12-12-2016, 06:44 PM
#46
Originally Posted by t-man
Lol, we finally got some snow! Went wheeling with my buddy. Check out my build thread, 2.5' of fresh powder was fun.
I would assume the 6112 would handle things better, not sure on the 5160. I know I'll never buy another bilstein product again! Complete crap so far. Lol
Sent from the drivers seat of my 05 4runner.
So what would you recommend if not bilstein?
My brother lives in Michigan right now-when he was out for Thanksgiving we got him snow here in SoCal, before he'd had any back there.
Originally Posted by Inv4drZm
You already have the Metaltech lower links so all you would have to do is unthread the end an inch and reinstall them. This would keep 35's from stuffing near the rear door by pushing them back toward the middle of the wheel well giving your axle more range of movement.
Hmm. I learn things here every time.
Presumably I'd do that in conjunction with the body lift?
Ideas, ideas...
Thanks!
12-12-2016, 07:59 PM
#47
Real Name: Tony
Real Name: Tony
In my first post on this thread I outlined that I really feel better quality, preferably rebuildable, is needed for the added mass. Fox, King, radflo, icon, boss, etc. 650# or 700# Springs in the front and 225# springs out back.
I have no experience with the 6120 series, so they could be worlds better, but for the price I'd go with one of the above mentioned. Quality proven.
2005 Toyota 4Runner, Sport Edition, V8, K&N filter, Doug Thorley headers, custom dual exhaust, Bilstein 5100 W/ Tacoma TRD coils in front, FJ Cruiser coils, Daystar 1.5" spacer W/ Doetsch Tech 8000 10" shocks in rear, 2.5" 4crawler Body Lift, removed Sway-Bars, removed mud flaps, removed running boards, chopped body mount, 315/70-R17 Hankook Dynapro MT
Build thread: http://www.toyota-4runner.org/4th-ge...ld-thread.html
12-13-2016, 01:10 AM
#48
Real Name: Blake Salce
I think body lift a got a bad name from years ago when guys modified hockey pucks for their chevy trucks. For obvious reasons of stacked spacers, unsafe spacers. And a complete hack job this allowed movement and created issues of course. Movement equals breakage!
No lift means lower cog, yes, but then fitting tires poses an issue. As
@ Inv4drZm
said, if you put a 2" body lift and suspension lifted trucks side by side the suspension lifted truck will have a slightly higher cog because it moves everything up, whereas a body lift left the heavy drive train and frame below. The disadvantage now becomes that you didn't really improve ground clearance with the body lift, the tires do that, which would be on both trucks. A suspension lift on the other hand technically gives you more ground clearance, although the rear pumpkin is still in the same spot and only goes up with the tires too. Now, to add to this, usually with a lift a person puts on bigger tires, which usually requires moving the tires out too. This effectively makes your vehicle more stable as now it has a wider footprint. Kind of like if you stand with your feet together and someone pushes you, it's hard not to lean. Spread your legs out a little and it becomes much easier to resist that force and stand up tall.
With my truck being as tall as it is, and no sway bars, and remember I don't have better springs really either, just Tacoma and FJ coils, that I still don't feel like my truck is tippy. Yes it leans, but I never feel I'm in danger. I put it through some pretty hairy shit without issue or fear of tipping. I don't rock crawl, so I can't give an experienced opinion there, but I definitely get in some off camber spots in the woods and ditches!
So back to the body lift speech, if you put a quality lift on, that uses blocks as wide or wider than the bushings, heavier hardware to support it, torque it down properly and check later I believe you aren't hurting anything. Vehicle, cog, etc. Especially with our trucks and the lack of fender openings, and that damn rear door in the fender!, unless you are limiting travel, boooo , you will hit and rub and have issues. Unless as stated, you move the rear axle back and trim the rear of the fender.
Ok, I rambled enough...
So, can I add spacers to my suspension lift to gain some extra height? Like spidertrax, or some 1.5-2 inch spacers on my front coils and rear coils? How would that affect performance. I want to gain a little more height when I move up in tire size. (I don't think my adjustable coils could be spanned to lift the front much more given that it has to be uneven due to weight on drivers side? Or it'll throw my bilsteins off? I don't really know the settings. I'll have to take it somewhere to figure that out. Can ya clear that up for me? Lol
12-13-2016, 08:26 AM
#49
Real Name: Tony
Real Name: Tony
Well the problem with putting spacers on top of Bilsteins is they are already extended travel shocks. In fact, they are longer than all the extended travel options out there if I remember correctly. When you add a spacer on top of them it allows your suspension to drop to far, killing your bushings, balljoints, tie rods and cv axles. Mall crawler could probably get away with it, but if you go offroad you'll tear it up.
12-13-2016, 11:47 AM
#50
to further that explicitly.
when you overextend the travel (past ~3.5") in front, you will bind your CV axles. NO BUENO
Couple Yotas
Iluv4xToys!
12-13-2016, 05:49 PM
#51
pppfffftt get out of here with your logic and reason.
but seriously i run a spacer on top of my BOSS coilovers that are set at 1.5" and my limit in down travel is my UCA hitting the spring. now is it the best thing for all parts involved? no definitely not, but if kept in check and maintained no issues should be had. i just now need to replace/reboot my CVs after 2years.
