Old 12-24-2019, 01:17 PM #1
smokey73's Avatar
smokey73 smokey73 is offline
Real Name: Roddy
smokey73 is on a distinguished road
smokey73's Avatar
Real Name: Roddy
While the engine is out
I'm sitting right at 290k miles on my '03 V8 Limited. I've had it 4 years now and have been watching the rear main leak get worse and worse. I've also noticed that after it sits for a few days (this happens a lot) it smokes pretty bad on cold starts and uses more oil when doing a lot of low rev driving (in the woods and mountains). Last year when we went to NM, I pulled my camper to Carlsbad 500+ miles. It didn't use enough oil for me to notice. I used nearly half a qt of oil each day we spent riding around Queen and Cloudcroft, then none on the drive home. I'm pretty sure the valve seals are leaking causing oil consumption and smoke, this has also wreaked havoc on the cats. I notice this morning that there's oil leaking from under the front cover. This could be from the front seal or the cam seals. I've also been fighting exhaust manifold leaks off and on for a year or two now.
I said all this the say that I'm going to plan on pulling the engine this spring and address all these issues at once, out of the car. My plan is to
-pull the engine
-pop the heads and send them out to be resealed and adjust the valves
-reseal everything, including exhaust manifolds
for those who have done it, is there anything else I should look into while it's out? Are there any other mileage related items I should look into?
'03 Limited V8 Toytec Ultimate 3/2.5" General Grabber ATx LT275/70 R17 Rear Grizzley locker
smokey73 is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 02:05 PM #2
ElDuck ElDuck is offline
ElDuck is on a distinguished road
How much is all that going to cost?
Would it be cheaper to pick up a motor with decent miles from a recycler instead of opening up yours and redoing it?
ElDuck is offline   Reply With QuoteReply With Quote
Old 12-24-2019, 02:23 PM #3
smokey73's Avatar
Real Name: Roddy
smokey73's Avatar
Real Name: Roddy
A quick search on rock auto shows a seal kit for about $150. I've got time to check prices and find a better/cheaper one. I haven't checked with any local machine shops on these heads, but I would assume the head job would run between $200-$300/ea. I'mm thinking I'll go ahead and do the alternator and p-steering pump while it's out. They're both originals.
I don't know what a pull-out engine would cost, but i don't think I would go through the trouble to install one without giving it the same treatment.
Old 12-26-2019, 05:18 PM #4
weaves weaves is offline
weaves is on a distinguished road
Timing belt and water pump for sure and it would also be a good time to replace the starter since you'll have the intake manifold off. But wouldn't it make more sense to replace the engine with a lower mileage one from a salvage yard instead of spending all that time and money rebuilding just the top end on a 300k mile engine? I know a "lower mileage" 03-04 non-VVT 4.7L engine can be had for relatively cheap compared to its 05+ VVT counterpart.
I was faced with a similar situation when my radiator cracked which caused the engine to overheat but ultimately I decided to fix it after pulling the heads and seeing that the cylinder walls, cams, ect had very minimal wear.
weaves is offline   Reply With QuoteReply With Quote
Old 12-26-2019, 05:46 PM #5
nevada's Avatar
nevada nevada is offline
nevada has a spectacular aura about nevada has a spectacular aura about nevada has a spectacular aura about
nevada's Avatar
with that mileage, you may as well address the bottom end also. no sense to go through the trouble of pulling the entire thing, only to put it back in untouched.
rebuild, or replace it with a lower mileage one.
1985 pickup: EFI 331/4r70W-Dana 300-42 TSL SXII's/raceline beadlocks-30spl longs-5.29's-spools-sky Hi steer-OBA/4g tank-10.5k RR winch-dual blue tops-200 amp alt-flatbed.
1985 4runner sr5: 22RE/5spd-6" pro-comp suspension-37 BFG at's-5.29 gears-Badlands Basher bumper-8.5k RR winch.
2006 4runner v8 limited: stock. Build Thread YouTube Channel
nevada is offline   Reply With QuoteReply With Quote
Old 12-27-2019, 01:21 AM #6
V8Man's Avatar
V8Man V8Man is offline
V8Man will become famous soon enough V8Man will become famous soon enough
V8Man's Avatar
Expensive engine to rebuild. A gasket set if I remember correctly was $400.
I currently own 4 T4R 4th Gen
#1) 2003 Sport V8 2WD purchased new, totaled @ 175,000.
#2) 2003 SR5 V8 2WD running w/engine from #1(Son#3 is Driving)
#3) 2003 Sport V8 4WD
#4) 2004 Sport V8 Supercharged 4WD
V8Man is offline   Reply With QuoteReply With Quote
Old 12-27-2019, 08:57 AM #7
jcaino jcaino is offline
jcaino will become famous soon enough jcaino will become famous soon enough
Rebuild with 1UZ rods (beefier) and put a supercharger on that sucka.
