Old 09-24-2020, 12:45 AM #1
Epic Ed's Avatar
Epic Ed Epic Ed is offline
Epic Ed will become famous soon enough
Epic Ed's Avatar
Off-Road Lighting Project
Got the off-road lighting project underway today by installing the Rigid 10” light bar in the hood scoop location. Mounting bracket purchased from C4 Fabrications. Also had a 30” Baja Designs S8 installed in the lower valence.
I had a local shop do the install and haven’t had a chance to look at how it’s mounted but I’m very pleased with the esthetics. The S8 is recessed far back enough that it could have been mounted without cutting the valence but I decided to get the full exposure - and I’m not disappointed.
I am a bit disappointed with the performance of the Rigid spot. The difference between the Rigid and the S8 is substantial - and not just due to the volume of lights in the S8. The Rigid is a spot and the S8 is a driving/combo pattern. The throw is really weak compared to the S8, and not just because of the length discrepancy.
Ditch lights are already wired and ready to mount a pair of BD Squadron Sports as soon as the brackets arrive. I'll be replacing the OEM fog lights with a pair of round BD Squadron SAE amber as soon as I figure out how I want to mount them in that location. I also plan to add a pair of BD LP4s to the front bumper but that may have to wait until I upgrade the bumper. I'm currently looking for a way to mount them on top of the OEM bumper above the lower valence but haven't seen anyone mount off-road lights in that location so there must be some challenges that make it impractical. Open to suggestions if anyone has some.
2007 Toyota 4Runner | Sport Edition | 4WD | Fox 2.5 front | Fox 2.0/OME rear springs | Camburg UCAs | 285/70/17 Bridgestone Dueler Revo 3s on TRD Pro wheels | Westcott Designs Sliders | BD S8 30" light bar | Rigid 10" with C4 bracket in hood scoop | BD Squadron Sport ditch lights
Epic Ed is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 08:55 AM #2
Drak's Avatar
Drak Drak is offline
Real Name: Doug
Drak is on a distinguished road
Drak's Avatar
Real Name: Doug
I had a C-4 hood scoop light on my to-do list as well.
Which Rigid light fixture did you get?
They have the SR series with sub-choices, and the SR2 series, also with sub-choices.
So I think there's a total of about 7-8 different choices for the Rigid.
This shows them all in action and the differences were pretty drastic between them, depending on your beam needs.
Rigid industries 10" SR & SR2 Series LED Range - Snake Racing - YouTube
2003 Imperial Jade 4Runner Sport Ed.
Drak is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 10:15 AM #3
JuniorPigeon's Avatar
JuniorPigeon JuniorPigeon is offline
Real Name: Aaron
JuniorPigeon has a spectacular aura about JuniorPigeon has a spectacular aura about
Real Name: Aaron
Baja > All
Also, for mounting the Squadrons in the factory pockets you can use this Ford/Toyota, F-150, Tundra, Tacoma Fog Light Kit. You simply drill one new hole on each side of the bumper, and hook the connector up backwards to reverse the polarity. It will work on your factory fog switch. I did it this https://www.toyota-4runner.org/2973768-post36.html way, credit to @YetiX .
2007 4Runner Limited V8
| 2.5 Fox 3" lift w/ remotes & DSC | Dobinson 677V rear | SPC UCAs | 1" BL | SCS F5 | 315/70 DuraTracs | Prinsu full rack | RLC rear bumper/swingout | C4 front bumper | Warn VR8-S | F55 fairlead/Flatlink-E | Rocksteady skids | ARB 2500 awning | Dometic CFX 40W | Partner Steel 22" stove | Adventure Index drawer/sleeping platform | ARB twin compressor | Odyssey 34R dual batteries | Blue Sea SI ACR/fuse panel/USB | Renogy 100W Eclipse | Baja Designs Squadron R & S2 | G5R retrofits | Doug Thorley headers/Y pipe | weBoost OTR |
JuniorPigeon is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 10:22 AM #4
topherjroutdoors topherjroutdoors is offline
topherjroutdoors is on a distinguished road
looks good love the mod
topherjroutdoors is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 12:03 PM #5
randy88fj62's Avatar
randy88fj62 randy88fj62 is offline
randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about randy88fj62 has a spectacular aura about
Do you get glare off your hood from the hood scoop light?
