided to watch for a Black Friday deal on the Bilstein 24-186049, the 4600 made for the 4th Gen 4Runner. I found a new pair for $140 shipped at AJUsa (great service btw) so I bought them and that's when it got interesting. I was pretty surprised at the difference between the Tacoma rear shocks (L) and the one made for 4th Gens (R), which is noticeably larger:
(Note: the Tacoma shock has the straight 9.8140G replacement bushing installed and I painted the mounting ring with black rust preventative paint.)
I haven't installed the new ones yet so I can't comment on any ride differences, and this isn't to knock the Tacoma swap or dissuade anyone from doing it. Just wanted to share this so people considering this move can make a more informed decision.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 12-22-2020, 11:58 AM #426
Bluesky 07's Avatar
Bluesky 07's Avatar
On Sunday I installed new 4Runner-specific rear 4600s on my '07 Sport. As noted above, I've had 2015 Tacoma OR 4600s front and rear for about 2 years and 50K miles. While I still feel the Tacoma swap is a solid choice, especially given the cost relative to a whole new setup, some owners may definitely prefer to use the 4R version of the 4600 for the rear. So far I have a couple of hundred miles on the new rear shocks; I like the ride a lot and the 4R version of the shock is noticeably beefier, something that surprised me when the shipment arrived a few days ago. Here's a side-by-side:
I still have a front set of 4600s, coils, & UCAs from a 2020 Tacoma OR I plan to install up front. Those aren't a concern b/c the vehicles are nearly identical up there whereas the Tacoma has leaf springs vs. coils on the rear.
Old 02-12-2021, 04:45 PM #427
PNWLivin PNWLivin is offline
PNWLivin is on a distinguished road
Do you have pics with the new rear shocks?
PNWLivin is offline   Reply With QuoteReply With Quote
Old 02-14-2021, 02:23 PM #428
Bluesky 07's Avatar
Bluesky 07's Avatar
@PNWLivin , haven’t had a chance to get decent pics between work & lousy weather but here’s a garage shot FWIW. Really happy with the look of my most recent suspension install. (For those not familiar, the front has coilovers from a 2020 Tacoma TRD Offroad [which have Bilstein 4600 shocks] while the rear is on FJ springs & the 4600 model made for 4th Gens, which is their p/n 24-186049.)
Old 03-08-2021, 11:29 PM #429
Roody Roody is offline
Real Name: Ross
Roody is on a distinguished road
Real Name: Ross
So just to clarify, the rear suspension will just mount directly to the new Energy bushings? No metal on metal anymore? Just want to be 100% certain of this before I tackle the swap later this week. Have the suspension, have the bushings, will press the OEM bushings out and the new ones in... and that's it? No need to swap over the metal sleeve and it's all good with metal on the Energy bushing as-is?
Current: 2018 GX460
Past: 2005 V6 4Runner, 2005 V8 4Runner, 2018 TRDORP
Love off-roading? Enjoy listening to podcasts? Consider yourself a four-wheeling enthusiast? So do we! Join in on the fun, and listen here:
The Off The Road Again Podcast
Roody is offline   Reply With QuoteReply With Quote
Old 03-09-2021, 12:36 PM #430
Real Name: Joe
Real Name: Joe
That is correct. If you read the star ratings on the Amazon page for this item, there are multiple people who commented on the 4Runner/Tacoma swap.
2015 T4R Trail Red, 3” lift, 285s, Niserack, HF rock sliders, BA bumper
2006 4runner sport, v6, Tacoma TRD springs front, airbags And 2” spacers in rear. 440k and still chuggin along.
1977 FJ40, V8, lifted, Warn 8274 winch etc.
2006 GX470, 285s, 2” lift, C4lo sliders
Old 03-18-2021, 05:49 PM #431
Bluesky 07's Avatar
Bluesky 07's Avatar
Selling surplus front & rear suspension parts from my two Tacoma swaps here if anyone is interested. Edit: SOLD.
Will TRD Tacoma suspension fit 05 4runner? Trob20 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 02-04-2013 01:22 AM
3rd Gen. 4Runner/'01-04' Tacoma Gauge Cluster Swap 2000SR5 3rd gen T4Rs 5 11-03-2010 06:14 PM
tacoma/4runner front end swap petty964 3rd gen T4Rs 2 09-25-2010 05:30 PM
axle swap with tacoma JGstarted22 3rd gen T4Rs 11 02-28-2009 07:26 PM
tacoma 4 cyl swap into 87 4-runner Kidznplay Classic T4Rs 1 07-15-2008 10:22 PM