2003 Galactic Gray Mica Limited V8
Inside: Pioneer AVH-2300NEX w/ backup cam | Dometic CFX3 55im | Custom floor w/ table & drawers
Outside: Hefty Fab Bumper | Warn ZR 10-S | RCI skids & sliders
Electrical: 150w solar panel | Victron MPPT controller | BlueSea breakers and panels
Suspension & Tires: Bilstein 5100's w/ Dobinson c59-314 & c59-329 | 5th Gen Trail wheels & Wildpeak A/T3W 275/70/17
jcaino is offline   Reply With QuoteReply With Quote
Old 12-27-2019, 07:20 PM #8
inscarguy's Avatar
inscarguy inscarguy is offline
Real Name: brian
inscarguy has a spectacular aura about inscarguy has a spectacular aura about
inscarguy's Avatar
Real Name: brian
Rule of thumb is never reseal or partially rebuild an engine with that high mileage. It will make the engine too "tight". Sounds weird I know but its true. I have seen and been around too many high mileage engines that have had heads rebuilt or have been opened up and resealed with untouched bottom ends blow up pretty quickly after all the work is done.
I realize the 4.7s are a great engine but redoing the top end could or will create other issues on the other areas that are worn.
My suggestion is rebuild it since you know the engine is sound. If not go for a used engine ( possible future issues as you dont know what its been through), or get a already rebuilt engine with a warranty from say Powertrain products. It may be higher in price but if something happens you would be covered parts and labor.
Good luck.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
inscarguy is offline   Reply With QuoteReply With Quote
Old 01-01-2020, 10:09 PM #9
smokey73's Avatar
Real Name: Roddy
smokey73's Avatar
Real Name: Roddy
I guess there's probably little chance that the bottom end wouldn't need work done. Maybe it would be better to start with a lower mileage pull out. I found one semi local, advertised as a running core with 150,000 mile for $300. Something like that might be a better starting point for a complete rebuild than mine. If mine would need any cylinder work, I would get the $300 back in machine work alone. This would give me a chance to piece all the parts together and get the engine ready to drop in. I could have it out and back in and running over a weekend.
Old 01-05-2020, 05:15 PM #10
radlynx radlynx is offline
Registered User
radlynx will become famous soon enough
Registered User
Why don't you run a cylinder pressure test and decide from there.
radlynx is offline   Reply With QuoteReply With Quote
Old 01-05-2020, 09:01 PM #11
smokey73's Avatar
Real Name: Roddy
smokey73's Avatar
Real Name: Roddy
I did a leak-down test a year or so ago when I first noticed it using oil, all cylinders were around 15-20% iirc. This is why I was originally considering just doing the top end. I believe the bottom end is in good shape, for its age. After putting a pen to it, I do believe I can swap in a junkyard engine cheaper than I can go through this one. I think I can get a pull out with about 150k miles, reseal it and do the water pump and tb for about $1000. I figured I'd be that far into my current engine with only doing the top end.
This brings me to the next question. Will a tundra engine swap in? I think I rember there being differences like the fact that the tundra and sequoia engines use a timing chain and maybe a different intake, but will they interchange? I've found several very low mileage (sub 50k) tundra engines for the same prices as the 4runner/GX engines.
Old 01-06-2020, 11:08 AM #12
That_Titanium_4RNR's Avatar
That_Titanium_4RNR That_Titanium_4RNR is offline
Real Name: Michael
That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light That_Titanium_4RNR is a glorious beacon of light
Real Name: Michael
Have never heard anything about any 2uz without timing belts. Someone please correct me if so.
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
That_Titanium_4RNR is offline   Reply With QuoteReply With Quote
Old 01-06-2020, 03:00 PM #13
nevada's Avatar
nevada's Avatar
if its a chain, its a different engine, probably the 5.7. as far as it being swappable...with enough money yes, anything is. I doubt it will be cheap, or easy however...
stick with a 4.7.
Old 01-06-2020, 04:33 PM #14
The '03-04 Tundra and Sequoia 4.7L will also work. The '02 and earlier 4.7L uses a cable throttle body while the 03-04 uses a drive-by-wire TB.
Old 01-06-2020, 09:33 PM #15
AuSeeker AuSeeker is offline
Real Name: Skip
Real Name: Skip
stick with a 4.7.
I'm guessing he's referring too the 4.6 UR-FE which replaced the 4.7 2UZ-FE in 2009/2010 and does indeed have a timing chain.
I'm guessing it won't be a direct swap, but not sure or we would of heard of others doing it.
2004 Limited V8
engine , lot , oil , plan , pretty
Engine loud metallic engine rattle @1800 rpm after sitting in traffic protist 3rd gen T4Rs 5 08-17-2019 08:04 PM
Intermittent vehicle/engine shake and vibration with check engine light present lloydster 3rd gen T4Rs 26 09-26-2017 11:58 AM
Rough Idle, Engine Sputtering, Engine Ticking, Flashing CEL Sotovo 3rd gen T4Rs 29 04-18-2016 10:35 PM
Engine,VSC,ABS and Brake lights on, no codes, engine running rough chd2001 4th Gen T4Rs 2 04-22-2014 12:14 PM
Engine swap Question..does L6 engine fit into 1990 Hilux/4runner hjalti_gto Classic T4Rs 29 11-28-2011 09:34 AM
