You "shouldn't" really.
To do an axle, you don't need to disconnect or touch the tie rod. Just the two lower bolts that secure the spindle to the ball joint mount.
I guess technically the littlest bit of toe could be off, but if it drives straight, and the steering wheel is straight, I think you'll be fine.
2005 4R V8 4x4 Limited - LEDs, FX-Rs, Gibson exhaust, TRD Red Front/Rear shocks, OME front springs, Toyotec rear springs, BF Goodrich 275/70/17 K02s, 1.25" Spidertrax. Front/Rear Polyurethane sway bar bushings, Total Chaos lower control arm alignment tabs. 150k miles and counting
2005 Prius - DD/Grocery getter. 250k miles and counting.
