Frame rust areas and sections to evaluate?
Lolaya
Hi,
I live in Connecticut and have 2005 4Runner that has frame rust.
I want to evaluate it and take pictures of it myself but don't know what exactly are the important parts to look at.
I read that its important to look at where the wheel meets the frame (From a tire guy at Costco) but don't know what its called.
What are the most important sections of the frame to look at? Thank you!
Hi,
Not to be a bit flippant, but the entire frame is important and should be evaluated. Take a deadblow hammer or similarly weighted hammer and hit the frame on all sides that you can with the hammer . . . the hammer should rebound off the frame. Surface or superficial corrosion will not stop it from rebounding off the frame, this can be fixed with some time, various tools and various products that neutralize present and prevent future corrosion. Youtube can be a huge help here.
If the hammer sinks into the frame, this is an indicator that the frame has corroded to the point where you need to evaluate frame repairs, if it is even possible.
Areas where clearances between parts, and there are many, are usually more prone to rust due to the fact moisture and corrosion agents collect there.
Use some sense, youtube and you can generate a plan of action. You are going to get dirty. I eliminated rust from an 1988 BMW E28 M5 that sat for almost a decade after hard use in the Baltimore Metro Area . . . it was dirty, I had to become a better welder and even better grinder, but it came out great.
Where the wheel meets the frame? That is likely the lower control arm mounting bracket. Easy enough to evaluate.
Yep, frame rust can show up just about anywhere on a rust belt vehicle, especially on the 4runner boxed frame, the worst usually starts inside and by time you notice it, it's ugly! Ask me how I know! Look at my picture album.
"03 V8 LTD.
Hi,
I have a 2005 4runner with 150,000 miles and we are in the Bahamas. No real rust issues, but I have seen pictures of 4runner from up north when the frames were rotten to worthless. There's nothing you can do to correct or salvage a rusted out 4runner frame like the ones eaten up by rust.
