Old 06-30-2013, 07:19 PM #1
04rnr's Avatar
04rnr 04rnr is offline
04rnr is a jewel in the rough 04rnr is a jewel in the rough 04rnr is a jewel in the rough
04rnr's Avatar
Oil Catch Can
Has anyone done this on the 4th gen ?
Oil Catch Can Install Guide - Tacoma World Forums
2007 Sport.
"Colorado is FULL, try N.M."
"Everyone is an expert"
04rnr is offline   Reply With QuoteReply With Quote
Old 06-30-2013, 07:37 PM #2
BlackWorksInc's Avatar
BlackWorksInc BlackWorksInc is offline
BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold BlackWorksInc is a splendid one to behold
I'm honestly on the fence about this... I thought about installing one; but most are for boosted applications where there is more pressure in the system. But as the thread shows there is an amount of oil going back into the intake... but its no where near as bad as some of the European vehicles I have seen.
I'd be curious to see how this thread goes.
BlackWorksInc is offline   Reply With QuoteReply With Quote
Old 06-30-2013, 08:43 PM #3
MICA4R's Avatar
MICA4R MICA4R is offline
MICA4R is on a distinguished road
MICA4R's Avatar
Well we haven't heard of "gunked" intakes on these rigs. The V6's seem to be filling the cans... If anything maybe this would be good on the V8's 25% more places to mist out oil?
2008 SE 4.0 4WD 5100's
MICA4R is offline   Reply With QuoteReply With Quote
Old 06-30-2013, 09:53 PM #4
97hb's Avatar
97hb 97hb is offline
97hb is on a distinguished road
97hb's Avatar
Did the home depot husky catch can for $12 about 40k ago. It definitely catches oil and stops it from entering the manifold.
2017 Ram 3500 4X4 - The hauler.
2003 SR5 4X4 4Runner - 412K+ Off-road Toy.
1997 Civic SFWD 674hp 530tq - Because racecar.
97hb is offline   Reply With QuoteReply With Quote
Old 06-30-2013, 10:37 PM #5
04rnr's Avatar
04rnr's Avatar
Me too, Ive seen these years ago, and I remember I guy I use to wheel with (very honest/good guy) had one on his rig, and worked well for him, yet you all know how the forums are, they bashed him, called him a liar etc, he finally got sick of it lol.
Do you have a write up???? you got a V6 or V8?
2007 Sport.
Old 06-30-2013, 11:23 PM #6
97hb's Avatar
97hb's Avatar
Sorry no write up. You just need a husky air compressor filter in the tool section of home depot. 2 1/4ntp to 3/8 fittings from plumbing section home depot. 4 ft of 3/8 hose auto zone. If you let it fill all the way, the ventilation pipe on the intake side (passenger side valve cover) will suck in lots of oil and will have blue smoke show under load.
Old 07-01-2013, 02:37 AM #7
I can't remember off the top of my head how Toyota did their PCV systems on the V8 and V6's but are you guys sure that you've tapped BOTH banks for your oil catch cans?
Posted in T120 forums for wider input.
http://www.toyota120.com/forum/showt...572#post185572
Old 07-01-2013, 04:12 AM #8
97hb's Avatar
97hb's Avatar
If running open atmosphere you can hook both valve covers up to the can but if running PCV, passenger side vent should not go to the can.
Old 07-01-2013, 04:37 AM #9
Maybe its because its late at night and my brain is shutting down, but what reasoning do you have for this?
Old 07-01-2013, 12:02 PM #10
97hb's Avatar
97hb's Avatar
Not sure about the 2UZ but the 1GR stock pcv is on the drivers side valve cover and connects to the intake manifold creating vacuum in crankcase. The passenger side vent hooked to the intake post filter pre throttle body is there to equalize the vacuum created by the pcv.
Old 07-07-2013, 10:18 AM #11
97hb's Avatar
97hb's Avatar
About 600 miles on this dump. Catches about 3 ounces per 1000 miles and at my 5k oil change I am about a quart low. I can feel the motor running smoother with no oil in the charge. Great mod and still emissons legal depending on how you hook it up.
Old 07-07-2013, 08:23 PM #12
You guys are right, I thought about it the next morning when my brain was functioning and not turned off and I remembered the routing diagram.
Sometimes tired brain no work late at night!
Old 08-02-2017, 02:58 AM #13
USA591's Avatar
USA591 USA591 is offline
USA591 is on a distinguished road
USA591's Avatar
Oil Catch Can
FWIW, I'm a Liberty CRD (turbo diesel) owner who runs a Pro Vent (catch can system) on my rig.
Why? Because the CCV tube is routed straight back into the intake side of the turbo--this causes all that oily mist leaving the crank case to be sent back through the turbo, into the intake manifold where it gunks up said manifold and specifically the MAP sensor on this engine. When I bought my (used) rig and pulled the sensor after 46K previous miles, it looked like someone dipped it in tar. Yuk.
The Pro Vent routes these gases into a condenser element where it can be drained with a petcock valve and the scrubbed gases can be sent back through the engine to keep our LA air nice and oxide-of-nitrogen free.
Does it work? Hell yeah--I pulled my MAP sensor a few weeks ago after 50K miles and it was clean and dry.
A diesel is a high compression engine so we have lots of blow-by compared to a gasser, but I'm curious--why not run this system on any internal combustion engine and keep your intake manifold sparkly clean? There's gotta be some blow-by to worry about...right?
73
PS...why am I stalking this forum? 'Cause a T4R is in my future!
USA591 is offline   Reply With QuoteReply With Quote
Old 12-08-2018, 12:43 PM #14
ZebRuaj's Avatar
ZebRuaj ZebRuaj is offline
ZebRuaj will become famous soon enough
ZebRuaj's Avatar
Sold the G35 and moved the catch can over into the 4Runner for kicks. Ebay unit with 3/8" fuel line from the auto parts store.
Mounted it on the driver side fender area.
Last picture is with 4 days of short driving, less than 80 miles. A lot of water condensation with some oil. Curious how much of the condensation is due to winter temps and my short drives. Will probably have to empty it out weekly at this rate.
6340
6342
IMG-20181201-110006
07 T4R Sport Edition V6 4x4
ZebRuaj is offline   Reply With QuoteReply With Quote
Old 12-08-2018, 12:58 PM #15
0verland's Avatar
0verland 0verland is offline
0verland will become famous soon enough 0verland will become famous soon enough
0verland's Avatar
I've run a catch can on many other cars both boosted and N/A. All applications have proven to work in my case. I was just curious because I see all the applications for our rigs only on the 1GR, but nothing for the 2UZ.
Has anyone put one on the 2UZ? Pics would be nice to see for either.
2006 V8 Limited 4WD
| Doug Thorley Headers | Gibson | Old Man Emu | ToyTec | SPC Performance | RCI Metalworks |
| Skid Mark 4x4 | SpiderTrax | BFGoodrich KO2 | aFe | Rutech | HCF Mod |
0verland is offline   Reply With QuoteReply With Quote
2005 4th gen upkeep and catch up Black4thgen05 4th Gen T4Rs 5 08-01-2012 03:40 AM
4 runner ever catch on fire? goodlooking4runner General Discussions 13 01-06-2012 10:42 PM
4 runner ever catch on fire? goodlooking4runner 4th Gen T4Rs 10 01-03-2012 03:12 PM
How to install windshield catch kit?? Help! jsulen 3rd gen T4Rs 6 02-09-2011 12:51 PM
Catch all mats Rayh78 Engines / Suspension / Wheels / Tires / Audio / Accessories 5 10-16-2003 12:19 PM