2008 4Runner Sport Edition 4.7 V8 4WD
1988 FJ62 Landcruiser
President LA County Trailcrew 4x4's
https://www.facebook.com/groups/Trailcrew4x4
randy88fj62 is offline   Reply With QuoteReply With Quote
Old 09-24-2020, 12:30 PM #6
Bumbo's Avatar
Bumbo Bumbo is offline
Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of Bumbo has much to be proud of
Bumbo's Avatar
Very nice.
The lower bumper is my favorite location for a front firing lights... it yields the best viewing experience when you keep the glare and spill off the hood and windshield.
Old 09-24-2020, 05:45 PM #7
Epic Ed's Avatar
Epic Ed's Avatar
I ordered the SR-series Pro (spot). It's the only one that fits in the scoop.
https://www.rigidindustries.com/sr-s...sr-series.html
Specs indicate output at 7900 lumens translating to about 1400 lux at 10 ft. It doesn't seem that bright. I'll get photos tonight of the throw for both light bars.
*FYI - that video is from 2014 and way out of date for their current product line. They only have the SR Series Pro now, but available in different throw patterns. As indicated, I got the "spot" which is the most appropriate for that location.
Old 09-24-2020, 05:49 PM #8
Epic Ed's Avatar
Epic Ed's Avatar
None. I barely notice it's on. lol
Old 09-24-2020, 05:51 PM #9
Epic Ed's Avatar
Epic Ed's Avatar
Originally Posted by JuniorPigeon View Post
Baja > All
I saw that thread and it's not bad. I'm trying to figure out how to make it look more factory like you see with the 5th gen 4Runners. I talked my buddy into ordering OEM pods and he's going to work on fabricating a mounting bracket for the BD Squadron series lights. Might have a new option for these lights in a month or so.
Old 09-24-2020, 07:31 PM #10
Drak's Avatar
Real Name: Doug
Drak's Avatar
Real Name: Doug
Wellsir, I thank you for knocking one to-do off the list.
I'll go with something larger in the lower bumper instead then.
Old 09-28-2020, 06:21 PM #11
Forum148 Forum148 is offline
Forum148 is on a distinguished road
really like how they mounted that s8. Can you take some pictures closer up of how the mounted it?
06 V8 SR5 --Kings--JBAs--RCI armor--Lil B's--33s--Wheel and Party--
Forum148 is offline   Reply With QuoteReply With Quote
Old 09-28-2020, 09:33 PM #12
Tironeous's Avatar
Tironeous Tironeous is offline
Real Name: Joe
Tironeous has a spectacular aura about Tironeous has a spectacular aura about Tironeous has a spectacular aura about
Tironeous's Avatar
Real Name: Joe
Diode Dynamics seem to beat everything else out there LED Fog Shootout: SS3 LED Pod vs. Market-Leaders | Diode Dynamics - YouTube
2005 4Runner Limited V8 4x4 Galactic Gray Mica
Instagram | My "Build" Thread | Bilsten 6112 with 650lb spring | Total Chaos UCAs | Bilsten 5160 with OME 895 | Stealth Custom Series GEN5 Wheels | Dirtcom Trail Swing | Sony XAV-AX5500 | Focal Integration ISS 165 (Front) | Focal RCX-165 (Rear) | Pioneer TS-SW2002D2 (Subwoofer) | Accele RVCLPMBS (Backup Camera)
Tironeous is offline   Reply With QuoteReply With Quote
Old 09-29-2020, 12:12 AM #13
Epic Ed's Avatar
Epic Ed's Avatar
You bet. I bought the brackets from Rago Fabrication. It looks like they're no longer making them, but still have some in stock. I would assume once they're sold out that's the last you'll see of this particular bracket. I'll get some photos this week.
Old 09-29-2020, 12:08 PM #14
Right on! I knew Cali raised made brackets for the same place but i really like how how high that sits in the bumper.
Old 09-29-2020, 09:05 PM #15
Epic Ed's Avatar
Epic Ed's Avatar
More pics of the S8 mounting bracket and location.
bumper , lights , mount , pair , valence
Off-road Lighting Wiring Question SkyGuy41 4th Gen T4Rs 3 10-24-2015 10:09 PM
Off road lighting comparison testing MidwestJ 5th gen T4Rs 2 09-08-2013 08:55 PM
4wheel and off road magazine project 03_4x4Runner 4th Gen T4Rs 3 04-28-2012 01:14 AM
