08-17-2014, 10:09 PM
HELP! Can you identify this leak?
08-17-2014, 10:40 PM
It looks too far forward to be tranny. It could be though. I'm having a hard time with the pictures. What color is it?
I would check the oil filter to make sure it didn't creep loose. It looks like those pics are from the driver side front below the engine.
08-17-2014, 10:42 PM
Looks like coolant. Check your lines and rad for leaks.
White 2017 TRD Pro
Black 2007 Limited V6 4WD - Sold
08-17-2014, 10:49 PM
Is the fluid watery or more oily? It appears to be ATF, possibly leaking from a transmission cooler line or the cooler unit itself. Toyota SLLC (Super Long Life Coolant) is pink and would appear lighter in colour than what is shown on the vehicle at the moment.
Another thought, what color is your power steering fluid?
08-17-2014, 10:58 PM
Thanks for the replies guys. It appears to be less oily, more watery. Its not red, more like a dark pink in color. I'll check my oil filter in the morning...I hope its not major...this trip has been in the works for a while lol
Edit/ not sure what color my steering fluid is...i think its clear. Another thing to check.
08-17-2014, 11:28 PM
Agreed, possibly leaking from the pan drain plug based on that picture. Pull the skid plate and check.
2014 Trail
A mild build She gone... sad face.
2001 Limited 4x4
08-18-2014, 06:12 AM
Pink is the color of the coolant. Check the coolant resivior level too.
'14 VW Touareg & '15 Porsche Cayenne
Sold -- 2004 4Runner SR5 4WD V6 | Properly built & prepared for overland use!
08-18-2014, 07:58 AM
That really looks like ATF, check the trans cooler lines at the connections to the Radiator (drivers side).
2019 TRD OffRoad - Fox w/Resi, 650lb Springs, JBA HD UCA, T12 Rear Springs w/DS 5mm Spacer, Odyssey 34R-PC1500T AGM w/Diode Upgrade and CTEK Monitor, NOCO battery charger wired to external port for shore power, Rago Hidden Winch Plate, Comeup Seal 9.5 RSI, RCI Sliders/ Skids, 285/70-17 Cooper AT3 XLT on Fuel Rims, Various LED upgrades, OE Engine Heater w/External Port, XenonDepot Low Beam HID & LED 3k Fogs, ScanGauge, Midland GMRS, Accessory Mount for iPad, mike and Inreach, iKamper Mini 3.0, Custom Kitchen/Cargo system, ARB 50Q, Goose Gear dual drawer, Wilco Solo Tire/Hilift/RotoPax Carrier.
08-18-2014, 09:49 AM
This. Maybe grab some brake parts cleaner and spray/wipe everything down. Best way to see where it may be coming from
2008 T4R 4x4 V6
08-18-2014, 02:52 PM
The coolant looks far lighter than what you see on the vehicle right now, it will look closer to tinted water; where as this looks sort of like kool-aid and the napkin really shows the redness of the fluid.
I think he's got an issue with his transmission cooler or lines, because you can see the front skid plate is soaked from high up, which indicates the leak is around the radiator area.
08-18-2014, 06:34 PM
I agree Tammy cooler lines are suspect, I can't tell the color in the picture though. But not knowing if the water-pump is puking its worth checking.
08-19-2014, 04:02 AM
Geez.... Just smell it and you'll know. The coolant smells like a dead animal and ATF smells petroleum based. Easy.
2005 Sport Edition V6 / Toytec Ultimate 3" lift / Light Racing UCA's / 17x9 KMC Hoss wheels / 285/70 17 Goodyear Duratracs / Gibson cat-back / black headlights / HID's / Shrockworks bumper / Rola Vortex roof basket / LED interior swap / Emelianenkov's gauge cluster LED swap /
08-19-2014, 09:36 PM
what does it taste like? LOL
08-19-2014, 09:47 PM
Real Name: Leonard
Real Name: Leonard
It taste like Pink..,... Never mind.
Having fun's build
08-23-2014, 01:50 PM
Back from my 350 mile trip, and had no issues. I checked my coolant level along the way and it was around the full mark. I also kept an eye on engine temps throughout the trip and it never really fluctuated. I have a feeling that, as some of you noted, it is coming from the area of the bottom of the rad because when it drips it usually pools closer to the driver side below the inner axle boot. I'll be taking it in to the shop this week... Hopefully i wont need a new rad! Thanks for all your input!
