Old 07-30-2018, 06:41 PM #1
swapmeet's Avatar
swapmeet swapmeet is offline
swapmeet is on a distinguished road
swapmeet's Avatar
Driveshaft vibration with lift?
Hello, I've tried searching in a variety of ways and can't find an answer. So hopefully this isn't a wasted new post.
Decelerating/ braking creates a vibration in the Driveshaft or U-joint. My truck is a 07 4x4 V8 lifted 3.5+" on Radflo 2.5 shocks, which are very soft. Because of the softness, I get a lot of nose dive when braking, so I think it exacerbates the issue.
I've always had a minor vibration when accelerating hard, and still do. This feels similar, but much more exaggerated.
My thought is that its either pinion angle or the slip yolk. I remember people saying it helped to get a driveshaft spacer if you lifted your truck because of the slip yolk. Is this still a thing?
I'm looking at adjustable arms for the rear, but I don't want to pull the trigger until i'm sure it'll resolve my problem.
In case anyone feels compelled to ask, its not the brakes. 100% sure.
Thanks
Barry White 2007 SR5 V8 Black, Toytec Boss, 17x8 Level 8 MK6, 265/70 Terra Grapplers, Mortar Can Storage, CB, LED's scattered about, Ditch Lights, 4x Sliders, RCI full skid package Flowmaster 50 SUV, XD HIDs, lots of trail rash.
swapmeet is offline   Reply With QuoteReply With Quote
Old 07-30-2018, 07:28 PM #2
TowMeOut's Avatar
TowMeOut TowMeOut is offline
TowMeOut is on a distinguished road
TowMeOut's Avatar
Triple Drilled Toyota Driveline Driveshaft Spacers by Low Range Off Road, .75", 1.0", 1.25" (TDT-DS)
I'm not sure what 3.5" of lift equates to but this would be a cheap way to at least troubleshoot. The 4th gen driveshaft is known to have issues already (famous driveline "clunk"). I'd bet lifting just makes the problem worse. Before you start tinkering with the suspension maybe give the spacer a try. I'm assuming these go on the differential end but maybe someone else will chime in.
06 Sport 4x4
185K and counting
Bilsteins, FJ/Tacoma springs
Nitto Terra Grapplers
TowMeOut is offline   Reply With QuoteReply With Quote
Old 07-30-2018, 07:35 PM #3
swapmeet's Avatar
swapmeet's Avatar
Thanks for the suggestion. It looks like those won't fit my truck (doesn't fit 2005+ 4runner)
My understanding is that the lift changes the pinion angle as well as increasing the separation on the yolk because the distance from the center diff to the rear axle has increased.
I'm not against the spacers, just want to make sure i'm taking the right steps, not just throwing parts at a problem that may be familiar to others.
Old 07-30-2018, 07:55 PM #4
TowMeOut's Avatar
TowMeOut's Avatar
Time to break out the ruler... Maybe another option:
4Crawler Offroad Products - Driveshaft Spacers for Toyota and Ford
06 Sport 4x4
185K and counting
Old 07-31-2018, 10:49 AM #5
swapmeet's Avatar
swapmeet's Avatar
Bump
Old 07-31-2018, 06:27 PM #6
swapmeet's Avatar
swapmeet's Avatar
bump
Old 07-31-2018, 09:23 PM #7
mjotrainbrain mjotrainbrain is offline
Real Name: Matthew
mjotrainbrain is on a distinguished road
Real Name: Matthew
I don't have specific answers for ya, but maybe you'll have to look into custom links to correct that pinion angle, and maybe a custom driveshaft to fix any length issues (or perhaps a spacer would do the job just fine, idk).
Instagram: @projectrustyrunner
2003 V8 | Titanium Silver | 180k miles | Uniden CB | Bilstein 5100 Front @1.75" | Extended rear diff breather | American Racing 16" wheels | Full interior LED conversion | Curt roofrack w/ extension
mjotrainbrain is offline   Reply With QuoteReply With Quote
Old 07-31-2018, 09:55 PM #8
Johns06yota's Avatar
Johns06yota Johns06yota is offline
Real Name: John Iannacone
Johns06yota has a spectacular aura about Johns06yota has a spectacular aura about
Thanks
Are you completely sure the vibration is in the driveshaft because I was getting a vibration on deceleration and coasting from about 40 down to 20 but went away in 4wd (indicates bad needle bearing) Maybe this helps
Johns06yota is offline   Reply With QuoteReply With Quote
Old 08-01-2018, 11:05 AM #9
swapmeet's Avatar
swapmeet's Avatar
I'm always in 4wd... (V8, fulltime 4Hi) I'm not sure I could get to 40 in 4low.
Old 08-01-2018, 05:12 PM #10
Oh okay I didnt realize yours was the full time 4wd model. In that case I think those used a different bearing design so disregard my last comment haha
Old 08-02-2018, 04:54 PM #11
swapmeet's Avatar
swapmeet's Avatar
bump
Old 08-02-2018, 06:59 PM #12
Spriter's Avatar
Spriter Spriter is offline
Spriter is on a distinguished road
Spriter's Avatar
In my limited experience i found this to be the drive shaft having some sort of problem, or that the U joint is going bad.
Spriter is offline   Reply With QuoteReply With Quote
Old 03-05-2019, 11:56 AM #13
swapmeet's Avatar
swapmeet's Avatar
Just to button this thread up, I had a bad U-joint in the driveshaft.
Had it rebuilt by a local shop and its good to go.
Interestingly, they suggested that put new/ more grease in the U-joints every 6k miles.
I typically put more grease in every never-thousand miles.
Old 03-05-2019, 12:34 PM #14
Formidable's Avatar
Formidable Formidable is offline
Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light Formidable is a glorious beacon of light
Formidable's Avatar
Thank you for following up on this. I am about to lift my 08 V8.
2002 Thundercloud | TRD Supercharger | TRD Headers | URD 2.2 Pulley | Toytec | Addicted Offroad | 4xinnovations | Icon | SCS | BRIDE
BUILD THREAD
Formidable is offline   Reply With QuoteReply With Quote
Old 03-05-2019, 06:29 PM #15
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Fairly sure U-joints are just a replace type thing after they wear out... not rebuildable.
Grease the driveline zerks every 5k-6k/oil change (6 zerks on the 4x4, 2 slip joints and 4 U-joints), and rotate the tires, your 4runner will thank you.
I had a 1985 Toy pickup on 35's... it was hard on the drive line stuff i guess.
The front U-joint on the rear axle failed/exploded.
Was in a school zone so i was going slow...good thing!
BAM! Clunk! Clunk! Clunk! ...pull over.
Put in in 4x4 and tied the axle up then drove a couple blocks to a friends house.
It put a small hole in the floor bottom where the axle bounced up off the pavement and slammed the truck.
This was way back in the late 80's.
Driveshaft vibration with lift?-85-pu-jpg
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Vibration when braking benjamin247 3rd gen T4Rs 20 12-01-2022 06:01 PM
Scary vibration at 60+ mph and while braking Tundra9er 3rd gen T4Rs 14 04-28-2016 02:48 PM
vibration when braking brettmc 4th Gen T4Rs 15 06-11-2011 06:39 PM
Engine/Driveshaft - Vibration/Noise? elcidsurfer Classic T4Rs 6 12-19-2010 10:15 AM
Bad Vibration/Noise on Braking USSEnterprise 3rd gen T4Rs 4 12-27-2009 03:16 AM
