Old 06-09-2023, 12:25 PM #91
Forum148 Forum148 is offline
Forum148 is on a distinguished road
Just wanted to update this with my experience of purchasing superpro offset lower control arms. I received my package and opened it and noticed some rust on both of the lcas. Contacted super pro and they’ve given me three options 1. Is to exchange them, 2. Is a $100 off if I choose to keep the ones with rust on them, or 3. Return for full refund. Bummed that there is rust on the new lcas I am happy to see that they stand by there product and are willing to help me out.
SuperPro LCA-ad312a96-79af-4d7d-a854-22fe6eb63e38-jpg
06 V8 SR5 --Kings--JBAs--RCI armor--Lil B's--33s--Wheel and Party--
Forum148 is offline   Reply With QuoteReply With Quote
Old 06-09-2023, 05:41 PM #92
rdruss's Avatar
rdruss rdruss is offline
Real Name: Ron
rdruss's Avatar
Real Name: Ron
I'd send them back just to get rid of the "spatter".
2003 Limited, V8, AWD. K&N, Dobinson IMS/FJ springs,, SPC UCA, Super Pro bushings in front LCA and in all rear control arms, Michelin 265/65R17 LTX/Defenders, stock wheels with homemade center caps, Stop Tech slotted rotors w/Posi Quiet pads all around, spare tire relocated to inside cargo area.
Old 06-10-2023, 11:59 AM #93
Yeah I'm leaning toward sending them back because the spatter is quite bad on them. I asked if they could look at the replacements before they send them out to me and they said they would double check them.
Old 06-15-2023, 04:53 PM #94
nytosc nytosc is offline
nytosc will become famous soon enough
Total shot in the dark, but anyone have a set of stock LCA they are getting rid of? Condition doesn't matter - I plan on rebuilding for a stock(ish) suspension setup.
nytosc is offline   Reply With QuoteReply With Quote
Old 06-15-2023, 10:33 PM #95
I may be willing to let mine go to you. But it won't be for a month or two. Not are what your timeline looks like.
Old 06-19-2023, 11:55 AM #96
Bluesky 07's Avatar
Bluesky 07 Bluesky 07 is offline
Real Name: Russell (OB #9908)
Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future Bluesky 07 has a brilliant future
Bluesky 07's Avatar
I have mine available right now. They're damn near pristine too, just need bushings (for sure) and ball joints (maybe) replaced. I'll make you a deal for sure.
Bluesky 07 is offline   Reply With QuoteReply With Quote
Old 10-18-2023, 09:33 PM #97
Update finally put the lowers on. Holy crap what a difference these made. My old ones were hammered with 140k on them so kind of a hard comparison. But the truck is buttery smooth now. Will update next week when I get the alignment done. But based on feel 10/10 would recommend as of now.
Old 11-03-2023, 05:21 PM #98
Alignment update 👌🏻
SuperPro LCA-img_5752-jpg
Old 03-04-2024, 05:24 PM #99
aemravan aemravan is offline
aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute aemravan has a reputation beyond repute
anyone running these LCA's can confirm how much these offset the tire forward for me by chance?
Also, I see that the alignment bolts are larger than factory.. does anyone know if this would work with the cam tab eliminator kits..? Assuming the answer is no? Which I guess isn't the end of the world.. I would just need to pick up a larger bolt set to run through these and open up the hole spacing in the plates..
2003 Limited V8 4runner - 37's, Tacoma Front End swap, ARB locked front and rear , LC200 rack swap
aemravan is offline   Reply With QuoteReply With Quote
Old 03-20-2024, 02:33 PM #100
EdmundGTP EdmundGTP is offline
EdmundGTP will become famous soon enough
I just did the math on for this when I installed them this past weekend. Measuring the centerline off-set at each bushing and then converting that to a total forward offset angle, I trig'd out that the double-offset LCA's should shift the wheel hub centerline forward by about .4 inches.
Taking a reference measurement between the frame and brake calipers before and after installation confirmed this.
Also confirmed by the fact that my tires no longer rub in reverse with the steering at full lock, and the resulting gap is just over .3 inches.
As for compatibility with the tab eliminator kit, I cannot comment.
'06 V8 4R Sport, FOX 2.5 RR/DSC Coilovers, FOX 2.0 RR/CD shocks, Wheeler's & Timbren Bumps, ROKMEN lower links, LR UCA's, Warn VR8000, 7069's, Hanma LEDEEZ, DO Front Bumper, BAMF LCA Skidz, RCI Skidz, WMW Full Size 4x8 Roof Rack, WhiteKnuckle Sliders, etc. etc.
EdmundGTP is offline   Reply With QuoteReply With Quote
Old 03-20-2024, 09:50 PM #101
I can confirm my non measured findings from
doing this install 2 weeks ago as well. Didn’t pull actual measurements, but combination of these lca and the spc uca I got a healthy shift forward which also got me away from the body mount in reverse that was previously eating into it a good amount with the 37s.
I’m running the cam eliminator kit. What I will say is that you CAN make it work, but it’s not an easy fit if you’re like me and still wanted to get the max inboard setting in the front and max outboard setting in the back bushing. There is so much offset with the double offset bushing that both of the rear tabs had to be installed in their “center” setting. There is just too much angle from the double offset.
Took a little finagling but I got it to work.
Old 03-21-2024, 06:31 PM #102
Even without using the cam eliminator kit, the double offset bushings in these LCA's do not make it easy to fish those LCA bolts through and get all the cams fully seated between their frame tabs.
I ended up installing mine with both the forward (camber) and rear (caster) cam bolts at their max outboard setting. I also have SPC UCA's at their "neutral" or "OEM+2deg" caster setting, and with the ball joints clamped at the outermost ends of their adjustment slots.
With that combo I was able to get everything dialed in to a very nice alignment spec with +4.0 Deg. Caster, Neutral Camber, and +0.2 Deg. toe.
Old 03-21-2024, 09:28 PM #103
Yup, same here on the spc adjustment , I was amazed at how much camber I needed to pull out lol
Old 03-29-2024, 10:09 AM #104
YYC4R YYC4R is offline
YYC4R is on a distinguished road
Hi all. New to the forum. I recently bought a 2007 Limited. Lower control arms are seized and need to be replaced.
I would love to go OEM but Canadian Toyota prices are insane. New control arms and all cam hardware will cost $1400...just for parts. Superpro looks like a nice alternative and good quality. I can get them shipped to me in Canada for about $950 (on sale).
How has everyone liked their Superpro LCA? Any issues or concerns?
Thanks
YYC4R is offline   Reply With QuoteReply With Quote
Old 03-29-2024, 10:27 AM #105
xtremewlr's Avatar
xtremewlr xtremewlr is offline
Real Name: Todd
xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold xtremewlr is a splendid one to behold
xtremewlr's Avatar
Real Name: Todd
Thanks
They work just fine. You shouldn't have any concerns running them at all.
2003 4Runner Limited 4wd V8 - Build thread on Tacoma World
FJ tcase swap, VVT intake swap, Solid Offroad motor mounts, Doug Thorley y-pipe, Bold Performance cat-back, ADS shocks F&R, Metal Tech LTHD springs rear, 1" body lift, 285/75/17 Toyo R/T Trails on Sequoia rims, Coastal front bumper, CAD rear bumper
xtremewlr is offline   Reply With QuoteReply With Quote
good , manufacturer , option , rule , superpro