2004 white Limited v8 NOW WITH 35s Build Thread -toytec BOSS front set at 1.5" with 2" spacer and Metaltech LT rear -1" 4crawler BL. -Nitro 4.56 gears. -35x12.50r17 treadwright Guarddog MTs. -swaybars removed. -Ebay uniball UCAs. -RCI skids. -E-locker retrofit with 12voltguy panel and harness. -Shrockworks sliders. - body damage and the such
1989 DLX 4runner SAS BUILD
12-13-2016, 06:24 PM
#52
oh and here is some more stuff on my truck and set up, since it wasnt in my original post.
Suspension:
- Toytec BOSS coilovers set at 1.5" with a 2" lift spacer on top for the most down travel possible and to take the preload out of the coilovers.
- Ebay uniball UCAs, very happy with them for the money i spent and no issues to report.
- Metaltech Lt stage 4 with the 2" springs and icon VS 2.0 shocks. lower links set to 1" longer than stock, resulted in me having to clearance the rear of the wheel well a little more and cut about 1-1.5" of the rear bumper cover out and pound the rear pinch weld also.
Tires:
- Treadwright Guarddog MTs 35x12.50r17
very happy with these tires, only other tire that i like more are the Cooper ST Maxxs.
Brakes: very important for 35s in my opinion
- PowerStop drilled and slotted rotors with Z36 ceramic pads.
Body lift
- 1" 4Crawler aka roger brown
pictures of stuff
articulation; 38" of total articulation measured on a 20 degree ramp at 35 psi
cutting;
driver side body mount and fire wall. had to cut about 1.5" or so out of the lower 6-8" of the flare/fender and about 1" along the bottom 4" or so of the front bumper cover. ive since gone back and touch some stuff up and pounded my firewall with a bigger sledge hammer
12-13-2016, 06:46 PM
#53
Real Name: Tony
Real Name: Tony
Lol!
Bilsteins extend further than the boss though. Still have stock uca?
12-13-2016, 07:51 PM
#54
Lol!
hell no. i would never be able to get the ~10" of front suspension travel i have with stock UCAs. i have the Ebay uniballs and love them. it was written out in my post just before this and in my sig. should i buy you hooked on phonics for christmas?
and plus the UCA would be the limiting factor anyways so extended travel or not a spacer will still net roughly the same travel depending on which UCA is installed
12-13-2016, 08:04 PM
#55
Real Name: Tony
Real Name: Tony
Lol, I saw that but I was stuck in traffic and it finally started moving so I didn't get back to it.
And yes, uca would definitely be deciding factor there! Lol
12-13-2016, 08:41 PM
#56
Real Name: Jake
Real Name: Jake
I guess I can post here haha. Been running 35's for about 1.5 years now. Dont know if it will be much help to anyone since I have a lot of stuff most do not have on their trucks, but here it goes.
Tires:
Ive had both Toyo Open Country MT's and BFG KO2's in a 35x12.5r17. Rim size is 17x9 with about 4" of backspacing. Running a 1.25" spacer in the rear
Suspension:
Front: Custom +4.5" each side long travel kit
Probably about 3" higher than stock, although its hard to tell at this point
Rear: OME 895 springs with Icon Aluminum 2.0 shocks
(Soon to be leaf spring swapped with Deaver F67's and most likely 12" shackles with 12" or 14" stroke shocks, axle will be moved back about 3/4" to help with clearance)
1.5" Body lift
No bumpstop extension, front or rear
Body Mods:
Body mount chopped
Trimmed Fiberwerx front fenders
Trimmed ~1" from the rear bumper in fender well area
Front tube bumper I built
Fit:
Clears lock to lock full compression in the front
Slight rub in rear on door in fenderwell, but not much can be done about that
Other Mods:
Regeared front and rear with Yukon 4.88's, solid spacer in the rear
CVJ 4130 front axle shafts running OEM outer CV's
12-13-2016, 08:52 PM
#57
Tires:
Suspension:
1.5" Body lift
Body Mods:
Body mount chopped
Fit:
Other Mods:
I think this is the first time I've seen your truck, looks unique, I like.
12-13-2016, 09:08 PM
#58
Tires:
Suspension:
1.5" Body lift
Body Mods:
Body mount chopped
Fit:
Other Mods:
whats your travel from full bump to full drop with that custom front LT set up. i was able to milk the OEM geometry for 10"
12-13-2016, 09:39 PM
#59
Real Name: Tony
Real Name: Tony
Deavers? Nice! You better do a write up this time!
What did you do? Would love to do some tweaking. 👍
12-13-2016, 10:18 PM
#60
Real Name: Jake
Real Name: Jake
Thank you! Its unique to say the least haha.
Im getting about 13.5" right now with the axles in. Right now the limiting factor is the axles, metal to metal cycling without axles was closer to 14.5" to 15". Could probably squeeze just a bit more of bump travel now if I shorten the bump stops, although I think the limit would then become the upper uniball running out of angle.
Once I pull the trigger, I will for sure. Found some F67's local, just waiting for the guy to respond before I go purchase them, but hes super flaky so who knows how that will turn out. Might actually have to start a build thread then, been putting it off for awhile haha.
