View Poll Results: Type of oil used
Synthetic
59 |
86.76% |
Conventional
6 |
8.82% |
Synthetic blend
3 |
4.41% |
09-17-2023, 11:08 PM
#31
Real Name: Patrick
Real Name: Patrick
Redline 5w-30
Redline is one of the only true synthetic motor oils that use group 4 and group 5 stock base oils and NO group 3 “synthetics”. Any motor oil with group 3 base oil is not a true synthetic oil. Group 3 is just a highly refined mineral oil, GTL and extreme hydrocracking, that was the center of a lawsuit between Mobil and Castrol that changed what could be labeled synthetic in many countries. Castrol wanted their group 3 oil to be classified as synthetic so they wouldn’t have to pay Mobil for PAO base oil, a group 4 base oil, and instead use group 3 with a small amount of PAO and be able to label it synthetic. In Germany synthetic motor oil can not be labeled synthetic if it contains group 3 base oils.
Now Mobil, Amsoil and most every other brand of oil hardly contain any group 4 PAO, or group 5 esters, oils now and use mainly group 3 base oils. If you look at the SDS sheets for the oil you want you will be able to determine if it has group 3,4, or 5 base oils in it. You just need to check the CAS # to determine exactly what type of base oils are used. The percentages of each base oil are given but only in a percentage range since the oil blend is proprietary for each motor manufacturer/blender. German motor oil manufacturers can sell group 3 as synthetic outside Germany so German synthetic oils in the USA contain group 3 base oils with some PAO base oil.
Group 3 base oil isn’t bad but it isn’t a true full synthetic motor oil
Red Line Synthetic Oil. 5W30 Motor Oil
2007 Limited V8, AWD, Pelican Storage Cases, Radflo 2.5 Kit. Metal Tech Rear Offset Lower Links. 265/65/18 BFG TKO. Redline Full Synthetic lube, ARB Deluxe Bull Bar and SLEE ARB Foglight Light Surround with Rigid D2 Fogs and ARB LED Indicator/Markers. WARN 9.5XP. Dirty Parts Dual Battery Kit w/ rocker switch & Dual AGM Batteries. Gobi Stealth Roof Rack, ladder, Sunroof Insert, and Tool Box Stealth. ARB Diff breather kit.. (2) ARB Quick connect for jumpers and rear voltage access. Projecta Dual Battery voltage monitor. AGM Voltage Booster PRO “Texas Slim”.
09-17-2023, 11:57 PM
#32
Real Name: Russell (OB #9908)
This may be true but the question is whether there’s $12 a quart difference. I think not.
09-19-2023, 11:02 AM
#33
What oil do you use in your 4runner?
Toyota Syn, and the TRD Oil Filter every time! I live in mild desert winters and hot summers. Never had an issue.
09-25-2023, 05:41 PM
#34
Trying out Costco's 5W-30 this time around. I've heard good things!
2007 Sport Edition V8 4WD w/Nav, JBL and rear seat entertainment, Fox 2.5 R/R coilovers, FJC rear springs with Fox 2.0 Pro series shocks, Rear ARB locker, 305/70R17 Ridge Grapplers, DT short headers
09-25-2023, 07:34 PM
#35
Real Name: brian
Real Name: brian
Redline synthetic or Pennzoil ultra platinum 5w30 and toyota oil filters
'08 4Runner Limited V8 Shadow Mica: Sport hood, bilstein 6112's, 5160's, b12 coils, Gibson cat back, 4runner XSP rims, Michelin X LT AS 275/55-20
'06 4Runner Limited V8 Salsa Red: bilstein 6112, 5160, Wheeler T12's, 4Runner XP wheels, Michelin AT2 275/55/20, Magnaflow Exhaust,, Powerstop brakes, sport hood
RIP.....'08 4Runner Limited V6: white, bilstein 6112s, 5160s, b12 , powerstop brakes, nav, TRD cat back, 4Runner XP rims, Michelin Defender LTX 275/55-20, sport hood
09-25-2023, 07:44 PM
#36
Real Name: brian
Real Name: brian
Costco, walmart, amazon basics are all the same. They are all made by Warren Oil Co. Their additive packs are pretty much the same.
