10-02-2019, 03:11 PM
slight rough idle '07 V8
Just picked this one and there's a slight rough idle compared to my other '07 that has twice the mileage. Nothing serious, but noticeable to me. This one only has 93K miles.
Does not throw codes and I just put OEM plugs in with no difference.
Seems to drive ok, with good power and throttle response....but it feels slightly slower than my 180K mile '07, which could be in my mind too.
MPG seems down approx .5-1mpg vs the higher mileage one (15.5 vs 16.6) but that could also be from the tires and I think I need an alignment on this one.
Any thoughts?
Just the Toyotas
'86 FJ60
'07 4R V8
10-02-2019, 04:29 PM
It could be your MAF sensor. Try cleaning it with some spray from autozone. I had a rough idle, but it threw up a code, and that fixed it.
05 limited 4runner 4x4 Philip Alberti's 05 4Runner Build
10-02-2019, 09:25 PM
Real Name: Elliott
Real Name: Elliott
Check the MAF, the PCV, the throttle body. If you changed plugs, did you replace coils? If none of the basic simple stuff helps, you may need to plug in a reader for some live data. Might be a vacuum leak, a fuel flow problem, the list can get long
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
10-03-2019, 07:45 AM
I'll start with cleaning the Maf. It's not as rough as a vacuum leak and probably not noticeable to most people even. It's also random. Will idle like a Camry, and then give a little shake to let you know there's an engine there.
Just the Toyotas
'86 FJ60
'07 4R V8
10-03-2019, 11:21 AM
Real Name: Michael
Real Name: Michael
Mine idles rough sporadically too, I have noticed it more frequently with my AC on. I have new plugs which helped for awhile but I feel like the thing is back to how it used to be
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
10-03-2019, 11:29 AM
Motor mount bad?
10-03-2019, 11:35 AM
Real Name: Elliott
Real Name: Elliott
A bad motor mount would just make the engine shake all the time at idle, it wouldn't be sporadic.
If you had a sticking or leaking injector, you would get an intermittent rough idle, and not necessarily get a cel. Your fuel trims have to go over +-30% to draw a code. Same with a minor vacuum leak. The ecm will adjust as things wear to keep the engine running normally. So you could be showing signs of something wrong without actually getting a code. A code only mean the computer THINKS something is wrong. Again, if the MAF doesn't get you there, might be a good idea to get some live data, better than throwing parts at it blindly. Just my .02. Good luck!
