Old 05-01-2017, 09:15 AM #1
mavrick1903's Avatar
mavrick1903 mavrick1903 is offline
mavrick1903 is on a distinguished road
Reverse signal wire?
Any input on where the best place to grab a reverse signal from up front, under the hood? I'm looking to trigger aux reverse lights.
mavrick1903 is offline   Reply With QuoteReply With Quote
Old 05-01-2017, 09:36 AM #2
backcountrymedic backcountrymedic is offline
Real Name: Jared
backcountrymedic is on a distinguished road
Real Name: Jared
I got mine from the fuse panel under the dash on the driver's side. Used it to connect to my b/u cam. I followed this thread. You could tap that same wire for your needs.
2006 Sport Edition 4X4 V6
backcountrymedic is offline   Reply With QuoteReply With Quote
Old 05-01-2017, 01:03 PM #3
SunPilot's Avatar
SunPilot SunPilot is offline
SunPilot is on a distinguished road
SunPilot's Avatar
Do you mean backup lights?
You're never lost, because no matter where you go, there you are! 07 Sport V-8, Icon front and rear lift, Icon UCA's, BFG 285/70R17's on American Outlaw rims, homemade front bumper with Rough Country fog lights and 30" embedded light bar. Homemade rear, dual swing arm, bumper. 10 gal. fuel can carrier. Homemade rock sliders and homemade roof rack with 40" light bar. 23Zero rooftop tent, ARB compressor, snorkel, dual AGM batteries . My 2007 4Runner http://www.toyota-4runner.org/4th-ge...ld-thread.html build
SunPilot is offline   Reply With QuoteReply With Quote
Old 05-01-2017, 01:27 PM #4
Yes. I'm adding the rigid 98002 reverse light kit. I'd like to have the option of reverse trigger as well as an On/Off, but don't want to use the rigid switch
Old 05-01-2017, 04:57 PM #5
SunPilot's Avatar
SunPilot's Avatar
I just put Auxbeam lights on my rear bumper. I power them from the trailer plug found under the body that is provided by Toyota. There are two connectors under there. One has a red-yellow wire I think, that is the backup light power. It is easier than fishing up into the tail light assemble and I didn't use any relay at all.. You could use the wire to power your lights right from there directly. This may not be what you are looking for if you also want to add a manual switch though. I didn't feel it was necessary for a manual switch on my rig, so I just went with this setup...clean and simple and short wire run.
Old 05-03-2017, 12:08 PM #6
iBison iBison is offline
Real Name: photoshop god
iBison is on a distinguished road
I just added some to mine. I wanted a switch under dash so I could also turn them on manually. I ran LEDs, but I used an LED anyway. I put the relay in the jack compartment and pulled a trigger off the wire going to the tail light. I think it was red and yellow.
Oh, and I ran the wire out through the drain hose in that same compartment.
.: READ IT! :.
Pre-Purchase Info, Modifications, Write-Ups, Quick Links, and FAQ's
Tons of info on 4th gens for new and prospective buyers with links to the best topics.
iBison is offline   Reply With QuoteReply With Quote
Backup Camera Reverse signal wire Smstnsn 3rd gen T4Rs 16 09-02-2020 08:24 PM
Reverse Camera Install -- Need to wire to reverse switch tyrenta 3rd gen T4Rs 2 07-14-2017 02:56 PM
Reverse sensing wire??? knotkrazy 5th gen T4Rs 6 10-17-2011 06:22 PM
Speed/Reverse Wire JMac Engines / Suspension / Wheels / Tires / Audio / Accessories 1 05-09-2008 07:16 PM
