03-19-2016, 01:47 PM
I have no first hand knowledge of wheel spacers, but if that was my car I would get a set of regular nuts and use the acorn nut on the tire to spacer instead of spacer to rotor.
If the spacer is beveled to use acorn nuts, I would not use the spacers with only half of the threads engaged. In other words, I would send them back.
03-19-2016, 01:58 PM
Real Name: Leonard
Real Name: Leonard
It's like your studs are not long enough for some reason. Spacers I have, nut sits just inside the spacer about the same depth distance as your picture and the stud is at the end of the nut to where no threads are show on it.
I wouldn't run them like that!
Having fun's build
03-19-2016, 02:00 PM
If that thing goes, that is going to be catastrophic, so be cautious and trust your gut.
Spend a few extra bucks and get proven spacers.
I had similar eBay spacers thrown in with mine when I bought it from the owner. Theose spacers didn't have the reputation for fitting Toyotas well. I sold them for top dollar on ebay and got Spidetrax. I sleep well at night.
Trust your instincts.
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
03-19-2016, 02:40 PM
I thought about getting some eBay spacers, but ended up going with spidertrax instead. I wouldn't trust that little of thread engagement.
03-19-2016, 04:31 PM
I would measure the hole inside diameter and outside diameter and see if the all-pro et studs fit. i use them with my all pros and the only problem with them is you need a thin wall SAE socket for them.
https://www.allprooffroad.com/store/...ef=6850A-AP-ET
04 4runner Sport Edition V8
-MODS- Maxtrac Lift Spindles | Bilstein 5100/5160| Tacoma frt springs | MT LT 3in reat springs | eBay UCA | SS brakelines | 4crawler body lift | 17 level8 punch | At3 315/70/17 | K&N cai | black clazzios |
Build thread
03-19-2016, 07:06 PM
Yeah, I'm not running them like that for sure. It does say that your studs need to be at least 1 inch to install them, mine measure about 3/4. They fit the hub like they should, so I'm not sure what more I can expect from spidertrex but my wallet being much lighter. I read on the tacoma forum you can switch to IS300 studs or Toyota matrix studs to get the extra length. Guess I'll try that....
03-19-2016, 07:11 PM
Originally Posted by truckhigh
This is a cheaper option, thanks for the link.
03-19-2016, 07:16 PM
So in total, how much will you spend on these spacers & longer studs vs. a known brand spacer?
1999 BMW M3 coupe(E36) & 2005 V8 sport 4X4 black: ARB bull bar with 4 hella 500s,backup camera in spoiler,VSC off, springs:Tacoma w/ toytec(1/2"Fr) & FJ w/ daystar(1.5"R) spacers,Bora .75" front & Spidertrax 1.25" rear spacers,swaybar bushings upgrade,Stoptech rotors,SS brake lines,RCI Metalworks skids (front, trans.,transfer), Volant CAI,DT shorties w/ Dirty Deeds exhaust,fully soundproofed,Rostra seat heaters,HID (lows),HIR (highs),running board lights (added),aux reverse lights,2006+ tail lights,rear fog mod (tail, brake, directional OR rear fogs),Scion T1819,LED int. lights, key reminder diabled, Land cruiser steering wheel,rear window dog barrier, vent visors, Ultraguage, Enkei Deep Six 20" wheels for summer, factory sport wheels with A/Ts, FJ cruiser wheels with winter tires
03-19-2016, 07:20 PM
I would buy longer studs and be done with it, wouldn't think there would be any difference than the expensive ones. Other than maybe being milled out of solid aluminum instead of the other
03-19-2016, 07:32 PM
I still don't understand why people bring up a "name brand" spacer. Am I missing what else it does other than a piece of 1.25 inch aluminum that is between your rotor and wheel? Not being a wise ass.. if someone knows, I'm all ears.
$157 for the set and it looks like the extended lug nuts will fit, so .75 each x 24 = $18. Not sure on shipping, but call it 10 bucks. $185 vs $400
$157 for the set and without really shopping around extended IS 300 studs are $175 for 5 sets. $332 vs $400. Matrix studs are cheaper at 36 for enough to change them all, so $193 plus 10 or so shipping for the studs. ~200 vs 400
03-19-2016, 08:31 PM
I had the same spacers, had the same issue with the studs. I ran them but put red locktite and didn't have any problems. But I also had second thought about it. I know have correct offset wheels.
2006 4Runner SR5 4x4 4.0, Ironman 4x4 complete 2" lift, method wheels, 275/70r17 BFG ATs, SOS Concepts front plate bumper, and Prinsu Designs roof rack.
03-19-2016, 09:05 PM
Studs from napa should be like 2_5$ a piece
03-19-2016, 09:17 PM
the rears should not have a problem as they are longer studs
Budget Build,5100's with tacoma/fj coils, CBI Offroad Front mount hitch, MY MAP LIGHT MOD How to: A/C in console
09 limited Titanium Metallic ,stock, color matched emblems, LED interior lights, winjet fog lights, LED foot well lights,HCF mod, fumoto f-103 oil valve, anytime backup-camera mod.
03-19-2016, 10:28 PM
Real Name: John
Real Name: John
2004 V6 2wd Sport - BFG Mud T/A KM 255/75/17, Bilstein 5100’s: front FJ coils, 4" lift spindles set @ .85, rear Metal Tech LT MD coils, SS brake lines, Uniball UCAs, Spidertrax; K&N air filter w/ HCF delete, WeatherTech Liners, dual batteries w/ isolator, inverter w/ 110v outlets, on-board air, satellite radio, custom grill emblem and roof rack; Mods: auto headlights, aux remote reverse LED pods and GY6.35 50w reverse bulbs, rear camera, interior LEDs, VSC, 12v w/ added outlets and windows always on, DRL on/off w/ always on mode, fog/map light, key reminder, TPMS bypass, front wheel liner relocate; de-badged, mud flaps, running boards, resonator, Xreas, front/rear sway bar removed
