Black front and rear emblems
luke87gt
Hi guys,
Can anyone steer me in the right direction for a pair of black/smoked front grill and rear tailgate trim toyota emblems?
Thanks
Buy new emblems off eBay, lightly sand, 3 coats of black 2-in-1 primer/spray paint, two coats of UV resistant clear spray paint, pull the adhesive tape on the back and you have a permanent, good looking solution.
Way cheaper to just use plastidip, don't even have to remove the emblems, just tape a square off around them, 1 light coat, a few normal coats with 5-10 min tack time between, then after it dries just peel the overspray and open centers of the emblems out with a toothpick. My front badge lasted over a year of no care and pressure washing then I had to peel it off and respray, rear is going on 2 years now.
Another vote for plastidip. After searching high and low for factory black pearl emblems, to no avail, I took the time to remove, sand, and paint mine. Front Toyota emblem is chipping away in multiple spots a year later.
If I could do it over I would have not wasted the time and just plastidipped. Since I can do it over again, that's what I'll do.:D
i thought you're not supposed to sand when plasti dipping? i remember reading somewhere that the surface is just supposed to be clean.
The person who mentioned sanding was talking about using regular paint, not plastidip.
I never sand for plastidip, just clean with a degreaser, then hit it with rubbing alcohol and let it dry.
missed that part! i want to do my sport wheels soon, gonna practice on the spare. should i use degreaser on the rims to get the stuck-on shit off?
Thank you for all the replies guys.
It looks like plasti-dip might be the way to go in this case.
I'll give it a shot.
