Old 12-05-2019, 03:04 PM #16
blindloser1080 blindloser1080 is offline
blindloser1080 is on a distinguished road
Originally Posted by 81runner View Post
Never worked with bluedriver before. I bought a cheapy Chinese ELM327 OBD2 module off eBay, think I paid like 12 bucks for it. Paired with torque pro, it gives you the ability to view live data from your running engine. Not sure if bluedriver can do that as well, I would guess it can. You want to know what your long term fuel trims are (ltft1 ltft2), short term trims (stft1 stft2) and also your o2 sensor voltages. This will help narrow down the issue. I would think if the plugs were a problem, you would get a code all the time. With fuel trims, you can be out a little bit or a lot, but the obd won't throw a code unless any of them is +-30%. So you could have a ltft1 reading of +25%, ltft2 of +12%, be running like shite, and still not get a code. Sure, you could just throw parts at it, but if you're in the dark about what's going on, that could get expensive quick, fast, and in a hurry.
Will do. I'll put it on there tonight and do some driving. See what I can find out.
blindloser1080 is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 10:05 PM #17
Did some driving around the block for about 10 minutes, max speed 40mph (having hesitation and misfire when stopping at a light and going again). Here's some info I found out:
Long term fuel trim bank 1: 0-4.7%
Short term fuel trim bank 1: -15.6%-9.4
Long term fuel trim bank 2: 3.1-6.3%
Short term fuel trim bank 2: -19.5%-7.8%
Old 12-05-2019, 10:28 PM #18
Tested the o2 voltages and such. Same drives, 40mph max. Here's the info:
Wide range os2 bank 2(3) sensor 1(1): voltage 2.884-3.442 (stayed very steady through drive)
Wide range os2 bank 2(3) sensor 1(1) equivalence ratio: .942-1.039 (again steady)
Wide range os2: bank 1 sensor 1 voltage: 2.893-3.501v (again steady)
Wide range os2: bank 1 sensor 1 equivalence ratio: .937-1.44 (steady)
O2 bank 2 sensor 2 (bank 3 sensor 2) oxygen sensor voltage- .055-.780V (peaks and valleys)
O2 bank 1 sensor 2 oxygen sensor voltage- .075-.76V (peaks and valleys)
Old 12-05-2019, 10:38 PM #19
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
I may be off, but I'm pretty sure 7.6v is pretty high for an o2 sensor...
What about fuel trims?
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 10:46 PM #20
You're right it was .76V
Fuel trims were posted above the voltages.
Old 12-05-2019, 11:02 PM #21
08TxRunner's Avatar
08TxRunner 08TxRunner is offline
08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough 08TxRunner is a jewel in the rough
08TxRunner's Avatar
Originally Posted by That_Titanium_4RNR View Post
Plugs bought specifically at a Toyota dealership. That way you can be sure they are genuine and for your specific vehicle.
Didn't know there was a problem with fake plugs for the wrong application being sold. Got any links?
08TxRunner is offline   Reply With QuoteReply With Quote
Old 12-05-2019, 11:03 PM #22
bdubbin bdubbin is offline
bdubbin is on a distinguished road
Oooo... data!!! I don't know anything about this but it's interesting!
I watched this https://www.youtube.com/watch?v=pIJdCZgEiys and it seems you're running rich. He lists some possible causes and begins troubleshooting but his condition is lean with a high + ltfr number. The first 7 minutes seem applicable to you.
2006 4Runner Limited V6 4WD | Daystar 2.5/1.5 | Duratracs 265/70/17 | All-Pro 1.25/1.5 | Morimoto Mini D2S HIDs
bdubbin is offline   Reply With QuoteReply With Quote
Old 12-06-2019, 01:07 AM #23
Thanks for the video. Guess I'll start at square 1 and clean the MAF. Also picked up a pcv valve as it was only $5 and I've never replaced mine.
Old 12-06-2019, 01:30 AM #24
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
Missed this. My bad. I think negative fuel trims mean you are running rich and the computer is throttling back on fuel delivery.
Old 12-06-2019, 01:38 AM #25
Cleaned the MAF, still happening.
So running rich... fixes/causes?
Old 12-06-2019, 01:53 AM #26
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
I stand corrected. I got it backwards. Positive trim means the engine THINKS it's lean and dumps more fuel. Negative trim means it THINKS it's rich and cuts back on fuel. Your actually running lean. The voltages of the sensors seem askew for the trim data, I feel like you need to look at the o2 sensors as I suspected. The engine THINKS it running rich because it's getting incorrect data from the sensors, so it's throttling back to make the o2 sensor read correctly. Sorry, my bad
Old 12-06-2019, 02:14 AM #27
So if I'm reading it correctly, bank 2 sensor 2 needs to be replaced?
Old 12-06-2019, 03:56 AM #28
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
I would say both banks, start with sensor 2, should be past the cats. The computer uses both sensors to determine the amount of oxygen and unburnt fuel in exhaust. Sensor 1 is harder to get to, I'd try the easier accessed sensors first. Though you may want to just change all 4 since they work in pairs per the respective bank. Both short term trims are kind of high. Normal should be 0 to +-10, occasionally dipping up to 12 or so. Are you noticing a higher engine temperature? Common on older engines running lean, also common to have a rotten egg smell from the tail pipe.
Old 12-06-2019, 04:07 AM #29
Thank you. Went on ahead and ordered both the downstream Densos off Amazon and they'll be here Tuesday (nobody local had the Densos). I haven't noticed any rotten egg smell or higher than usual temperatures.
Old 12-06-2019, 10:25 AM #30
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
I don't have any links but plenty of people have complained about buying densos online that have turned out to be "fakes".
As far as the comment about wrong application, that was because I figure that a parts desk at the dealer would be more accurate with their parts than say a big box auto part store.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
code , keys , misfire , plugs , replaced
P0301 misfire, replaced "everything", still a misfire, but no CEL...what next? Heyduke 3rd gen T4Rs 7 06-25-2018 10:50 AM
Misfire, with no CEL '99-4Runner 3rd gen T4Rs 16 06-12-2017 07:17 PM
Misfire on #6 swedge 3rd gen T4Rs 5 12-01-2012 07:50 PM
Misfire #5 jimbob86 3rd gen T4Rs 7 09-04-2012 12:09 AM
Cylinder one misfire error code without the misfire MJW 3rd gen T4Rs 4 05-03-2012 09:07 AM
