10-24-2015, 11:43 AM
Real Name: Kody
Real Name: Kody
Seafoam Second Opinion
I am planning on seafoaming my vacuum lines today as well as cleaning the MAF sensor.
I just want to make sure I have the right line before I run sea foam through it.
Thank you for your time!
2007 Silver Limited 4.7: Bilatein 5100 front and rear, 1.25?; Moog FJ springs front and rear; Nitto Grapplers 265/70/17;
2018 Super White ORP: Bilstein 5100s front and rear, .85; BFG Ko2 265/70/17/C (sold)😩
2003 Grey Sport Edition V8 (sold)
1997 Bronze 5-speed manual (sold)
10-24-2015, 11:44 AM
Seafoam is a overhyped product. Why do you need to seafoam your engine?
2007 V8 Sport Edition: Definitely Not Stock
2014 LX 570: Stock
10-24-2015, 01:49 PM
I tend to agree. If Toyota thought these sorts of products would improve it's engine QDR (Quality, Durability, Reliabilty) they'd require them in the maintenance manual.
I'm not opposed to running a fuel system cleaner like Techron through once a year but admittadly that's not required either, I just do it out off boredom and to feel like I'm doing something important.
10-24-2015, 03:08 PM
I'd like to know too. Please take pics when you do. It might be over hyped but for now I'm a believer. About 5 yrs ago, my other car (not a T4R) was idling low and sputtering. Seafoam fixed it.
Black 2004 Toyota 4Runner SR5 V8 (born again Aug 2014)
DIY: spark plugs, servos for vent and airmix, fender splash shield, seafoam, rear axle seal & parking brake, exhaust muffler tailpipe, rear brakes, hood struts, a/c recharge, front brakes, front struts, rear shocks, ATF exchange, smartphone holder.
10-24-2015, 03:50 PM
Real Name: George
Real Name: George
In your attached picture, front most hose in the center of the block.
Seafoam is not overhyped. It can make a significant difference is your performance. A little in the gas tank, a little in the oil, a little in the vacuum lines goes a long way on a high mileage gunked up machine. It's truly a great product, been using for years.
Just be sure to give her a hard run ( 'spirited'is the preferred term) after
10-24-2015, 03:51 PM
Real Name: George
Real Name: George
*front most vacuum hose
10-24-2015, 05:55 PM
Real Name: Kody
Real Name: Kody
Is this the right one?
Looks/ feels like air is being sucked into the block
10-24-2015, 06:26 PM
Seafoam is like cocaine....makes everything better until it doesn't....
If it aint broke, don't fix it. If it is broke, understand the problem before adding cocaine.
2006 4Runner SR5 4x4 V6 Shadow Mica => Mrs
2006 4Runner SR5 4x4 V6 Titanium Metallic => Mr
2012 Sequoia SR5 RWD 5.7L Magnetic Gray Metallic => "I get to drive it! (says hubby) No! I get to drive it! (says wife) Happy Wife - Happy Life
10-25-2015, 01:41 AM
Real Name: George
Real Name: George
that is the one. was on my phone earlier and couldn't make an arrow on the pic.
i'm surprised at all the 'hate' on the seafoam here. i thought it was generally well received here while doing my initial research on which hose to use. saw some good videos that proved it works. i saw some power/mileage increases after my treatment (142k).
10-25-2015, 07:56 AM
Real Name: Steven
Real Name: Steven
Basically you just want the SF to be ingested. It will ingest into the valves pretty much anywhere you inject it into the intake plenum. You really are not cleaning the plenum, the valves are what is the major concern. Deposits to form on the valves, especially if you use a low quality grade of fuel and do a lot of city driving.
Don't skip the cleaning of the TB as well. If it's dirty you will feel a pretty good difference in the idle for sure.
2008 4R LTD V8 4WD, ICON Stage 3, TRD Pro Wheels, GOBI Rack, TRS HID Swap along with too many other mods to list here!
10-25-2015, 08:10 AM
Seafoam
I recently watched a video comparing seafoam to heet (and ipa)....
For what it is worth, here's the video
https://youtu.be/ElbgPhujl_M
Stock 2016 4Runner
Trail Edition, with KDSS, Weathertech mats, TRED PRO x4
10-30-2015, 12:48 AM
Just seafoamed my 4th gen v8 today... 240k kms (Canada) on it, don't really notice it running different, has been maintained perfectly since day 1 and ran perfect before, runs perfect now...
Lots of blue smoke so I guess that means it helped? I used 3/4 of a can and used it in that vacuum nipple that has the black cap at the front of intake manifold... Took cap off, hooked up vacuum hose with a hose clamp, rev and put the hose into the bottle... Make sure you don't let it stall out.
Hope that's clear, researched for a while and it was hard to find the right answer... This is it. Good luck and enjoy!
10-30-2015, 12:51 AM
That's the right one... Pull black cap off, vacuum line with hose clamp if necessary, stick hose into seafoam, rev engine and go... Don't let it stall, just dip the hose in then remove...
10-30-2015, 01:11 AM
Originally Posted by Ogre Ray
Eh, I don't really think of Seafoam as a fuel stabilizer; but I guess it does work that way.
These are some interesting videos, I had been wondering if anyone did real world testing with a borescope.
In a lawnmower:
https://www.youtube.com/watch?v=WdT4DPFXIkM
In a bigger lawnmower:
https://www.youtube.com/watch?v=u6UeJXkzDW8
The pistons weren't too bad in either engine to begin with, but it does give a decent idea of the cleaning properties. The basic thing to take away here is that Seafoam is a double edged sword, you can use it as a preventative maintenance every oil change or every other oil change to help reduce carbon build-up (in which case you may not see any noticeable results, because well there's not a lot of carbon anyways.) Or you can use it as a deep soak, carbon buster (which I have done on a few heavily carboned vehicles), in which case you run the risk of breaking loose chunks of carbon and/or unplugging what that gunk was plugging up.
You don't NEED Seafoam to keep your engine running good, but for the most part it does do what it is designed to do and using it as preventative maintenance doesn't hurt much either. The main thing take away is that you're using Seafoam mainly to break down carbon on the valves, pistons, and injector tips. Depending on things like severity and how you use the product, your mileage may vary.
While these types of products aren't usually called out in maintenance manuals for traditional gasoline engines, you do see many manufacturers starting to call for them in the newer GDI engines because the carbon build-up on the valves gets pretty nasty.
10-30-2015, 03:04 AM
Real Name: Rob B.
Real Name: Rob B.
While I always have a lot of respect for
@ BlackWorksInc
replies and automotive knowledge, I'm still going to say that Sea Foam sucked in through a vac line is a waste of $7. The Sea Foam can't possibly stay on any surface long enough to clean anything. If you mixed it with your fuel, I could see it providing some cleaning properties especially if you have crappy fuel near you with few additives.
There are more people that don't understand what they are doing and hydro-lock their engines than people that gain any benefit from sucking Sea Foam through the intake. Don't be one of those people.
2009 GX470 Sport Edition w/ KDSS
