Old 06-11-2019, 05:21 PM #1
tdubz tdubz is offline
tdubz is on a distinguished road
Alignment numbers after 2.5/1.5". Do they look OK?
I just installed my Dobinsons 2.5/1.5" lift, Wildpeak A/T3W 275 tires, and followed it up with an alignment. I have stock UCAs. Full details below, if needed.
I am asking because when driving, it seems like the 4Runner doesn't seem to want to stay in the lane. It is not noticeably pulling one way or another, but it seems like it is more difficult to keep it tracking straight. Most of the driving so far has been on highway or multi-lane roads. When I look at the 4Runner parked on a flat surface + steering straight--it appears the passengers side wheel's camber is angled a bit more than the drivers, but the numbers don't seem to reflect this.
Wondering if you guys would give advice on the resulting numbers:
The guys at the shop seemed pretty reasonable and were recommended by the local America's tires.
Note: This is also my first experience with AT tires on my 4Runner. So I may also just be overly sensitive, and need to get used to them.
Build:
Front : Dobinsons C59-302 + GS59-221
Rear : Dobinsons C59-505 + GS59-705
Tires : Falken Wildpeak A/T3W 275/70/R17
Wheels : 2018 4Runner SR5 "Snowflake" 17x7 (15mm bs)
4th Gen 4WD 4.0L
Dobinsons | JBA | Wildpeaks | RCI
tdubz is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 05:58 PM #2
Cloud9's Avatar
Cloud9 Cloud9 is offline
Cloud9 is on a distinguished road
Cloud9's Avatar
You also have to remember it matters WHICH side of the road you are on. Roads are tilted for the water to run off on an angle. Try drive on the same road and then turn around and drive on the other side of that same road. Each way will be tilted the opposite way.
Best way to do this is maybe on the highway where you know it's very FLAT>
2019 TRD pro - S&B intake, Gibson Side Dual Catback black ceramic tips, Sprint Booster. lift coming
2006 4Runner V8 - Doug Thorley Headers/Hi-flow Magnaflow Cats, Gibson Catback Dual Exahust, Volant Air Intake, Sprint Booster, All from Burtman Industries
1996 Limited 3RD Gen, still going strong!
Cloud9 is offline   Reply With QuoteReply With Quote
Old 06-11-2019, 09:21 PM #3
BackOff's Avatar
BackOff BackOff is offline
Real Name: Derek
BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough BackOff is a jewel in the rough
BackOff's Avatar
Real Name: Derek
Your caster is on the low side.
More caster help the t4r go straight down the road. Less wandering.
3.5* is nice.
This is why you might need UCAs.
2004 T4R 4x4 SR5 v6
Some modifications.
Black-N-Blue
BackOff is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 08:02 AM #4
blackoutt's Avatar
blackoutt blackoutt is offline
blackoutt has a spectacular aura about blackoutt has a spectacular aura about
blackoutt's Avatar
Get upper control arms. I shoot for 4 degrees caster. Also it looks like he either got lazy or couldn't adjust any further on the LCA, are you LCA bolts seized? Very common.
blackoutt is offline   Reply With QuoteReply With Quote
Old 06-12-2019, 02:39 PM #5
If they weren't lazy, do you think that they could get my caster to 3º or is it just fighting an uphill battle?
What in the numbers do you see that make you think they didn't adjust the LCA? Nothing is seized, it's a California car with almost no rust. I loosened the LCA bolts to install the suspension (no PB blaster was needed for any bolts/nuts, just a standard breaker bar).
4th Gen 4WD 4.0L
Old 06-12-2019, 03:10 PM #6
blackoutt's Avatar
blackoutt's Avatar
It looks like they adjusted the left (caster and camber changed) but the right just a touch of camber change, like the left it basically where it was. Why not try to get closer to 0 camber and max the caster out? Looks like any alignment I'd get around my area too, it takes a good patient tech to make the numbers come out spot on but this dude didn't even get them all in the green! I wouldn't have paid for it.
Old 06-12-2019, 08:24 PM #7
Whoa! I was lead to believe the the numbers were fine, due to the lift. I should have pushed them harder to at least get the camber into spec.
Reading more into the caster being too low, I realize that this probably my major issue with being difficult keeping it straight. I think it was probably a bit low before the lift, the lift just made it worse. This is good info to bring back to them (but ideally to have had before I left/paid).
4th Gen 4WD 4.0L
Old 06-13-2019, 08:26 AM #8
blackoutt's Avatar
blackoutt's Avatar
Maybe they couldn't get more adjustment with the lift. Post pics of alignment cam position and we'll see if they're swung way out. Would still recommend upper control arms to get it aligned perfect for tire life and easier driveability.
Alignment numbers after 2.5/1.5". Do they look OK?-looks-good-me-15145867-jpg
Old 06-13-2019, 01:08 PM #9
RonJR RonJR is offline
Real Name: Ron
RonJR has a spectacular aura about RonJR has a spectacular aura about RonJR has a spectacular aura about
Real Name: Ron
I agree, 1.4 deg is way too low for caster - it'll wander all over the place. Spec is 2.5 to 4 deg, and 4 is better than 2.5. With the 2.5" lift, you'll need aftermarket UCA's to get that much caster, keep the camber correct, and avoid tire rub all at the same time.
I used the SPC adjustable UCA's and set them so I could get 4.5 deg of caster. It drives down the highway like it's on rails now.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
RonJR is offline   Reply With QuoteReply With Quote
Old 06-24-2019, 04:39 PM #10
This is what both rear cams look like. I didn't drop the skid plate, so no shots of the front.
Either way, I realize that I am not going to be able to get close to 4º with the stock UCA, so I bought some JBAs, and will push the alignment shop (or possibly a new one) to get everything into the "green" and get the caster up to 4º. Thanks for the advice.
4th Gen 4WD 4.0L
4runner , dobinsons , driving , numbers , tires
Alignment numbers? Forum148 4th Gen T4Rs 13 12-13-2019 12:23 PM
Alignment numbers? Forum148 Engines / Suspension / Wheels / Tires / Audio / Accessories 0 03-19-2018 08:30 PM
alignment numbers NCrunner0 4th Gen T4Rs 31 11-30-2015 02:26 PM
How are these Alignment Numbers? NateMob 3rd gen T4Rs 5 12-15-2013 06:13 PM
Alignment numbers jimithing 4th Gen T4Rs 11 02-15-2012 04:30 PM
