Old 10-17-2019, 11:43 AM #61
Bigshankhank Bigshankhank is offline
Real Name: Tyler
Bigshankhank is on a distinguished road
Real Name: Tyler
Originally Posted by firebirdguy View Post
thanks. so a sample of a synthetic blend at 5200 miles tested good, yet there are those who change their full synthetic oil at 3000-4000... this is just another example of proof that oil lasts a LOT longer than most people think.
That's just pouring money down the drain IMO. My dad had a couple of Mercedes C-class cars back in the 90's and the factory maintenance schedule called for full synthetic oil changes every 7500 miles. As a matter of fact I have been so busy lately that I didn't get to my most recent oil change on the 4-runner until a little over 7000 miles and I doubt it made a lick of difference except to irritate me that I am now off my usual easy-to-remember 5000 mile odometer check.
My rule of thumb;
Semi-synthetic in every car.
Full synthetic in my modern bikes
Conventional in my older (pre-1990) bikes.
Rotella in my diesel RV.
2008 4Runner SR5 V6 4WD
Bigshankhank is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 02:38 PM #62
JuniorPigeon's Avatar
JuniorPigeon JuniorPigeon is offline
Real Name: Aaron
JuniorPigeon has a spectacular aura about JuniorPigeon has a spectacular aura about
Real Name: Aaron
In my '97 with 289k - Lucas Long Drain 15w40 with a full quart of Lucas HD Stabilizer. Every 5k, it loves it.
In my '07 with 175k - I'm about to do my first one. It's been on Quaker State UD 5w30 for years with the PO, but I may do Mobil1 or Long Drain again since I've had good luck, but 5w30.
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
JuniorPigeon is offline   Reply With QuoteReply With Quote
Old 10-17-2019, 08:24 PM #63
w3fl3x w3fl3x is offline
w3fl3x is on a distinguished road
05 v8 with 239k miles. Been serviced at Toyota with Valvoline synthetic blend its whole life by previous owners.
I do the oil change on my own and used Valvoline high mileage synthetic blend 5w30 with a Toyota oil filter. I like to change it at 5k miles. Oil came out still fairly clean and no leaks even a this mileage. No reason to switch to full synthetic.
w3fl3x is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 10:56 AM #64
heres something i read recently on a tacoma forum.....
in the v6 1grfe engines, toyota actually says to NOT use synthetic oil. it was in a toyota bulletin or document someone posted & specifically said these v6's should not use full synthetic... not sure why, but it was pretty clear toyota said it for some reason.
anyone heard that before or seen the document too? maybe its seepage or leak related?
im a full believer in synthetic oil being better than normal oil... but theyre are some engines that dont like it or not designed for it.. example is older v8 engines with flat tappet lifters/cams, the lifters wont rotate in their bore like they should due to the decreased friction from synthetic. & older v8s like that with older tech gaskets & high miles can definitely have leaking issues on synthetic.
just something to reasearch & think about for the v6 & synthetic oil.
Old 10-18-2019, 12:59 PM #65
PWGUNNY's Avatar
PWGUNNY PWGUNNY is offline
PWGUNNY is on a distinguished road
PWGUNNY's Avatar
My v6 '04 has 197,000 miles. This truck continues to amaze me with its reliablity and CAN DO attitude. LOL
I've always used 5w-30 synthetic oil. Usually Mobile One, but not too committed to brand.
2004 WHITE SPORT 4RUNNER V6
Full FJ TT suspension, Daystar Comfort ride 2.5/1.5
Cooper ATR 265/70/17
and 2020 White SR5 Premium (boring stock)
PWGUNNY is offline   Reply With QuoteReply With Quote
Old 10-18-2019, 01:50 PM #66
Ripper238's Avatar
Ripper238's Avatar
I'm approaching 10k and will likely be going to Castrol EDGE Extended Performance 0W-20 from the OEM Toyota synthetic oil when the time comes. I have always liked Castrol oil.
I hope to do oil changes every 8-10k since I do well over 20k every year, so only doing it 2-3 times a year will be great!
Old 10-18-2019, 01:56 PM #67
Ripper238's Avatar
Ripper238's Avatar
Well that's really strange since Toyota them selves (dealers) use Toyota branded synthetic oil for their oil changes?
