Old 06-04-2019, 01:08 PM #1
orangeblast22 orangeblast22 is offline
orangeblast22 is on a distinguished road
Help, I'm stuck in 4WD
My 2006 Sports Edition V6 is stuck in 4WD. I recently/accidentally engaged the center differential function (the orange 4WD icon with the X in the middle appeared on my dash). Once I got myself out of that, I noticed my 4WD would not switch to 2WD no matter what I do to the knob.
Any ideas on how to fix this?
2006 v6 4x4 Sports Edition in Titanium Silver
orangeblast22 is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 01:43 PM #2
lightfreak lightfreak is offline
lightfreak will become famous soon enough lightfreak will become famous soon enough
Put it neutral then shift the knob to 2WD , then roll it slowly back and forth between D and reverse. Could take a while
2004 4Runner Limited V6 4WD ***SOLD***
385,000 Km
Titanium Metallic
Vehicles: '21 Highlander XSE V6 AWD | '21 Acura RDX SH-AWD Tech | '03 Honda CBR600F4i
lightfreak is offline   Reply With QuoteReply With Quote
Old 06-04-2019, 01:49 PM #3
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
If I had issues switching between 2WD and 4WD, I would be more than happy if it failed in AWD mode if the center diff lock still worked.
Even if it never switches back, its perfectly fine to leave it as it is.
With the center unlocked, it's basically in AWD mode and perfectly fine to drive on roads.
Old 06-04-2019, 11:47 PM #4
grave's Avatar
grave grave is offline
grave has a spectacular aura about grave has a spectacular aura about
grave's Avatar
... up to 55 miles per hour. don't do this.
read the paper that is on your driver's side sun visor and keep trying to cycle it out of 4WD (it's not AWD, ever).
pet every dog
grave is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 12:26 AM #5
simple's Avatar
simple simple is offline
simple will become famous soon enough
simple's Avatar
Thats false, brother. The 4th gen, with the center dif unlocked is absolutely AWD. Thats one big reason I like the 4th gen's 4wd system over the 5th gens; a torsen center diff! Generally speaking you could go any speed in 4wd in the 4th gen with the center dif unlocked, and do any type of driving on any type of surface.
The 5th gen, you can technically drive any speed as well, but you're limited to turns at about 30-35+mph. Any turns slower than that misalign the front and rear wheels enough that it causes binding in the diffs due to differing wheel speeds.
I learned the hard way that part time 4wd in the 5th gen doesn't mean you can switch between 2 and 4hi whenever like I was used to in the 4th gen. And that 55mph number you're thinking of is engaging the 4wd system, and i think it's 60mph. If you try to engage it above 60, the system just beeps at you. You slow to 59, engage it, and then continue on your merry way.
To OP, yeah, try shifting into neutral and tapping the brake a few times, or rolling forward a bit. I'd even take it on a drive and leave the switch in 2hi and wait for it to switch. I once couldn't get 4lo to engage and I kept rapidly swtiching it between 4hi and lo, and then the transfer case finally broke free and engaged.
Air 4rceRunner One, 04 Sr5
simple is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 12:40 AM #6
Doozi's Avatar
Doozi Doozi is offline
Doozi will become famous soon enough
Doozi's Avatar
What “simple” said! You just have to shift between H2 and H4 at speeds below 60mph.
Also, I believe that the 5th Gen Limiteds have the Torsen diff.
Doozi's 2006 Sport Edition V6 4WD - Titanium Metallic - purchased 09-13-10
Dobinson's F: C59-302/GS59-220, R: C59-677V/GS59-575 / LR UCA's / Medic links / LT285/70R17 DuraTracs on Countersteer Type-X wheels / WeatherTech DigitalFits and Window Visors / Rear Diff Breather Mod / J.A.'s Fog Light Mod / Centric Premium rotors w/ Akebono Pro-Act Ultra Premium pads / LED interior lights / HIDs (4500k lows) / Man-A-Fre engine+tranny skids / RCI MetalWorks T-case skid / B.A.M.F LCA skids / CBI front/rear, Sherpa Equipment Company roof rack, WKOR sliders welded on, Panhard Correction Kit... Lovin' it!
Doozi is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 02:02 AM #7
ac1617 ac1617 is offline
ac1617 will become famous soon enough ac1617 will become famous soon enough
This is correct. I don't think many users understand the difference between the transfer cases between different generations of 4runners and the models within that generation. 4th gens all have torsens with the V6 being able to select 2wd and 4wd unlocked. If OP is stuck in 4wd unlocked there is no speed limit in which he can drive in this mode.
ac1617 is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 09:00 AM #8
bjax4x4's Avatar
bjax4x4 bjax4x4 is offline
bjax4x4 is on a distinguished road
bjax4x4's Avatar
4wd binding
Did you have any issues with vibration or drive shaft issues after the 4wd binded?
bjax4x4 is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 09:32 AM #9
earthrealm earthrealm is offline
earthrealm will become famous soon enough earthrealm will become famous soon enough
if you are really stuck in 4wd only[green 4wd sign on dash], and you try to remove it from 4wd by turning the knob to 2wd, then the amber and orange signs will be blinking on your dash,
there are several methods to force it to disengage.
