01-25-2017, 12:01 AM
LED License Plate Lights
I replaced my license plate lights with LEDS and noticed that they flicker intermittently. Anyone else ever experience this? If so, what'd you do to Fix?
I've tried multiple types, same deal. Should all be 12v no?
[Sold] 2007 Limited - V8 4WD
Stock Rear RAS / Bilstein 5100s / OME 885 / RB 1.25 BL / BFG KO2s - 275/70R17 / SCS Ray 10 - Brushed Gold /
XenonDepot Hid Kit (lows) / Aftermarket Yellow Fogs w/ XenonDepot HIDs / DT Premium Long Tubes / Custom Y w/ 2 cats deleted / full custom exhaust pipe with magnaflow / aFe CAI / MAF Calbrator
01-25-2017, 12:05 AM
Real Name: Russell (OB #9908)
I recently had to replace one of my LED tag lights and right after, the other one started flashing intermittently. Not flickering, but flashing on/off at about a one-second interval. Not sure if that's what you're saying or not. I removed the bulb and reversed in the socket and it's been working okay since. I have no idea why that helped.
01-25-2017, 12:19 AM
Interesting. I thought flipping it would make it not work at all. I will try. I checked some other forums based on a Google search, there is a lot of resistor talk. Might just put reg. bulbs back.
01-25-2017, 07:47 AM
you know what, its the led, you get what you paid for, ive gone thru alot of the ebay leds, especially the newer ones i have tried out, 5050 smd worked the best, but lately the new stuff i got off ebay, they all decide to crap out within a few weeks. back then they work pretty long like 5 years. i tried the 20 tiny smd and they didnt last more than 1 week, bright tho. so i just gave up and purchase these https://www.theretrofitsource.com/le...ledriving.html
best thing i did, lasting pretty long and its bright enough.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
01-25-2017, 07:53 AM
Real Name: Dustin
Real Name: Dustin
Like
@ riceandpho
said above, I've had great luck with TRS, but for standard leds, I like diode dynamics much better
2016 Super White Trail (build in process)
2013 Tuxedo Black Ford Raptor SVT (built and sold)
01-25-2017, 09:27 AM
Originally Posted by Mariner
Like
@ riceandpho
i went osram leds, and phillips on another car, they work better. was thinking about switching my osram to phillips to see a difference in the spread of light.
01-25-2017, 05:09 PM
Real Name: Ed
Real Name: Ed
@ Marfy
try the stock bulbs first, if they flicker the sockets may be the issue.
I recommend the Philips 194 LEDs, they're readily available at Pep Boys and they always have online discounts, currently 15% so you're looking at $11 and change for a pair. I've tried the Sylvania/Osram Zevo 194s before, pretty identical in brightness/color but they're more expensive, $10 each.
01-25-2017, 08:08 PM
So far I have had good luck with the JDM ASTAR LEDs. Good 6000k white light and quite bright. Only problem I had was the ones I bought for my map lights are too bright so if I need it i just turn on the passenger side. I like the overall brightness if I am messing around inside at night though. Kind of thinging about buying a set of red ones though. But probably not...
2003 galactic grey mica Limited 4x4 V8 X-REAS and rear factory air suspension.
01-26-2017, 05:45 PM
I've had generic ebay LEDs in my license plate for almost 2 years.
Maybe exactly what some of the other people are saying the quality might be worse.
2003 Toyota 4Runner Sport - "Dumbo"
2018 Toyota Camry- "Sylvie"
02-07-2017, 10:22 PM
Just to close the loop on this for future searches, I bought higher quality lights and they don't flicker...makes sense.
https://www.amazon.ca/LUYED-Lumens-E...ct_top?ie=UTF8
02-08-2017, 08:54 AM
I replaced my interior, reverse, and license plate bulbs with VLEDS.com. a little on the expensive side but no issues at all.
2005 Toyota T4R Sport 4x4 V8
Bilstein 5100 struts and shocks,Halo headlights,Gibson Exhaust. 10" kicker subwoofer with Pioneer stereo, Wheels painted gunmetal, Bull Bar. Roof rails Plasti dipped. VLED interior bulbs including license plate and reverse bulbs.
Future: Thorley Headers(maybe $$)
02-08-2017, 10:54 AM
Real Name: photoshop god
Mine did that, then one died. I put the old stock bulbs in. The LEDs light the plate up to well anyway.
.: READ IT! :.
Pre-Purchase Info, Modifications, Write-Ups, Quick Links, and FAQ's
Tons of info on 4th gens for new and prospective buyers with links to the best topics.
03-23-2017, 05:03 AM
Warrenty
Most important is Warrenty.
LED lighting heads like Philips, VLEDS & TRS offer standard Warrenty. Piece of mind
03-23-2017, 08:51 AM
Real Name: Jason
Real Name: Jason
I had some LED bulbs and they were doing the same thing. They were some cheap LED bulbs I purchased about 8 years ago and they were a real blue color. I found www.superbrightleds.com and I purchased the 4100k natural white LED bulbs for $14 for the pair and they look great. They are a huge difference over the other ones I had. If you are looking for a nice and great price for the LED bulbs look at them. They are located in Missouri and have fast shipping also. I ordered mine on a Friday and they were delivered to my house on that following Monday. Check them out! They also offer a 2 year warranty and will replace them free of charge if one goes out before that time.
FJC SUSPENSION/DEBADGED/DDM TUNING 5000K HID KID/DDM 9006 YELLOW LED FOG LIGHT BULBS/YAKIMA MEGAWARRIOR BASKET/265-70-17 FALKEN WILDPEAK MT-01.
