Old 02-13-2021, 04:33 PM #31
Hunter61 Hunter61 is offline
Real Name: Steven
Hunter61 will become famous soon enough
Real Name: Steven
Originally Posted by CelticRunner View Post
Finding this thread very useful. Thanks.
Mine rusted out previously where the pipe connected to the muffler (rear side) and had it welded back on. The weld held strong but now the pipe itself is rusted through. Didn’t notice until I heard the rattle at certain RPMs again.
Anyone experience this? Do I need to replace the rest of the tail pipe as well? Or can I just replace the muffler?
I assume I need new bolts since they are thoroughly rusted. Can I reuse the rubber connectors?
Place holder for when I can figure out how to post an image*
For the tailpipe I replaced the one on my '04 sport with this one. It was a perfect fit.
Amazon.com: Walker 54617 Tail Pipe: Automotive
Hunter61 is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 05:40 PM #32
CelticRunner's Avatar
CelticRunner CelticRunner is offline
CelticRunner is on a distinguished road
Here is where the connection went. It’s completely disconnected right at the muffler side of the connecting joint, but the pipe coming out of the rear of the muffler is completely rusted through, vertically along the bottom of the pipe
[IMG][/IMG]
And another view:
[IMG][/IMG]
06 SR5, 190k miles (just breaking it in)
CelticRunner is offline   Reply With QuoteReply With Quote
Old 02-13-2021, 05:42 PM #33
Thanks for the reply. I’m having trouble opening the link. Are you saying I need to replace the whole end tailpipe as well?
Old 02-13-2021, 08:33 PM #34
Real Name: Steven
Real Name: Steven
You could do that but I didn't want to bother with cutting & rewelding. At $60 for a new one the savings would be minimal.
Old 02-13-2021, 10:45 PM #35
Thanks. I’ve watched a couple videos and I think I can handle pulling out and attaching/bolting in the new muffler. I’d like to avoid unnecessary work/costs and cutting/welding is way outside of my capabilities.
So other than the muffler and new bolts, do I need any other parts? New rubber connectors? The ones there seem to be in good enough condition.
I’ll probably grab the stainless steel muffler from Walker in a week or so, unless someone opines otherwise.
Old 02-13-2021, 11:20 PM #36
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
If the rubber hangers are not dry rotted you can reuse them, bend them to see if there's any cracking from dry rotting.
2004 Limited V8
Old 02-14-2021, 08:00 AM #37
Thanks! I’ll take a second look at them.
I guess I was a little uneasy about continuing to use the original tail pipe just do to the rust all over the connection piece. I hate what the north east (and the heavily salted roads) does to the underside of these vehicles)
Old 02-14-2021, 12:44 PM #38
Syr4RinNC's Avatar
Syr4RinNC's Avatar
It’s all just pipes - however you can connect them with a pretty good seal will work. Certainly oem design and connections will work.
My muffler rusted through at the exit point. I got an exhaust connector and a bunch of jb weld and it’s held together okay. I need to figure out a better exit because I keep crunching it on trails with a poor departure angle - so side exit or cutting or something
Old 05-25-2022, 09:01 PM #39
parsky1 parsky1 is offline
parsky1 is on a distinguished road
What size are the tailpipe bolts?
parsky1 is offline   Reply With QuoteReply With Quote
Old 05-27-2022, 01:05 PM #40
46runner's Avatar
46runner 46runner is offline
46runner has a spectacular aura about 46runner has a spectacular aura about
46runner's Avatar
I ordered the "Walker 35138 Exhaust Bolt Kit" from Amazon. Looked it up on Amazon but it did not mention the bolt size.
46runner is offline   Reply With QuoteReply With Quote
Old 04-23-2024, 11:33 PM #41
bslack88 bslack88 is offline
bslack88 is on a distinguished road
Exhaust Leak after new Muffler install
Originally Posted by 46runner View Post
Hi there, this post is super helpful. I actually just did the same thing, replaced the Muffler and Tail Pipe on my 2003 4Runner, but I am having an Exhaust leak/noise coming from where the muffler connects to the Cat pipe with the spring bolts; and for the life of me I can't figure out why! Any help would be appreciated, thank you.
bslack88 is offline   Reply With QuoteReply With Quote
Old 04-24-2024, 10:18 AM #42
4R005 4R005 is offline
4R005 is on a distinguished road
Did you use the correct gasket for this joint ? Should use gasket like Walker # 31639 , kind of like a 1/4" thick bowl shape thingy, larger diameter one end and smaller diameter at the other ( I know its a lousy description ). My 2 cents.
4R005 is offline   Reply With QuoteReply With Quote
Gasket between muffler and tail pipe nissanh 3rd gen T4Rs 4 03-30-2017 03:56 PM
Looking for muffler and tail pipe for 2007 4Runner v8 Brooklyn@3260 Free 0 04-27-2016 05:49 PM
Muffler to tail pipe gasket size or part? pb&j 3rd gen T4Rs 2 04-10-2015 02:10 PM
5th gen muffler and Lt front exhaust pipe oibdeke For Sale: T4R Items 0 11-04-2011 02:55 PM
Exhaust Pipe and Muffler Raddogz 3rd gen T4Rs 3 11-19-2007 11:58 AM
