Originally Posted by doubleA
hi all
i am planning on changing my rotors/pads soon.
I found through searching that bleeding the brakes requires a computer hookup? I ask because if I need new calipers will I be able to bleed the brakes?
that would only be needed if you somehow get air into the MC/ABS unit. if no air, you don't need a scan tool.
also, to prevent issues, when compressing the pistons into the calipers, crack the bleeder open, and let then excess fluid out there. don't force it back up the line, into the MC/ABS.
1985 pickup
: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5
: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited
: stock.
Build Thread YouTube Channel
