08-25-2019, 12:27 PM
ok to leave skid plate off?
I'm so tired of (*#&@$(*#&ING with the skid plate just to do a (*@&#$ing oil change every damn time. Is it ok to leave it off?!
08-25-2019, 12:38 PM
Real Name: Leonard
Real Name: Leonard
As long as you are using as a DD, YES.
Having fun's build
08-25-2019, 12:52 PM
yep, daily driver, thanks.
08-25-2019, 12:53 PM
Real Name: Elliott
Real Name: Elliott
If you don't take it off road, not a problem. If you do take it off road, not advisable
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
08-25-2019, 02:35 PM
i assume you have a v-8? i have a 6 cyl, and don't need to touch the skid plate for oil changes. here in the northeast, the plate is important to keep snow and winter junk from flying up into the engine bay. and any time of year it deflects branches and rocks, etc.
08-25-2019, 03:17 PM
Originally Posted by rwh963
i assume you have a v-8? i have a 6 cal, and don't need to touch the skid plate for oil changes. here in the northeast, the plate is important to keep snow and winter junk from flying up into the engine bay. and any time of year it deflects branches and rocks, etc.
yep, v8. It's onroad to work 95% of it's time, the only other time I have it "offroad" would be muddy roads during the winter/hunting season.
08-25-2019, 03:21 PM
It does help channel air to cool off parts of the engine and drive train.. however.. on the road its fine.. ive driven around without it plenty... I would retap the holes and get a replacement for piece of mind though
08-25-2019, 08:53 PM
Real Name: Ron
Real Name: Ron
Have an '03 V8 LTD and mine's been off for 3 years, no problem. I'm all highway though, if I was an off roader would have to have one.
Removed mine because it was a rusted/rotted out pos. Same with gas tank skid but I did replace that w/RCI.
08-25-2019, 09:50 PM
Is there any reason you couldn't cut a 5in dia hole in the skid plate directly below the drain plug? That's what the V6s have so shouldn't be an issue....?
08-26-2019, 11:52 AM
Real Name: Ron
Real Name: Ron
There already is a nice large hole to access the drain plug. That's not the issue. The problem is that it is impossible to change the oil filter on the V8 without removing the skid plate.
I put mine back on every time - it keeps glop out of the engine compartment and provides a bit of protection. If I offroaded the '06 seriously, I'd get an aftermarket skid plate. The OEM one is pretty wimpy and not smooth at all on the bottom, so it's more of a "catch on the rocks and get destroyed" plate than a "skid" plate.
2006 Sport Edition, V8, 206K miles, 2.5/1.5" OME lift, SPC adjustable UCA's, 255/75/17 BFG KO2's load range C @ 40psi. Regeared diffs to 4.30, with TrueTrac in rear.
1994 SR5, V6, 5-spd, Aussie locker front, Aisin manual hubs, Truetrac rear, 33/10.50/15 BFG KO's, stock suspension, OBA (Viair 400C), Front Range Offroad twin stick, 225K miles. Dual 2.28 transfer cases, for a 90:1 crawl ratio.
08-27-2019, 09:36 AM
Real Name: Henry
Real Name: Henry
My V8 front skid rusted off and could not go back on, I drove with it for about a year off until I bought a v6 skid plate from the junkyard. Absolutley no issues in that year!
Ask me about my frame rust!
Major Parts List:
Energy Suspension, full front end rebuild, 885& Toytec, SPC upper arms, dual-amped 7 speaker stereo, 5100's, rear swaybar delete courtesy of rust, v6 junkyard skidplates and a lot of elbow grease
08-27-2019, 03:41 PM
Good grief! With not having any experience with the V8, I just assumed it had a remotely mounted filter like the V6. Now I understand the scope of the issue and feel sorry for you 8cyl owners (but still slightly jealous), hahaha.
08-28-2019, 08:29 AM
Replaced the factory skids with a set from RCI. Took an old windshield washer fluid gallon jug and more or less cut it in half (leaving the handle on) and it works perfect to slide up under the filter to remove it and catch the oil that drains - without having to remove the skid plate.
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
08-28-2019, 12:21 PM
Real Name: Bill R.
Real Name: Bill R.
2007 2wd Tundra didn't even come with one from the factory. Makes it easier to change oil too.
08-28-2019, 02:54 PM
Real Name: Michael
Real Name: Michael
I took of my front skid when I first got my runner. It was rusted and only being held on by zipties (previous owner). I then proceeded to drive multiple times on the beach at stock height with no issue other than getting sand stacked all in my mid skid plate that covers the trans. Its still off now and it's been almost a year. You'll be fine but don't go bashing it on rocks.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
