Powerstop K2422
montijo505
Hey guys, I searched but couldn't find any info on this. I Bought a powerstop kit for my Cobalt and it works really well. Looking at a kit for my 4Runner but don't know if it's the right size rotors as there is two different options. The one I'm looking at is 13.30" front and 12.28" rear rotors. Is this correct for a 2008 SR5? The other option is 12.56" front and also 12.28" rear. I have 17's on my 4Runner. Thanks in advance!
Check the castings on the front calipers. I'll research for the markings & edit this. Just because you have 17" wheels doesn't nessesarilly mean you have the larger rotors. I think you probably DON'T have the larger ones as they were standard on Sport & optional on Limited.
EDIT: the smaller rotors use calipers stamped "WL" or "WG", the larger rotors use calipers stamped "WH" so look for those markings.
You can always upgrade to the larger if you are getting new calipers. (REQUIRE 17" wheels)
Thanks, I'll check after work, in order to complete the upgrade the only other thing needed would be calipers correct?
