PDFs for 4th Gen Fender Liners
I discovered my run of the mill work Xerox copy machine did 11x17 and we had 11x17 paper. For those of your with office type jobs that "allow" you to print personal things make sure you check out your large copy/printer. I don't mind paying $2 to a copy shop to print it up but I do mind stopping off at one and waiting 5-30 mins in line.
what is the hell size paper does this require? C? What scale?
Does anyone have the dimension of each leg or 3D CAD part?
So I just did this. Couple things I'd like to add for anyone thinking about doing this--
I initially went with 1/8" buna rubber. Bigger is better right?
Finding replacement fasteners is a royal PITA. I first tried the tap & bolt method with and M8 tap, but found out some holes were already larger than 8mm.
Then I tried finding the fasteners suggested here. Looked around at home depot, found some fasteners, but they were a dollar a piece (no thanks).
Ultimately, I got fed up with the fasteners and decided to go with the 1/16". I was pleasantly surprise when I compared with OEM and found the the 1/16" was a hair thicker. Also much easier to cut.
Cut some out yesterday and just tested one on today and it looked amazing now I just got to do the rest. I used 1/16 Grainger Vinyl Rubber and some plastic rivets to hold it in place. Thank you! Really save me some money. Spent only $14 for everything
I uploaded the PDFs for everyone:
4th Gen Fender Liners PDF
You will need a printer that can do 11 x 17.
UPDATE 6/26/18:
Thanks to [MENTION=113703]46runner[/MENTION], here is the link to PDFs you can print on an 8.5x11 printer and piece together:
https://t4r-1351852ontarioin.netdna-ssl.com/attachments/4th-gen-t4rs/268736d1506110940-pdfs-4th-gen-fender-liners-aprontemplates.pdf
I used some oil resistant rubber from Grainger:
GRAINGER APPROVED Rubber,Vinyl,1/8 In Thick,12 x 24 In - Rubber Sheets and Strips - 1MXU1|360-1/8B - Grainger Industrial Supply
"Oil-resistant Vinyl Rubber, Plain Back, 1/8" Thk, 12" X 24", 80a Durometer "
Part number on grainger.com is: 1MXU1
I think I put around $20 bucks into it (I think 2 sheets did it??? 1 sheet is ~ $11.50 ).
Also, people are cutting up Rubbermaid trash cans, or using trimmable floormats.
According to Preacher35:
"4WDFTW made templates for these pieces."
"The parts that you are referring to are the front fender apron seal (smaller piece) and front fender splash shield (larger piece). The part #'s are as follows:
LH FAS: 53736D
LH FSS: 53886H
RH FAS: 53735B
RH FSS: 53886H (yes, same as the left hand)"
Many thanks to [MENTION=89791]preacher35[/MENTION], [MENTION=100938]acronin2[/MENTION], [MENTION=115707]4WDFTW[/MENTION], and everyone who contributed to this!!!
:thumb: :cheers: :thumb3: :beer:
Original Thread
Another Thread
Hi,
New here..
any chance that the templates are similar to Prado KDJ120 (03-09)??
if not - any ideas where would I find matching templates? I looked everywhere :(
TNX a lot anyway.. great site!
[MENTION=145671]BagiMT[/MENTION], thanks for the Amazon link. Looks pretty stout for 1/16" thick, is that what you used? I see it also comes in 1/8".
Yes, I got the 1/16", is plenty strong and works with stock fasteners. The pictures looks thicker than it is, but 1/16" is thicker than the stock rubber.
I’ve ordered the product from RadRubber for both my old 3rd gen and now 4th gen. Quality is top notch but shipping has been slow lately. Ordered mine on 3/6 and they just shipped this week for arrival early next week.
erinobr2000
