I haven't changed the oil since I installed the RCI skids and got a helpful tool...a Form-a-Funnel. I already have a Fumoto valve so between all three of these items, the oil change was the easiest I've ever done! And not a single drop of oil on the pavement! I did have to loosen the filter a bit without the funnel in place as there was no room to turn the filter wrench. Just enough so it was still sealed, but could be undone by hand after placing the funnel.
The F-a-F is the Truck/Tractor size, btw, and I just wiped it clean.
[IMG]
[/IMG]
07 Limited V8 Titanium Metallic
Bilstein 5100s x4, Fronts set on 0 with OME 885s, Sway-A-Way 1.5 rear coils, JBA UCAs, '12 Trail wheels, Cooper AT3s 265/70/17, Mobil1 0W40, Amsoil Severe Gear 75W90 and SS ATF.
(Previous truck: 1993 Toyota DLX, V6, 4x4, Xcab, 5 speed, Pewter Pearl - owned from day 1)
http://www.toyota-4runner.org/4th-ge...ml#post2069269
