01-08-2020, 04:16 PM
#16
Real Name: Michael
Real Name: Michael
Titanium Metallic 2006 Limited 4WD V8 | Doug Thorley "Premium" Long Tubes/Modded Ypipe | Magnaflow dual in/dual out | True Dual Exhaust | Fr: 5100/885/SPC R: Icon 2"/2nd gen links | 285/75R17 G003s | Sherpa Princeton | Baja Designs | 5th Gen Brakes | Everything else is in the Build Thread
01-08-2020, 07:43 PM
#17
Real Name: Todd
Real Name: Todd
Originally Posted by That_Titanium_4RNR
Nice! Little more work than the Relentless one but it looks really nice and clean once done.
01-18-2020, 02:39 PM
#18
Originally Posted by duffdog
Its just not going to happen. Nobody has ever installed 33's on a 4runner and not had them rub on the frame when off roading. Forget the sway bar and body mount, even after all of that is done the 4runner can turn so sharp that the actual frame hits the tire. There just aren't people who can say that they have done it without rubbing. Even if you are doing something as simple as going up a driveway and turning, either the tires will rub or you do not have 33's, its that simple. 285's are not 33's, they are slightly smaller. 33's are 33x12.5x17.
If you are bored, go ahead and type in the tires size to see the difference here:
Tire Size Comparison
I am literally telling you I ran 255/80/17s (a 33.1x 10.2 inch tire) for over 4 years with no body mount chop and no rub. I mapped the Red Clay Rally 2 of those years, and it wasn't until I went with a 285/75/17 that I required a BMC.
Also, you can't just say "285s aren't 33s, they're slightly smaller" I don't believe you are understanding how tires are measured because 285/75/17 is a 34x 11.1 inch tire.
So yes, you CAN run "33s" with the correct wheel offset, lift and ucas and a little know how. I aND many others are testament to this.
I cleared 33s easily running a Dobinsons MRR lift, no sway bar, ICON UCAS and a caster adjustment as far forward as possible. (Usually 4 to 5 degrees forward).
Nothing else required. 34s are when it becomes required.
Instagram: overland_tennessee
Website: www.redclayrally.com
01-18-2020, 02:40 PM
#19
Originally Posted by techno
Are you saying get the caster at 4°, or forward 4° more than spec, which would put it at 7°13'?
Total caster was between 4 and 5 degrees
01-18-2020, 03:53 PM
#20
Which UCAs can push out 4-5 degrees? I always read people getting 3 maybe 4 degrees, but I always figured more was better in this case.
I may or may not do a bmc after my lift and 33s, but I always figured enough caster along with 0 offset wheels would be plenty to avoid it.
2006 4Runner Sport Edition V8 4WD
01-18-2020, 05:06 PM
#21
Real Name: Todd
Real Name: Todd
SPC adjustable UCAs should be able to.
01-19-2020, 12:46 PM
#22
Saw this a while ago and saved it to my notes for reference, hope this helps.
“Thanks to gaterose for providing the following information.
What does it take to fit x tire with x lift?
Front/Rear Lift Tire Size
Stock -
265/65R17
265/70R17* (except BFG A/T)
1/0
265/70R17* (31.6x10.4)
255/75R17 (32 x 10)
2/1
265/70R17
255/75R17
3/2
275/70R17 (32.2 x 10.8)
285/70R17† (32.6 x 11.2)
255/80R17* (33 x 10)
3/2 + 1-1.5" Body Lift
255/85R17† (34 x 10)
285/70R17†
305/65R17† (32.6 x 12)
* requires removal of mud flaps and probably minor trimming
† requires trimming and may require body mount chop (click here for details on body mount chop), upper control arms, and/or increased backspacing.
Add 5 to the middle number for 16" wheels, subtract 5 for 18" wheels (265/75R16=265/70R17=265/65R18)
The above assumes you're using stock wheels and no wheel spacers. Aftermarket wheels or wheel spacers will increase rubbing, more trimming will need to be done in order to fit the listed lift height.”
01-19-2020, 09:47 PM
#23
It’s possible I am currently running 285-70-17 Falken Wildpeak AT tires on ET 0 4.75 BS wheel with 3” icon lift with SPC UCA’s without a BMC. Just had to trim fender liner.
01-20-2020, 03:45 PM
#24
255/75/17 Kumho AT51 here on FJ wheels (15mm offset) and 2" lift = almost no rubbing except reverse full lock on one side...
01-20-2020, 08:08 PM
#25
33's must be 12.5 inches wide or they are not 33's. What is so hard to understand about that concept? If they are not 12.5 inches wide they are "weenie european range rover pizza cutter tires" which is what you have. Also, 285's are STILL not 33's and you yourself mentioned that they rub and they are not even big enough to call 33's yet.
2005 Blue SR5 v8
3" suspension lift, 1" body lift, 315's, rear Elocker, on-board air system, slider air tanks, full skid plates, front Demello bumper, rear HMF plate/tube bumper, rear 9000lb hidden winch, front 10000lb winch, dual electric fans (in cab adjustable temp), rock lights, 25W LED projector lights.
01-20-2020, 08:31 PM
#26
Real Name: Todd
Real Name: Todd
That's just ****ing stupid. Pizza cutter width or 12.5 width, they are both 33" tall, therefore 33s. Where do you get the idea they "have" to be 12.5?? Just because it's your concept doesn't make it fact. Get over yourself with that bullshit.
Pizza cutter 33s probably wouldn't need a BMC with the right wheel offset and might be the better option for anyone not wanting to do one. To each their own.
01-20-2020, 09:20 PM
#27
I got Pizza cutters 33" no bmc. It's like saying that if Ferrari is not red then its not Ferrari, or like someone i knew that used to say that if you turbo your golf and its not 20pounds of boost don't tell anyone that it is boosted.
Sent from my Redmi 4 using Tapatalk
01-20-2020, 10:49 PM
#28
Its not my concept. Its been that way since off road tires were invented Mr. "xtreme wheeler"...lol! You simply cannot buy a 33.153x10.324x17 tire anywhere.
Its what keeps people from being confused. As an "xtreme wheeler" you should know that already. Oh wait, you have a rooftop tent - you should change your handle to "xtreme overlander"...
2005 Blue SR5 v8
01-20-2020, 10:53 PM
#29
No it isn't. Its like having a ferrari with a 4 cylinder engine, which makes it not a ferrari even though from the outside it appears to be one. Or having a 4runner with a chevy motor - not a 4runner anymore even though it appears to be one from the outside. Same concept.
2005 Blue SR5 v8
01-20-2020, 11:06 PM
#30
If measuring tape is at 33" .......it's a f..ing 33", X10 or by 12.5 has nothing to do with hight of a tire. The size you describing is a simply a start point for a truck/tractor tire from when you and me weren't born yet. Simple as that.
