Paint
jsimon
Does anyone have an idea of what could be causing spots like this? I have two so far. The one in the picture is above the right rear tire and the other is on/around the fuel door. It has never had any bodywork and I keep it pretty clean. Toyota told me they won't fix it because it's out of warrenty (had it for just over 3 years and 120K). In case the pic doesn't work, heres a link:
http://i14.tinypic.com/4hbv75y.jpg
Thanks for the help.
<a href="http://tinypic.com" target="_blank"><img src="http://i14.tinypic.com/4hbv75y.jpg" border="0" alt="Image and video hosting by TinyPic"></a>
That looks like oxidation to me. It could be caused by a number of things such as how well the paint is protected from the elements with the use of a wax or a sealant and how much sun exposure it gets.
Check out this page. Scroll down a little less than half way and you'll find a section on Oxidation.
You can usually take care of it by polishing it out with a mild abrasive.
From my experience in auto refinishing, I'll tell you one thing, paint is a riddle sometimes. The answer is hidden within. I saw a paint problem on VW's painted a similar color as your truck. The clear would become milky and then peel off. VW paid to refinish the affected vehicles regardless of mileage.
At first glance, it looks like someone took a dual action sander with 1000 grit and sanded down the clearcoat. As paint is sanded, each layer becomes exposed and each layer has different characteristics. When the clear is sanded and the basecoat exposed, that ring is the first thing you'll see. Sand further and the basecoat quickly yields to a primer layer. For 4R's I beleive the primer is a light grey or white.
That whiteish "ring" is a strong indicator of reparwork.
I know you said that you've never had any repair work done, but possibly a repair was made, most likely at the port of entry. It looks like a spot repair showing signs of age. However this is just a guess because I'd really need to see it in person to tell exactly. A spot repair is used to repair a minor blemish on the surface, like a small scratch. To make a long description short, the inner-most area is sprayed with basecoat (color) and a slightly larger area sprayed with clear. However , the entire panel is not refinished, instead the reparied area is then polished to blend in to the underlying area. This type of repair is not going to hold up over time especially in areas of the country with lots of sunlight.
Has it ever been polished with a rotary buffer? It could have worn down the clear in that area and the sun did the rest.
Can you describe what is happening to the surface, it looks like the clear has lost is gloss. Is this correct? Any change in texture? Can that ring be felt by rubbing your hand over it?
Take it to a local body shop, not a big, high production shop, but a decent shop where you can talk to the guys without all the hype of fancy waiting rooms and damage appraisers who dont know anything about repairs. Good luck.
Holy cow, that picture must make it look worse than it is... That looks really bad... Toyota has to help you out on that one, that looks like someone took a sander to the paint...
I also see you have water spots on your rear windows too, I have them on my rear windows and I can not get them off...
Good luck with a fix for that paint issue...
That looks like something dripped on it... There are splatter marks around the ring which are definitely not connected to the main circle... Did you park under anything that dripped something on the car?
What color is that? I can't tell if it's silver or white.
I was under the impression that the non-metallics (including white) did not have clearcoats.
