Old 07-20-2016, 10:03 AM #1
zidaro's Avatar
zidaro zidaro is offline
zidaro is on a distinguished road
zidaro's Avatar
you could slip a spacer in there to get a little bump, if you could find a spacer to fit the tophat. Its not the same shape as the top of OEM strut.
You also can crank the coil down a little bit beyond 1.5", issues arise when you've cranked it to less than the compressed length of the coil, then when it bottoms, the spring compresses on itself and crushes itself.
But, the correct way to achieve proper ride height is to suspend the vehicle with the proper spring. You need to up up your rate to a 650 or 700# spring. Easy to do, and then you did it right. It'll ride much better than a cranked down over compressed lightweight spring
Couple Yotas
Iluv4xToys!
zidaro is offline   Reply With QuoteReply With Quote
Old 07-20-2016, 10:39 AM #2
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Yeah, I have no complaints with my 700# coils + V8 and stock front bumper even. Need to measure how much of threads are exposed but I have a full 3" in the front.
2005 4R "The last of the V8s!" - TC +2 LT. - Lockers Front & Rear - 37's - Dana 60 - Build Thread
2005 Tundra 2WD Regular Cab 4.7L - Chopped Frame - Short Bed Swap - Lowered
2019 Tundra 4WD Double Cab 5.7L My Website: Full Metal Designs
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 07-20-2016, 11:21 AM #3
GX4SEVEND's Avatar
GX4SEVEND GX4SEVEND is offline
GX4SEVEND has a spectacular aura about GX4SEVEND has a spectacular aura about
GX4SEVEND's Avatar
Someone smart probably replaced those with taller coils haha.
You should buy icon or king coils in a longer length, like 14". This allows a taller lift with less preload on the spring. Just a thought.
‘14 SR5 in white
Front: King ext travel 2.5 w/ adjusters, TC UCA/LCA
Rear: King 2.5 shocks w/ adjusters, Dobinson’s 3” Icon Billet lowers, Icon tubular uppers, PCK
Wheels/Tires: SCS SR8’s w/ Toyo MT 35x12.50x17
Full RCI skids
GX4SEVEND is offline   Reply With QuoteReply With Quote
Old 07-20-2016, 11:36 AM #4
Civiceg94's Avatar
Civiceg94 Civiceg94 is offline
Civiceg94 is on a distinguished road
Civiceg94's Avatar
I though about the same thing. To put spacer. The way it came from icon i like the way it rides. Am afriad if i crank it up a bit itll change the way it rides.
Icon extended travel coilover, Icon 2.0 rear shock, Ome 895e rear spring, Camburg balljoint control arm, 285/70-17 Toyo open country at2, SCS F5 17 inch gloss sliver, Energy Suspension bushing sway bar & front lower control arm, Viair 2gallon air compressor, DDM Tuning 55w hid low.
Civiceg94 is offline   Reply With QuoteReply With Quote
Old 07-20-2016, 05:13 PM #5
EdmundGTP EdmundGTP is offline
EdmundGTP will become famous soon enough
It will change the way it rides.
Another thing to consider. The coilover assemblies designed for our trucks have a specific length when fully extended. That length is determined by the optimum travel range of both the suspension linkage, and the operation range of the CV joint. Adding a spacer on TOP of the coilver may likely forces the knuckle droop to be further than what the CV can accommodate. I.e. extreme CV angle when either of the front wheels is nearly unloaded.
Consider the scenario in which you're climbing up uneven terrain. One of your front wheels completely unloads and that CV angle is now way past the normal operating range because of the top spacer you added. ATRAC kicks in, and locks the brake at that same corner, and now your drivetrain is transmitting intermittent torque through a CV who's angle is very close to, or maxed out. Bye bye CV joint.
'06 V8 4R Sport, FOX 2.5 RR/DSC Coilovers, FOX 2.0 RR/CD shocks, Wheeler's & Timbren Bumps, ROKMEN lower links, LR UCA's, Warn VR8000, 7069's, Hanma LEDEEZ, DO Front Bumper, BAMF LCA Skidz, RCI Skidz, WMW Full Size 4x8 Roof Rack, WhiteKnuckle Sliders, etc. etc.
EdmundGTP is offline   Reply With QuoteReply With Quote
Old 07-20-2016, 06:41 PM #6
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
You're much more likely to over-stress the CV by turning sharply than you are by any reasonable amount of suspension droop. The front wheels have a maximum turning angle of around 30 degrees. To get that much of a CV angle with suspension droop would require a droop of about 7-8 inches from horizontal at the wheel. A 1" spacer isn't going to get you to that point. You'd have to do a roughly 4" spacer-only lift to get those kind of angles.
It's also worth noting that preload does not change the stiffness of a spring. Stiffness is set by spring materials and construction. Consequently preload, whether done by raising the spring perch on the shock, or by inserting a spacer at the top of the shock, does not change the ride at all unless you shift the ride height so much that you are hitting the bump stops or exceeding the shock travel. As long as the preload does not exceed the vehicle weight (which case would prevent the suspension from getting off the lower stop), the spring operating point does not change, regardless of preload. It is still the same stiffness spring, and it is still supporting exactly the same amount of weight, therefore its loaded length will be exactly the same as it was before the preload change.
Preload does bias the suspension operating point away from center. Where spacers and other lift options cause trouble is when the suspension nominal operating point is biased too far from its center value, causing the suspension to frequently hit the stops on one end or the other, or causing the spring to go into coil bind before the stops are reached. As long as neither of those situations occur, the ride should be indistinguishable from the non-preloaded case.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 07-20-2016, 07:36 PM #7
Civiceg94's Avatar
Civiceg94's Avatar
so how are the people on this forum reaching heights of 39 inches without complaining about cv angles and also vibration from having the cv at weird angles?
Old 07-20-2016, 08:08 PM #8
By that reasoning, wouldn't a 3" coilover lift with a 1" spacer on top of it get you damn close to it?
What about an over max suspension droop PLUS turning the wheels?
bumpstop , icon , lift kit , spacer , suspension
Trd pro suspension vs icon?? Desert36 5th gen T4Rs 90 10-04-2016 11:20 PM
Anybody know what small spacers with dif drop kit r for? direwolf74 3rd gen T4Rs 2 06-07-2015 09:33 PM
Stacking spacers on Icon Coilovers JustSomeName 4th Gen T4Rs 12 01-10-2014 09:15 AM
ICON Suspension for 4th Generation - Icon Stage 6 WOLVERINE Want to Buy/Trade 2 02-18-2013 01:39 PM
Icon install. opps small mistake. ejason 5th gen T4Rs 0 05-02-2012 12:14 PM
