Originally Posted by VA4Runner09
So I got this bad boy scanned in! Twas a process but she is done!! Just get this printed on a large format printer - Do Not scale to Fit! Everything is drawn to scale and you will need at least a 48" by 12" sheet of paper to print it out on. If you go to the file tab and click on properties you will see the actual sizing! Hope this helps everyone out!!
Cheers!
Brian, a thought occurred to me when someone else was asking about the fairing template. The outline you scanned may be just a bit larger than the actual template so folks may want to cut just inside the line as of opposed to 'on the line'.
I realize it may sound like a minor thing, but my fairing was made to fit pretty flush w/ the WMW lower crossbar (thereby negating any light cutoff/blockage for a LED bar mounted behind it). Figured it was worth mentioning.
HokieRunner 2005 4Runner Sport Edition V8 4x4 Silver
Build Thread
Radflo 2.5 F 700#/R 220# / Desert Racing Uniball UCA / 285/70/17 Duratrac on 17x8 Konig Six Shooter / RCI Full Skids / BAMF LCA Skid / Shrockworks 3 Hoop Bumper / Custom WhiteKnuckle Sliders / Custom WMW Roof rack / CVJ Reman'd Axles / 06+ Facelift / Custom sound system / AIP Bypass / LED Gauges,Dash,Interior / Wiring, aux. lighting, dual battery, custom cargo box in progress...
