4wd vs 2wd mode on V6. - differential
Gecko123
I have V6 so it’s capable of switching into 2wd drive mode where only the rear wheels are engaged
If I drive in 2wd mode, is it easier on the front differential - less wear?
Thoughts?
Generally speaking, yes.
However you will occasionally want to shift in to 4wd and even lock the diff (off-road only) and drive around a bit to exercise the transfer case and keep it from locking up on you.
