Rear window control (interior) stopped working.
Lewis&Clark
Before I pull apart my dash I thought I'd see if it's something simple like a fuse. Anyone know which fuse the interior rear window switch might be connected to?
The sticker on the fuse panel doesn't say anything about that specifically and not sure it fits under any of the others. Maybe TAIL?
IGN SRS GAUGE STA.NO.2 FR.WIP / 4WD /
/ D.PWRSEAT P.PWRSEAT PWRSEAT.OUTLET / RR.WIP ECU-IG IG1
STA SECU/HORN / / / TAIL ACC CIG
POWER
Is it still working when you use the key fob, or when you turn the key in the lift gate? If yes then check that the window lock button isn't engaged. When that is pressed the rear window will not respond to the interior control.
Funny story, I thought mine stopped working once, turns out I just had the windows locked. :fro:
This happened to me when I first bought it. Worth mentioning. Seems like it shouldn't be included in the window lock circuit.
