Old 05-12-2016, 11:14 PM #1
jbssfelix jbssfelix is offline
jbssfelix is on a distinguished road
Unique Brake/Wobble Situation
So I've searched the forums and have similar issues, but I haven't found one that fits my exact situation.
Twice in the past few weeks, I've had to throw down the brakes pretty hard, one time enough to lock the tires up for a split second and engage the ABS. In both cases, immediately after I encountered pretty severe steering vibration/wobble. It occurred throughout the speedo, but got much much worse starting around 60mph (didn't go above 65 so I don't know if it died down above that). It also had some very noticeable vibrations on braking as well, particularly on medium-pressure.
However, in both cases I got to my destination and let the truck cool down for a while (15 min first time, about 2.5 hrs second time). When I came back, everything drove perfectly smooth as if nothing had ever happened.
Tire wear looks normal, brake rotors look clean (although they aren't new by any means). I haven't taken off a wheel yet to look at the pistons/calipers, but a recent trip for a routine checkup/oil change showed healthy levels of pad left.
Has anyone experienced this interesting combo of issues?
Thanks.
PS - 2005 4x4 V8 Limited, if that makes any difference.
2005 V8 Limited 4x4 - Dorado Gold
jbssfelix is offline   Reply With QuoteReply With Quote
Old 05-13-2016, 08:58 AM #2
sonerick's Avatar
sonerick sonerick is offline
Real Name: Nick
sonerick is on a distinguished road
sonerick's Avatar
Real Name: Nick
I've had these symptoms due to a sticking caliper piston.
2017 Chevrolet Silverado 1500 LT Z71
2011 Audi A4 2.0T Quattro
2005 4Runner SE V6 4WD (Sold)
2004 Volvo S60R (Sold)
1999 Jeep Cherokee Sport (Sold)
sonerick is offline   Reply With QuoteReply With Quote
Old 05-13-2016, 11:31 AM #3
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
That sounds like a plausible theory. It's not uncommon for the rotor to temporarily distort when it gets really hot under conditions of hard braking. My old Suburban used to do that. If the calipers are moving freely, that should only result in a mild vibration, since the caliper piston can float with the rotor. A stuck caliper would likely result in a much greater vibration.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 05-16-2016, 06:37 PM #4
emoore924 emoore924 is offline
emoore924 is on a distinguished road
Yep, probably an overheating rotor due to a sticky caliper.
Common problem.
Will likely mean replacing both front calipers and replacing (or turning) the front rotors...
emoore924 is offline   Reply With QuoteReply With Quote
Old 05-16-2016, 11:42 PM #5
having fun's Avatar
having fun having fun is offline
Real Name: Leonard
having fun will become famous soon enough having fun will become famous soon enough
having fun's Avatar
Real Name: Leonard
If the calipers are ruled out, you might check into LCA/UCA bushings.
Had a high speed hard braking create the same effect, and wouldn't happen for normal breaking. Changed bushings, and never came back.
Having fun's build
having fun is offline   Reply With QuoteReply With Quote
Can rear axel seals fix themselves? Unique situation... Jason B 3rd gen T4Rs 24 10-21-2016 01:50 PM
Unique Brake issue Dunngeon 4th Gen T4Rs 2 07-31-2015 11:39 AM
Brake fluid/dash light situation/ fluid level FlaskTL 5th gen T4Rs 19 06-03-2015 10:53 PM
Unique Job Experiences 4Runner4TW Off Topic 13 09-08-2013 11:43 AM
Unique Situation - Low Mileage 2003 4Runner Limited. rchavez1 Maintenance/Detailing 8 10-03-2005 05:49 PM