1. drive on uneven surface/road, about 200 700ft, should knock it loose
2. try disengaging why you are making a slight turn
3. go to a dirt road, lock the differential, then unlock, then try switching back to 2wd.
4. try engaging the neutral gear while attempting to switch into 2wd
5. put the car in reverse and try disengaging
6. last last option, get the wheels off the ground, use a mallet on the 4wd actuator, try in neutral and drive
2005 v6, galactic grey 4wd auto : pioneer avh 4400bh dvd hu, pyle reverse cam
2003 rav4 titanuim silver 4wd auto......sold
2004 rav4 titanuim silver 4wd auto : pionneer avhx 5500bt hu, pyle reverse cam
earthrealm is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 12:23 PM #10
Bumbo's Avatar
Bumbo's Avatar
That speed limit only has to do with mode switching (2WD to 4), once you are in 4 you are good to operate as normal.
It's 100% AWD (mechanical limited slip like an AWD Audi) with the center diff unlocked as all 4th gen 4Runners use a Torsen center diff.
Old 06-05-2019, 12:39 PM #11
Bumbo's Avatar
Bumbo's Avatar
Yup, the 5th Gen Limited was the only trim level to keep the Torsen, which is the same as the GX and Land Cruiser.
The V6 4th gen does have the ability to drive in 2WD in addition to the rest of the other modes, which is pretty cool and unique. The 4th really is my favorite generation of 4Runner.
Old 06-05-2019, 02:19 PM #12
m85476585 m85476585 is offline
Real Name: Matt
m85476585 will become famous soon enough
Real Name: Matt
Mine has been "stuck" in 4WD from the factory. The V8 has no 2WD option for whatever reason. There's no downside, but you do probably want to get it unstuck in case you want to use the low range sometime. the 4WD V6 has the same system, but with an ADD (Automatic Differential Disconnect) in the front.
A few things to try:
  • Drive around for a while to make sure everything is warmed up
  • Try shifting with the center diff lock on or off, while driving below 55mph
  • Come to a stop, and with your foot on the brake shift to neutral then try to shift to 2WD. If it doesn't shift right away, try letting your foot off the brake to roll slightly
  • As someone else mentioned, try switching while driving slowly and turning slightly right or left
  • Try reversing a little, then doing the procedure to switch at a stop in neutral
  • If all the fails, some people have had success loosening the bolts on the actuator cover and tapping on it (the cover?) with a wrench
  • You could try to go to 4WD Low then back to Hi, but if it gets stuck inLlow that would be bad
2007 V8 Limited 4WD
m85476585 is offline   Reply With QuoteReply With Quote
Old 06-05-2019, 05:07 PM #13
SummitRunner SummitRunner is offline
SummitRunner is on a distinguished road
This
2004 4Runner Limited, v8, 4WD
Overlanding Travel App for iPhone
"Great things are done when men and mountains meet." -William Blake
SummitRunner is offline   Reply With QuoteReply With Quote
Old 06-09-2019, 11:51 AM #14
Annnndddd.... I'm still stuck.
Last night I pulled my battery to finish up some work on my aftermarket HU install. Started her back up only to find the green 4WD icon on, an orange 4WD icon with an X in the middle, and my VSC off.
I read online... Followed instructions in the driver's side sun shade... Drove around my neighborhood an hour...drove back and forth in my drive way like a mad man for an hour...and nothing.
Turned it on this morning, still there.
Feels scary to drive because it's so tight in the turns. I don't feel safe, but it's my daily driver and I have to resolve this.
I also don't understand, why does it do this when I pull the battery? I've pulled the battery several times before but it's doing this now... Don't get it.
Old 06-09-2019, 11:59 AM #15
Swipter Swipter is offline
Swipter will become famous soon enough Swipter will become famous soon enough
Well, the advantage to this is, after going back and forth in the driveway that long, if the neighbors didn't think you were crazy, now they know you are.
Life is fun.
Swipter is offline   Reply With QuoteReply With Quote
2wd , 4wd , noticed , stuck , switch
Stuck in 4WD Hi Time4Hockey 4th Gen T4Rs 14 12-27-2021 01:34 AM
Key Off, Stuck in Acc Kyogie 3rd gen T4Rs 5 04-07-2017 08:25 AM
Cone washers stuck stuck stuck 4eigner 3rd gen T4Rs 14 04-03-2015 03:49 AM
rear hatch stuck is stuck tried everything.. tristentrd28 3rd gen T4Rs 4 11-09-2014 12:45 PM
How to get un-stuck smackitsakic 4th Gen T4Rs 7 12-24-2009 05:48 AM
