One of my front lower ball joints is torn, the rubber part, and some fluid/grease has leaked/is leaking. I assume it will need to be replaced at some point.
Yes I tried search, mostly 3rd gen stuff, and 1 thread on replacing just the ball joints which mainly says how much of a pain it is.
My plan is to just replace the entire LCA on both sides. This site has the set with ball joints for $171 shipped.
2007 Toyota 4Runner Front Lower Control Arm with Ball Joint Pair at 1A Auto.com
I know buying just ball joints would be cheaper for parts, but would require purchasing a special tool (tie puller?), which would make the total cost almost the same, and possibly require more work, so why not just get new LCA's.
It's been almost a year already and I haven't noticed any ill effect from driving like this.
With all that said, what is the harm of driving with the torn ball joint for the time being until replacement? When it gets to the point of "failure" what exactly could/would happen? I'd think not, but would failure of the ball joint harm any other parts? Thanks everyone
