09-14-2022, 01:44 PM
Product for cleaning dash & door panels
Can anyone recommend a good product to use to clean and restore the door panels and dash on my 2007 sport?
The driver's side door panel is nasty from a summer's worth of sunscreen residue and the passenger side dashboard is miscolored, looks like the wrong cleaning product was used at some point and its very noticeable.
Looking for something that will remove grime safely and restore the original color without causing further damage.
'99 SR5, 2007 Sport
09-14-2022, 02:54 PM
rubbing alcohol and then your favorite protector.
09-16-2022, 11:56 AM
Real Name: Russell (OB #9908)
I clean mine with a damp cloth (Simple Green if there's visible dirt) then use Slick Mist Interior Detailer. Couple of pics:
Oh, and see the shine on the hood? That's the same company's Slick Mist Speed Wax. Walmart sells both IIRC.
09-16-2022, 12:39 PM
there are many. even DIY methods. I use griots garage interior cleaner for those parts and I'm happy with it. I don't use it on leather, even though you can, I still prefer the old horse hair brush and woolite detergent/water mixture
Interior Cleaner - Griot'''s Garage
I use their spray wax to wax under my roof rack and was happy with it so decided to give this a try too
09-16-2022, 01:33 PM
Real Name: Bob
Real Name: Bob
303 protectant.
2008 SR5 4WD
09-16-2022, 01:59 PM
Originally Posted by bob3dsf
303 protectant.
this
09-21-2022, 01:05 PM
Rubbing alcohol worked great to remove the grime, thanks for the tip
'99 SR5, 2007 Sport
09-21-2022, 04:50 PM
Real Name: brian
Real Name: brian
When I got my current 4runner the interior left alot to be desired. I used a Mr. Clean erase sponge. Used meguiars interior detailer after then a good leather conditioner on the seats.. Also if you have heavier stains LA's totally awesone cleaner is a great product.
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
09-22-2022, 12:17 AM
303 protectant.
I used 303 forever, however I am a believer in Carpro Perl now, imo lasts longer, collects less dust, and depending on dilution is a great exterior plastic / engine protector, and an excellent tire shine.
‘03 SR5 V8 296000k
09-23-2022, 05:56 PM
Real Name: Bob
Real Name: Bob
Good to know.
I found about 303 from: Sweeeeet project cars..
2008 SR5 4WD
09-24-2022, 07:09 AM
303 protectant.
This
09-25-2022, 10:23 PM
Optimum Leather Protectant Plus. Leaves a dry, matte finish and does not attract dust. 303 is also a great product.
09-27-2022, 05:41 PM
Real Name: Andrew
Real Name: Andrew
I know most people want a simple all in one solution, but I've been using 2 products together which has given me great results.
1) P&S Xpress Interior Cleaner - Cleans really well, safe on all surfaces, affordable, and smells good.
2) 303 Protectant - Since the Xpress is just a cleaner and 303 is basically just a protectant, I then follow up with the 303 for UV protection. It leaves a very nice OEM finish and helps keep the dust from sticking too.
2006 V8 Sport Edition
Build Thread
