Old 03-06-2019, 03:22 PM #1
Leveling spacers...
ive read most the threads & stickies on lifting/leveling 4th gen 4runners & got most the info i needed, like the lift is ~2x the spacer thickness. & what shocks/struts/springs will fit the 4th gen.
i just bought a pair of used spacers that are 1" thick & made of amuminum & was curious of a few things before i install them. this is for an 08 sport with xreas that seems ok for now, so cheap spacers are all thats needed before i change out the xreas down the road aways.
1> what is the normal lift people are doing to level the front? will 2" (1" spacer) be too much of a lift & make the nose too high? i dont plan on or need to lift the rear, just want to level or improve the stock rake.
2> is there any issues or ride comfort problems with using aluminum spacers vs poly? are there any rubber isolators that should be used for these alum spacers? or just install & go?
3> will a ~2" lift require any other suspension mods? or change the alignment enough to need it re-aligned? tires on it now are crappy so doesnt matter for the short term, but will be getting some new 265/70/17 in the near future.
any pics of just a basic 1-2" front spacer lift?
thanks!
Old 03-06-2019, 06:14 PM #2
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
You'll definitely need an alignment.
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 03-07-2019, 12:26 AM #3
gaber6 gaber6 is offline
gaber6 has a spectacular aura about gaber6 has a spectacular aura about
And possibly LCA bolts.
gaber6 is offline   Reply With QuoteReply With Quote
Old 03-07-2019, 11:57 AM #4
thanks for the alignment info.
any other input on questions 1 & 2? & pics?
Old 03-07-2019, 12:33 PM #5
sumday sumday is offline
sumday is on a distinguished road
if your lca bolts are seized your gonna need more than just bolts and prolly control arms. verify bolts are not seized before you start.
sumday is offline   Reply With QuoteReply With Quote
Old 03-07-2019, 01:50 PM #6
Geecole Geecole is offline
Geecole is on a distinguished road
Recent experience
I just did this yesterday on the same vehicle...first, I used a 3/4" spacer to get 1.5" of lift....perfect. Any more would have been too much.
Second, unless you're good down there, be really careful. The spacers can go in with the XREAS but you have to rotate the strut 180 degrees on re-install and run the risk of breaking the XREAS lines...which will wreck the entire system.
I had my mechanic do it, and he actually did split the line and wrecked the whol thing. I ended up going conventional.
Yes, you'll need an alignment, and mine also has 265/70 ATs.
Attached a picture....see if it's what you think you're looking for!
Geecole is offline   Reply With QuoteReply With Quote
Old 03-07-2019, 03:30 PM #7
thanks for the pic, looks great.
can you elaborate on the rotate the strut 180? why does it need to be rotated?
Old 03-07-2019, 03:56 PM #8
prolly cause the spacer bolts to existing mount and spacer has studs 180 degrees apart
daystar has stud extenders and doesnt have to be rotated
Old 03-08-2019, 12:54 PM #9
thanks, good to know these little detaiils before installing.
here are pics of the 1" spacers i bought, they dont have any markings or numbers on them, anyone recognize the brand?
i read a thread about the daystars & extended studs, do these look like they require extended studs? looks like a recessed area that maybe doesnt need extenders?? the seller said they were complete & as removed from the vehicle so hes saying they dont need anything extra & will install as is.
Leveling spacers...-img_8599-jpg
Old 03-08-2019, 01:05 PM #10
those spacers bolt on over the existing strut mount studs. then you have to rotate 180 so you can bolt to upper strut mount
Old 03-09-2019, 12:37 PM #11
still confused about the rotate 180 thing... i havent looked at the suspension yet as the truck isnt on the road yet untill some other issues are addressed. im very mechanically inclined, have done a lot of work on older muscle cars including numerous full frame off restorations, suspension/engine & paint work, so doing the job isnt an issue, just not familiar with it yet.
i have the factory service manual & will look at videos of the install... but can someone explain why the shocks need to be rotated 180? is the rotation just to get the shock back in place then put back to normal position? or will they be installed 180 & stay that way? for XREAS that seems like an issue leaving it rotated & the lines twisted.
just trying to understand the reason for 180 rotation & if its just to get the shock back in or if thats how it will be positioned for good. if its for good, i think i may just go the 5100 route or FJ springs for the slight front lift i want to level it out some.
Old 03-11-2019, 11:28 AM #12
so sounds like the strut has to be rotated 180 when mounted back in, that seems like a problem for the XREAS. i will look for the daystars or commit to doing 5100's. was hoping i could use these spacers with the xreas that still seems to function ok.
thanks for the input
Old 03-12-2019, 11:48 AM #13
I've heard it can work..
I've heard it can work but is tricky. I think I've seen a couple of videos of the install working, too, but even though I'm decently handy, that unless I had the right tools, it wasn't worth the potential hassle for me.
Good luck on yours; for the cost, the Billsteins might make as much sense as anything else.
Old 03-13-2019, 02:54 PM #14
4by4runr's Avatar
4by4runr 4by4runr is offline
4by4runr is on a distinguished road
4by4runr's Avatar
Mfr
I think those are the same ones I have. They were purchased from a shop on eBay.
Here's similar:
StreetRays 2" Front Leveling Spacer Lift Kit 95-04 Toyota Tacoma 4Runner 4WD 2WD | eBay
2004 V8 4x4 sport in Galactic Grey • Xreas delete • 248k • BFG KO2 265/70/17 • Custom Arizona sun two tone paint • 2" leveling kit
4by4runr is offline   Reply With QuoteReply With Quote
Old 03-13-2019, 03:29 PM #15
Here's similar:
the ones linked say are for 95-02 4runner & 95-04 tacoma. the ones i have came off a 13 tacoma & the seller said they should fit a 4th gen 03-09 4runner too.
did you install yours with the xreas or did you delete it before installing them?
change , lift , spacer , spacers , xreas
Leveling kit (spacers) - tackle install myself? Fired Up 5th gen T4Rs 8 12-19-2014 03:15 PM
Leveling spacers - Poly vs. Billet SurfToy 4th Gen T4Rs 10 05-21-2010 07:26 PM
FS: Leveling spacers for \'03 & up 4Runner Even Steven Classifieds - buy & sell (no commercial ads please) 1 05-24-2007 02:57 PM