Synthetic should be fine for any car, its only switching to synthetic in high mileage vehicles it can be an issue. If you use it from the start it should always be fine.
Maybe i am missing something?
Old 10-18-2019, 02:49 PM #68
4gambler
Guest
Posts: n/a
4gambler
Guest
Posts: n/a
489 miles on my 2020 and I use toyota assembly line OEM fill.
LOCAL STEALERSHIPS ALL USE MOBILE 1 FULL SYNT. FRieken caps lock.
Old 10-18-2019, 05:40 PM #69
yes toyota has synthetic oil since many of their other engines specify it, but the v6 in 4runners & tacomas etc, there is a document saying to not use synthetic but no explanation as to why.
i will see if i can find it again, but im sure others on here have heard of it too.
Old 10-19-2019, 10:21 AM #70
Ripper238's Avatar
Ripper238's Avatar
But they put it in there 4 Runners at the dealer and it comes with it? Would love to see the documentation for this.
I looked for the documentation and the only thing i could find is the 5,000mi oil change vs 10,000mi oil change and how the 4R's are not designated for the 10,000mi oil change which makes sense since its an off road vehicle.
Don't know what year this was written:
Toyota Parts | Synthetic Oil Good or Bad for Toyota Vehicle
"*The 2TR-FE (4Runner / Tacoma) and the 3UR-FBE (Flex Fuel Tundra / Sequoia) are the exceptions to this new change interval program; these engines have not been approved for the 10,000 mile interval at this time. A 5,000-mile/6-month oil change interval is still required for these vehicles. Also, the Flex Fuel 3UR-FBE requires a 2,500 mile interval when operated on E85."
Old 10-19-2019, 12:35 PM #71
based on everything ive read for 4th gen v6 says 5/30 conventional was used untill roughly 2010. i dont think 4th gens come from the factory with synthetic. after ~2010 they use the 0/20 which is a synthetic from toyota.
ive seen the 5000 vs 10,000 oil change documents too, also have read the one about using 0/20 in some v6s after 07 or 08.
but the one i read within the last few weeks was posted on a facebook toyota group & was an official toyota document or TDS & it clearly said the v6 in 4th gens & tacomas prior to 2010 should use conventional 5/30 oil. i tried locating it this morning but cant find it... it is out there though.
i agree that using synthetic in these engines probably wont hurt anything & all kinds of peopel use it, but toyota specified conventional oil for some engine & synthetic for others.
Old 10-22-2019, 06:50 PM #72
Gen4SR5 Gen4SR5 is offline
Gen4SR5 is on a distinguished road
184k on my 03' v6 been using Castrol edge high mileage conventional oil every 3-4k since I bought it with 143k
Gen4SR5 is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 05:08 PM #73
Transient Transient is offline
Transient is on a distinguished road
I’m about to do the first oil change on my new (to me) 09. Planning to use tried and true Mobile 1 high mileage.
Transient is offline   Reply With QuoteReply With Quote
Old 10-23-2019, 08:20 PM #74
ATOWN4R ATOWN4R is offline
ATOWN4R is on a distinguished road
‘06 w/151k. Valvoline high mileage conventional 5/30 every 5-7k since 78k when I got her 5 years ago.
ATOWN4R is offline   Reply With QuoteReply With Quote
Old 10-24-2019, 02:26 AM #75
Daily4Runner916 Daily4Runner916 is offline
Daily4Runner916 is on a distinguished road
03' V8 with 260k. Pennzoil Ultra Platinum Full Synthetic 5W30. Oil change every 5-7k miles.
No issues!
Daily4Runner916 is offline   Reply With QuoteReply With Quote
guys , miles , mine , oil , shop
3rd gen engine w/120k miles Houston, Tx $750 zwalker16 For Sale: T4R Items 0 11-28-2018 11:28 PM
Annual 1yr/20k miles Engine Oil Change TripleTS_T4R General Discussions 17 10-18-2017 02:03 PM
4.7 V8 Tundra (same engine as our 4r with 1 million miles) Arthur4R 4th Gen T4Rs 11 08-29-2016 11:43 AM
600,000 miles on a Toyota Engine! Toyota4Runner Maintenance/Detailing 9 03-22-2005 04:05 PM
