Old 06-01-2016, 03:42 PM #1
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
Does Removing the Lower Grill Insert Require Removing the Bumper?
I plan to do the same mesh I used for my Satoshi in my lower grill and hood scoop. I found directions for removing and disassembling the front bumper that seem to say the lower insert is removable and doesn't have to be cut out like the main grill insert does.
Has anyone done mesh in the lower grill on a 4th gen, and/or has anyone removed the lower insert without removing the bumper?
Any insight appreciated.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 06-01-2016, 04:00 PM #2
DarenS DarenS is offline
DarenS is on a distinguished road
Check the service manual (sticky at the top of this forum). No bumper removal is necessary.
2008 T4R Limited 4WD V8 | Stock Rims | Michelin 270/70-18 LTX M/S 2
2004 Greyhound | 25 Races - 3 Wins | 0-45 MPH in 3 seconds | 45 MPH - Couch in 2.5 seconds | Retired in 2007
DarenS is offline   Reply With QuoteReply With Quote
Old 06-01-2016, 04:13 PM #3
Morphyne Morphyne is offline
Morphyne will become famous soon enough
I have done both. See thread below for grill. the insert just snaps out. although it might be hard to get the lower grill right without taking the bumper off.
Pics aren't that great. I had to take my bumper cover off to paint it. it wasn't that bad. in my opinion it is easier to take the cover off and beable to work with it and get your grill right than trying to do custom work on your back.
Morphyne's Painkiller build tread
Morphyne is offline   Reply With QuoteReply With Quote
Old 06-01-2016, 09:49 PM #4
iAlex684's Avatar
iAlex684 iAlex684 is offline
Real Name: Alex
iAlex684 is on a distinguished road
iAlex684's Avatar
Real Name: Alex
You don't need to remove the bumper to remove the lower grille insert. There are tabs that holds the grille insert on to the bumper. I used a flat head and mainly played around until I can feel alittle play in the grille insert. I believe there are a total of 10 or 8 tabs. I used a lift at my work to be able to be eye level to take it off since I didn't look for any instruction.
2006 Toyota 4Runner SR5 2WD 4.0 Liter / 20x12 Fuel Turbo 6 / Single 12" Soundqubed HDS312 at 2400 watts / Satoshi Grille / Hydrocarbon air filter delete / Custom Headlights with Halos / Tinted Windows 5% all around / Pin Stripe Removed / Lower Grille Flush Mounted Lightbar / Toytec Ultimate Lift /
iAlex684 is offline   Reply With QuoteReply With Quote
Old 06-02-2016, 08:38 AM #5
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
As stated above for the 06-09 bumper, the lower grill insert can be removed easily without removing the bumper. Mine had two screws then was just carefully working all the tabs around the edge out. I have the grill still sitting in my garage and can post a pic of the tab locations if you find you're having a hard time with it.
blackoutt is offline   Reply With QuoteReply With Quote
Old 06-03-2016, 07:24 AM #6
blackoutt's Avatar
blackoutt's Avatar
Two bolts on the top license plate frame area then big flat clips on the bumper that pop into the grill, slots shown on grill in second pic. 6 clips along the top, 7 along the bottom.
Lower grill insert removal 810moto 4th Gen T4Rs 3 10-12-2014 06:18 PM
Need help removing rear shock lower bolt WHORERUNNER 3rd gen T4Rs 7 01-06-2012 07:36 PM
Removing lower-middle section of Front Bumper James_T 4th Gen T4Rs 2 02-27-2011 10:12 AM
removing grill marcel 3rd gen T4Rs 12 10-07-2010 12:30 PM
removing my grill imryannn 3rd gen T4Rs 3 02-02-2009 04:14 PM
