08-20-2019, 05:18 PM
#17
Originally Posted by earthrealm
I'll tell you how well made they are in a week when I get them and mount them. I love the DIY approach and was going down that path, but I already have a laundry list of things to do on my 4runner, so the $25 extra with clips seems to be worth my time, unless they're junk. But the seller has an excellent rating, so we'll see.
08-22-2019, 08:36 PM
#18
yeah, that would be nice, as am sitting on the fence about them too.
waiting
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto...... sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
08-22-2019, 10:49 PM
#19
I added a bit more material to a lot of the corners to give them a little more strength.[IMG] [/IMG]
07 Limited V8 Titanium Metallic
Bilstein 5100s x4, Fronts set on 0 with OME 885s, Sway-A-Way 1.5 rear coils, JBA UCAs, '12 Trail wheels, Cooper AT3s 265/70/17, Mobil1 0W40, Amsoil Severe Gear 75W90 and SS ATF.
(Previous truck: 1993 Toyota DLX, V6, 4x4, Xcab, 5 speed, Pewter Pearl - owned from day 1)
http://www.toyota-4runner.org/4th-ge...ml#post2069269
08-26-2019, 08:51 AM
#20
Ebay kit feedback
So I rec'd and installed the Ebay complete splash guard kit. It was $39. The shipper had them out very quickly.
Fit is perfect and the material thickness is slightly thicker than OEM, so feel like they'll last a long time.
01-20-2020, 05:13 AM
#21
Real Name: Seth
Real Name: Seth
Old thread, I know, but I'll be doing this and adding my body lift height to the trace-out dimensions. I saw the thread on TW for the full-coverage one and will be giving that a shot!
2006 Shadow Mica SR5 v6 1" BL, Fox Racing UCA's, RC 3" N3 Lift, Rock Trix RT110 -12 Wheels, 315/70R17 Goodyear Territory MT, Tacoma Front Bumper, 5th Gen 4R Tire Carrier, Big Lion LED's
01-20-2020, 09:30 AM
#22
Real Name: Todd
Real Name: Todd
Link to the thread on TW for the extra coverage ones?
01-22-2020, 05:03 PM
#23
Real Name: Seth
Real Name: Seth
Here you go!
Upgraded Inner fender splash shields (Update 2nd run) | Tacoma World
09-20-2020, 05:07 PM
#24
Save the time, great manufacturer in Colorado...Yota Liners
Yota Liners over at www.yotaliners.com is the answer to this. Homemade seals never last, just like the ones from the dealer. I have bought from them for my 4Runner and previously my Tundra and wife's Tacoma. They are a family parts business here in Colorado where I live, make them out of a patented neoprene-like space-age material resistant to everything, and include instructions and the clips which are really expensive and hard to track down the right ones even from the dealer. Their customer service is great. Ordered the wrong set for the Tacoma once, and they quickly swapped them out. Would highly recommend if you want to save yourself the time and re-work in probably less than a year. Just my 2 cents.
03-01-2021, 01:52 PM
#25
Looks greta, will be trying for myself soon
03-01-2021, 01:56 PM
#26
Good idea, What about garage floor mat?
12-14-2021, 05:03 PM
#27
Originally Posted by BackOff
I just did this too, one was flapping in the wind.
Used some clear plastic to make the template.
1/16" water barrier membrane for tile shower floor...leftover from a shower repair. Its like inner-tube material. Super tough stuff.
Though I would try the extra coverage version floating around over on TW.
How are these holding up? I was looking for something thicker than 1/16 but maybe its not necessary. Also, did the tacomaworld template fit exactly, or did you modify it? Thanks
11-28-2022, 08:59 AM
#28
So when I bought my used 05’ 4runner the previous owner had torn these out probably when he did the lift and cuts for the 33” tires that are on there.. so I’m curious how important is it to get these back on? I’m up in the NY salt belt and I’ve got a fluid film coating done already.
Silver 05’ 4Runner V8 4.7L Sport, Bilstein 5100 shocks, Dobinsons C59-314B front springs, Dobinsons Aluminum Billet UCA’s, Superpro offset LCA’s, OCD sway bar endlinks, Toytec Superflex RCC2.0-P rear springs, Cooper Discoverer A/T 3 285/70/17 tires, SCS Blaze 10 Wheels with -10mm offset, and lots of plans for future mods…
11-28-2022, 09:47 AM
#29
Real Name: Rich
Real Name: Rich
Dealership tore mine off sometime in the past, probably when I was there for the 90K timing belt replacement. This past summer I bought new ones and installed them. I think they reduce noise as well as protect the engine from getting splashed with water and causing it to stall. It was an easy replacement, maybe 5 minutes per tire after the tire was removed. I got mine off Amazon.
Amazon.com: Set of Four Splash Shields with Clips for 2003-2009 4Runner (Fender Liners, Aprons, Shields, Splash Guards, Skirts, Guards, Seals, Splash Seals) C : Automotive
Rich
2004 V8 4Runner 140K+ miles
Kentucky
11-28-2022, 02:26 PM
#30
Real Name: Russell (OB #9908)
I realized I forgot to update this thread when I lost one of my DIY splash guards. Instead of cutting a new one, I decided to get the set made by Rad Rubber Designs. It's pricey for the product but the quality is top notch and they include a set of fasteners.
