Originally Posted by hankd
thanks for this. it definitely could have been the jack plate sliding. it's got a rubbery material on top so it would make sense. i i didn't realize the jack needed to roll and it wasn't able to move in the grass so the jack plate would have been forced to slide. last night i got a setup rigged up with plywood as you described. also have jack stands but i didn't bother with them because i wasn't under the vehicle and only needed it up enough to freely turn the wheels (was manually pumping the power steering fluid out). should i always use jack stands even in these cases to save strain on the jack?
i've got the 3 ton arcan jack from amazon/costco. when i jacked with the plywood from the front crossmember (where the skid plate attaches) i had better luck. i've got a 3 inch lift so the tires barely come off, might use a few more sheets of plywood next time i jack it up.
I would always at least have the jack stands under there in case the jack slips, even if you're not under any part of the vehicle, the floor jack itself could do major damage to other parts of the vehicle if it slips off the jacking point, just imagine it busting your oil pan, exhaust pipes, transmission, etc. etc.
