Old 08-20-2020, 10:16 AM #1
chrisbagnell's Avatar
chrisbagnell chrisbagnell is offline
Real Name: Chris
chrisbagnell will become famous soon enough
Real Name: Chris
After LED swap - Temperature Gauge not working properly
I recently changed the LED's in my instrument cluster and now am having a problem with the Temperature gauge. I started the car with no needles on, turned it off and put all needles back in their place, but the Temp one has a mind of its own. I pushed the needle on at "C" and when i turned the car on it moves differently then the other needles. it looks like its stuck based on how it jitters but im unsure. Does anyone know whats going on here and how to fix it? i know a replacement motor is around $20 i just have to find it, but if its a simple solution id rather save the money.
See the Video attached
chrisbagnell is offline   Reply With QuoteReply With Quote
Old 10-30-2020, 03:49 PM #2
Real Name: Chris
Real Name: Chris
I still have not been successful in trying to find a solution with this... hopefully bumping will help.
I changed the LEDs in my instrument cluster a few weeks back and the temperature gauge has not been working properly. it stutters up and down and no matter how many times I set it to "C", it continues to move randomly forward and backwards. I am looking at replacing the motor as I think it is bad.
I 100% caused it and ill admit it... I was playing with the needle like it was a helicopter propeller and probably blew up the motor.
Does anyone know where I can get the replacement motor and do it myself?
Old 10-31-2020, 11:34 AM #3
DMX512 DMX512 is offline
Real Name: Ben
DMX512 will become famous soon enough
Real Name: Ben
chrisbagnell
Check out this thread. Not a fix or answer to your specific problem but there are a couple of guys that could probably answer your question.
Instrument Cluster LED Swap
You might want to change the title of your post ( or start a new one) something like “after instrument cluster led swap temp gauge no longer working”.
That way sparky and yosh are more likely to look and respond.
Good luck
2007 SR5 v6 4x4
Black
17" wheels
200000 miles
Constant 12v Mod / TPMS Mod
DMX512 is offline   Reply With QuoteReply With Quote
Old 11-01-2020, 01:58 PM #4
Real Name: Chris
Real Name: Chris
Looking for this motor, searched both part numbers online and cannot seem to find anything, any help is appreciated this is the motor for the temp gauge.
The motors all look the same and have same part number 031027 06-103 but have different numbers for the number below “PPE+PS”, ending in B1 on this motor. They end on the fuel gauge as A2, speedometer is B2 and RPM is A1
Also scanned the QR code with no luck, wasn’t expecting anything as it is probably for the factory and never shared online but here it is for reference
Text : 000000000000000006330001608700
2004 Sport Edition v6 4wd, 180k+ miles
My Build Thread: CBR's Build Thread
My Write-ups: How to Manually Release Rear Hatch with Pictures
Old 12-03-2020, 01:18 PM #5
Real Name: Chris
Real Name: Chris
Solution
I wanted to provide an update for this as I have found the solution. Hopefully if anyone else is having this trouble this post should help in the future. I have a 2004 4Runner Sport Edition and the temperature gauge stopped working properly after I did an LED replacement from the factory orange to white. The gauge was stuttering after I reassembled the cluster and I narrowed it down to the stepper motor that powers the needle. I discovered that the proper identification for the motor is "6S".
According to a lot of google searching, This motor was used by Toyota and Lexus from 2003-2013. It will work in any position – speedometer (mph), tachometer (rpm), fuel, or temperature. In order to replace it there may be some soldering required that I will write up how to do once I receive the motor.
A simple google search of "Toyota 6S Stepper Motor" will get you the motor you need. I found it as of December 2020 for $20, a fraction of the cost a dealership would charge. I found a shop that is charging $175 to fix the instrument cluster. My suggestion if your soldering skills are sub-par is to buy the part and take it to a shop that specialized in instrument cluster repair.
Another option is to buy a cheap instrument cluster on eBay, (I bought one for a Chrysler 300 for $40), and practice on that before doing the real deal.
car , gauge , needles , temperature , turned
1999 4runner (6cyl) temperature gauge not working christinaNM 3rd gen T4Rs 1 07-24-2015 10:23 PM
gas gauge not working properly secondary-system Classic T4Rs 3 09-06-2014 01:16 AM
Tach, Fuel Gauge, Temp Gauge, Oil Pressure Gauge, Alternator Quit Working silentrunner Classic T4Rs 3 10-05-2013 12:51 PM
Tach and Temperature Gauge not working properly kdanielp3 Problems & Warranty Issues 0 12-31-2008 11:49 AM
Engine Coolant Temperature Gauge not working kdanielp3 Problems & Warranty Issues 2 12-17-2007 06:54 PM
