10-16-2019, 12:56 AM
Real Name: Jonathan
Real Name: Jonathan
Best quality aftermarket 4th gen headlight units?
Hi guys
The Depo aftermarket projector headlamps that came with my 07 V8 Sport a couple of years ago have died - driver side assembly had a turn signal bulb burn out/break off into assembly + melt the turn signal socket within housing - the passenger side seal has broken down and is super condensed and fogged constantly. Neither of my turn signals currently work (problem).
I rather just replace the entire set for a clean new set.
Will be searching for a non cloudy set of used OEMs but failing that, can anyone recommend the best quality aftermarket options currently on the market?
I’m not after any blacked out housing or halo nonsense - just clean OEM looking projector assemblies that will last a decent amount of time. I have a XenonDepot Philips 4300k HID setup currently installed.
Many thanks
Jon
4th Gen Sport Edition V8 4x4
10-16-2019, 09:44 AM
for aftermarket, good brands are usually tyc and depo, i still pass on those, i spend money on new oem set, its close to 450 out the door. never have to worry about leaking and sun damage again.
Pioneer DEH-80PRS,Rockford Fosgate T600-2,Hertz ML 1650.3(2 pairs),T400-2,Hertz ML 280.3(2 pairs),T1000-1bdcp,(2)JL Audio 12W6v3, Mechman 240a HO Alternator, Dual Northstar 31m,Borla Dual Exhaust,AFE Magnumforce intake.Enkei WT-4 Michelin Defender LTX 275/55R20. retrofitted S2000 projectors,Philips 85122 White Vision,Morimoto 5Five Ballast.Diode Dynamics SS3 Yellow Fog Sport.2 pairs of Hella Supertones.Full led conversion on interior and exterior.HAWK Talon Rotors and LTS pads F+R,Stoptech stainless steel lines F+R.Bilstein 5100 @0.85, MOOG FJ Springs front,Bilstein B12 36-281824 rear .
10-16-2019, 10:50 AM
dont oem's get sun damage too?
10-16-2019, 11:02 AM
Real Name: Michael
Real Name: Michael
Maybe after like 15 years of abuse, but if you coat them when you first get them and take care of them i'm sure they'd last a lot longer than any aftermarkets
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
10-16-2019, 11:59 AM
TYC here, theyve been good to me so far
10-16-2019, 12:58 PM
Real Name: Jonathan
Real Name: Jonathan
Appreciate the feedback. Going to pick up an OEM set and call it a day probably
10-16-2019, 02:14 PM
I would choose a good used set over a new aftermarket set every time. Every aftermarket headlight I bought it eventually developed condensation inside the housing. But that can be fixed by resealing it with Butyl tape or even silicone.
10-16-2019, 04:49 PM
Real Name: Jonathan
Real Name: Jonathan
Yup agreed. Just ordered from my local dealer - they price matched sufficiently against online pricing and came in under the total shipped cost.
10-16-2019, 05:12 PM
no doubt they would/should last a lot longer than aftermarkets.
i recently bought an 08 4runner that was a soccer mom vehicle in great shape & its lights were very foggy & yellowed. cleaned up a lot with mothers wheel polish though.
after searching for 6+ months for the right 4runner to buy & seeing literally over 100, i saw a lot of 4th gens that had faded & foggy headlights at 8-10 years under "normal" care conditions (not coating but not abusing). but thats longer than some will own their 4runners so i guess that can be considered never having to worry about sun damage.
10-21-2019, 05:58 PM
Got a set of TYC-stamped black housing ones from ebay (maybe theyre fake, maybe theyre real).
One is perfect, one leaks. both have a little peeled clear around the outside corner.
I'm looking to replace them and decided I'd try these next: https://www.amazon.com/dp/B07Y5QDM3S
They should arrive tomorrow, and I'm just interested in seeing how they look
10-25-2019, 06:42 PM
Another option would be to buy a used set from a junk yard.
2005 4Runner Sport Edition 4WD V8 (Black)
Mods: 2006 4Runner LED Tail light swap, Diode Dynamics LED bulbs on rear exterior and full interior, 2018 4Runner TRD Pro rims (in Graphite color) wrapped in BFG KO2 265/70/17, Rutech Secondary Air Injection Bypass, HCF Delete, Weathertech floor mats.
12-18-2019, 05:47 PM
Hello, I'm looking to replace my 2006 head light units, are you happy with yours?? You've had them a few months now, from your post date. Appreciate feed back. Thanks.
12-19-2019, 09:43 PM
Can you post some pics. I've been thinking about buying those.
12-20-2019, 12:08 PM
TYC from rockauto or Amazon here:
no leaks so far and they run through 3' deep mud holes every other weekend and downpours and rain, no leaks yet in 6 mos. the fitment lines are perfect too
12-20-2019, 07:38 PM
Any updates?
