Old 01-15-2018, 01:20 AM #1
crashman's Avatar
crashman crashman is offline
crashman is on a distinguished road
crashman's Avatar
extended coilover problems
Hi
I am wondering if anyone else is having problems with the extended coilover in the front?
I am having problems with my cv's binding at full droop. I have Icon coil overs with total chaos upper control arms.
when you spin the front wheels they stop at a point and need to be pushed past then they spin again. this happens on both sides.
I am starting to wonder if I need limiting straps
I already lowered the truck about 1" since the front was too high
thanks
2005 4runner sport, v8, magnaflo muffler, removed resonator, de-badged Drop in K&N pioneer 3300bt, back up camera, interior led upgrade Icon 2.5" external reservoir front, Icon 2.5" CDC external reservoir metaltech long travel rear shocks and system with Addicted offroad shock relocated 1" outward to work right protected by RCI full skid plates 295/70/17 toyo open country mt http://www.toyota-4runner.org/4th-ge...read-05-a.html
2014 november truck of the month
crashman is offline   Reply With QuoteReply With Quote
Old 01-15-2018, 01:44 AM #2
Brian3676 Brian3676 is offline
Brian3676 will become famous soon enough
I have no problems. Nor do any friends who have extended travel.
Do you have OEM CV or Napa/ AutoZone type replacements?
Brian3676 is offline   Reply With QuoteReply With Quote
Old 01-15-2018, 09:07 PM #3
crashman's Avatar
crashman's Avatar
I have oem cv's
I know I haven't heard of problems and when I did a quick search I couldn't find anything on it
wondering if it could be something else?
Old 01-16-2018, 11:11 AM #4
Mike07SE's Avatar
Mike07SE Mike07SE is offline
Mike07SE will become famous soon enough
Mike07SE's Avatar
I had this problem when I did the extended travel coil overs from Radflo. I suspect that the shocks were built with too much extension in them as could be the case with yours. You got to figure all of these are being assembled by hand - there's bound to be an assembly mistake, order misread, etc.
At full droop mine would bind and would create an issue when driving. Aftermarket axles were of no help as the inner CV joints were much less tolerant of articulating. Diff drop really wasn't much of a help, and really only served as a band-aid that slightly alleviated the binding (never liked diff drop kits anyways). I ended up going to a machine shop with my OEM's and having them cut back the inner CV joint by about 1/2" and re-machining the notch grooves for the CV boot and clamps.
Adjusting the coil over lift height will not help much as the shock will still allow bind during down travel no matter what.
Here's a discussion of my issue over on the "other" forum:
Toyota 120 Platforms Forum
SOLD2007 4Runner Sport Edition V6 4X4 - Natural White - Perf: Doug Thorley Long Tube Headers | 4.56 Gears ARB Front / TrueTrac Rear Off Road: Fr: Bilstein 6112 w/1/2" Toytec Spacer / Rr: MT ICON Long Travel | JBA UCAs | VTX Rogue 17x8.5 -10 | GY Duratrac 285/70R17 | Rear Diff Breather Mod | 1" Toytec Body Lift | Custom Cut Axle Joints ICE: Auto Pumpkin 10.1" Android | 3.5" Tweeter Mod Exterior: Quad Bi-Xenon HID Retrofit
2019 4Runner Limited 4x4 - MGM - Hers | Ironman4x4 FCP's & UCA | Fuel Rebel 20x9+1 | GY Duratrac 275/60R20 | Victory 4x4 FLRR
Mike07SE is offline   Reply With QuoteReply With Quote
Old 01-16-2018, 11:59 AM #5
Inv4drZm's Avatar
Inv4drZm Inv4drZm is offline
Inv4drZm's Avatar
Originally Posted by crashman View Post
Hi
thanks
Diff drop time!
Of course it spaces your skid plate down so does it really help?
2005 4R "The last of the V8s!" - TC +2 LT. - Lockers Front & Rear - 37's - Dana 60 - Build Thread
2005 Tundra 2WD Regular Cab 4.7L - Chopped Frame - Short Bed Swap - Lowered
2019 Tundra 4WD Double Cab 5.7L My Website: Full Metal Designs
Inv4drZm is offline   Reply With QuoteReply With Quote
Old 01-18-2018, 12:58 AM #6
crashman's Avatar
crashman's Avatar
I had a friend notch the oem cv's and it helped a little bit. I was worried that I bent the knuckle and that did it but it sounds like your solution may be the fix
can you tell me where you got them cut down? I wonder if I could have them do mine or let me know what to tell a shop here
Old 01-18-2018, 01:00 AM #7
crashman's Avatar
crashman's Avatar
Originally Posted by Inv4drZm View Post
Diff drop time!
Thanks I did the diff drop and I have RCI skids they work with the drop so I'm good
Old 01-18-2018, 09:08 AM #8
Inv4drZm's Avatar
Inv4drZm's Avatar
I didn't read the reply above that said they had the same problem even with a diff drop. A limit strap could be a possibility then.
Old 01-18-2018, 10:50 AM #9
crashman's Avatar
crashman's Avatar
I am considering limiting straps however I don’t know if it will affect off road performance 😳🤔😳
Old 01-18-2018, 03:12 PM #10
Mike07SE's Avatar
Mike07SE's Avatar
I had mine done at this shop somewhat local to me:
JB's Auto Machine
I honestly think this would be the way to go versus using limiting straps (unless a long travel suspension were being used). I think this would still end up being cheaper.
Old 02-14-2018, 03:41 PM #11
SoSoRunner's Avatar
SoSoRunner SoSoRunner is offline
Real Name: SoSo
SoSoRunner is on a distinguished road
SoSoRunner's Avatar
Real Name: SoSo
Did the OP ever come up with a solution? I just installed my front icon extended coilovers and I think I'm having the same problem. I don't have a diff drop kit so I should probably get one and see if it fixes it.
2006 Salsa Red V6 Sport 4WD:
Outgear Solutions full length roof rack | Pelfreybilt front bumper | Smittybilt X20 wireless winch | Factor 55 Prolink | Demello sliders | FN Wheels 5 Star 17x8.5 -6 offset | Cooper STT Pro 285/70/17 | Energy Suspension LCA bushings | JBA UCA | Icon 2.5 RR front coilover (extended travel) | MetalTech 4x4 Long Travel medium rear springs| MetalTech Long Travel Icon 2.5 RR cdcv rear shocks | Resz Fab rear links & lateral rod | Icon rear lower shin guards
SoSoRunner is offline   Reply With QuoteReply With Quote
SAW 2.5 coilover cmj 3rd gen T4Rs 7 06-19-2017 10:08 AM
Top of coilover seems off SteelStacks 5th gen T4Rs 3 05-30-2017 12:45 PM
FS: 4th GEN New ICON Extended Travel Front Coilover Shock Kit, $1100 Pittsburgh, PA 2008se4runner For Sale: Suspension/Wheels/Tires 23 02-16-2017 02:39 PM
FS 3rd Gen Icon Extended Travel Coilover Set $450 NC jij0226 For Sale: Suspension/Wheels/Tires 1 03-03-2016 06:50 PM
need coilover help hoss55 3rd gen T4Rs 2 01-20-2013 01:32 PM
