Old 07-22-2019, 01:27 AM #1
gookies gookies is offline
gookies is on a distinguished road
Changing Transmission Fluid, 03' 4Runner V8
Has anyone tried using one of these fluid extractors to drain and fill their transmission fluid? My 4Runner has the transmission dipstick and I believe you have to remove part of the exhaust in order to access the pan, which I'm trying to avoid. Using one of these fluid extractors seem like it would be fine, just wanted another opinion. Thanks.
https://www.amazon.com/s?k=vacuum+oi...b_sb_ss_i_1_11
gookies is offline   Reply With QuoteReply With Quote
Old 07-22-2019, 08:36 AM #2
Slowgoat's Avatar
Slowgoat Slowgoat is offline
Slowgoat will become famous soon enough Slowgoat will become famous soon enough
Slowgoat's Avatar
I had one.
It worked pretty well on motor oil but it would leave about a half quart or so of dirty oil behind.
It was a ***** to clean (took way longer than an oil change), and if any little thing happened to the seals it would not work at all. It had to be cleaned thoroughly after every use with simple green and a lot of water. That was messier than an oil change but that may be just me.
So every other oil change you would have to do a full drain and fill anyway so I got fed up with it and sold it. Only got $35 or so for it. They’re hard to ship I guess and people know the seals can go bad. Mine was perfect and I still only had one look in like 4 months when selling it so they’re not really sought after.
I never got around to doing the transmission. Seems like it could work if you could get the tube to the lowest part of the tranny. Since you have an 03 and it has the dipstick it’s a maybe. Others may know more.
It’s fun to watch it work when it does actually work, but it’s kind of finicky getting it to go every time.
2022 LUNAR ROCK TRAIL SPECIAL EDITION
2010 MAGNETIC GREY SR5 PREMIUM
2004 V6 WHITE 4RUNNER SPORT
1995 V6 3.0 BLACK 4RUNNER 4X4 (Retired)
4th & 5th Gen UCA Install Thread
Slowgoat is offline   Reply With QuoteReply With Quote
Old 07-22-2019, 10:04 AM #3
Real Name: Skip
Real Name: Skip
I don't think that device will do you any good, you'll only get the fluid out of the pan and you can do that simply by pulling the drain plug on the pan and no reason to pull any of the exhaust apart to do that, you only need to remove part of the exhaust to remove the pan not to get at the drain plug.
That being said just draining the pan will only remove about 1/4 of the fluid because the other 3/4 of the fluid is in the transmission and torque converter, the only way to remove all of the fluid is by doing it via the transmission fluid cooling lines, you can find how to do that in other transmission fluid flush/exchange topics on the forum or you can do several "drain and fills" over time a month or so a part.
Either way you go it will be a bit easier for you since you can refill the fluid via the dipstick tube and you will also be able to check the level with the dipstick, while us without a dipstick have to fill it either by the fill plug on the side of the transmission or via the cooling lines and then check the level by pulling the fluid level check plug.
2004 Limited V8
Old 07-23-2019, 05:40 PM #4
Yeah, I may end up doing it over a month with smaller volumes of transmission fluid to change it completely, so buying this may be a more convenient way of taking out transmission fluid and replacing the same amount, they're not that expensive so I may end up trying this out.
Old 07-23-2019, 11:05 PM #5
GMZ GMZ is offline
GMZ is on a distinguished road
GMZ GMZ is offline
Doing a fluid swap via transmission cooler lines is very easy, let the car do most of the work.
350Z--->T4R--->370Z--->T4R--->TDI--->T4R
2006 Titanium Silver V6 SE 4x4-Sold
2007 Titanium Silver V8 SE 4x4-Wrecked
2008 Galactic Grey V8 SE 4x4-Current
GMZ is offline   Reply With QuoteReply With Quote
Old 07-24-2019, 08:12 AM #6
Mantilgh Mantilgh is offline
Mantilgh will become famous soon enough
Check out your oil cooler hard lines before you do.
I had to replace the high pressure line for the steering and noticed my oil cooler lines are rusted and splitting.
I’m going replace them and exchange the fluid then.
Mantilgh is offline   Reply With QuoteReply With Quote
Old 07-24-2019, 04:33 PM #7
Yeah, I know mine are currently rusted, have been spraying Fluid Film and it's fine right now, but I did buy an OEM replacement awhile back, in the garage somewhere, haven't installed yet, but will likely do that when I do a drain and fill.
4runner , changing , extractors , fluid , transmission
DIY: Changing transmission fluid/ dropping transmission pan thumper 4th Gen T4Rs 11 12-18-2023 05:21 AM
Transmission issues after changing fluid 4thGen4.7 4th Gen T4Rs 17 06-16-2016 06:54 PM
How much Transmission Fluid do you lose changing the Radiator pconner748 4th Gen T4Rs 13 04-21-2016 08:54 PM
Changing WS transmission fluid in 2005 T4R Flyer 4th Gen T4Rs 39 12-29-2015 10:46 AM
2003 4Runner and Changing Tranny Fluid live4swell Maintenance/Detailing 32 12-20-2004 08:07 PM
