Old 09-22-2021, 12:42 PM #16
rajat rajat is offline
rajat is on a distinguished road
Originally Posted by firebirdguy View Post
get rid of the xreas... not worth $2500. using standard shock will "disable" the xreas since all the xreas shocks & parts are replaced.
for light duty road use or even light duty off road the best value option IMO are the KYB, there are lots of recent threads on here about replacing xreas & its not a difficult job to do, you just undo the lines at the check valves about 10" away from the shock & install new shocks, the lines & blocks can be left alone or easily removed.
the kyb front coil over shocks come fully assembled with new coil springs so its an easy bolt in replacement. & due to the ~10% stiffer springs they do provide a little lift over stock, not fully level but definitely raises the front closer to the rear. order correct 4WD shocks for your vehicle & be sure to note the fronts are left & right side specific.
Thank you for the advice. Will bilstein 5100 be as good? I also want to add enough lift to accomodate 265/70/R17 tires (standard size 265/65/R17)
rajat is offline   Reply With QuoteReply With Quote
Old 09-22-2021, 01:48 PM #17
the 5100 are better than the kyb's & are more geared for off roading, ive read some people say they are quite a bit stiffer ride tham OEM shocks or "light duty" types like kyb or monroe. & they cost quite a bit more & require new springs to be installed, your 140k mile stock springs are probably worn out/sagging. so all in all it will be at least double the cost of buying complete kybs, thats up to you & your budget.
as for lift, i run 265/70/17 on my 08 sport 4runner & even with the worn out 140k xreas they didnt rub anywhere, with the added 1-1.5" raise over stock from the kyb's they definitely dont rub so i dont think you need 5100s for such a small tire, its barely 1" over stock height & same width, especially if you dont go with super aggressive A/T tread. i have goodyear A/Ts that are a lot beefier than all season tires & again, no rubbing.
for the light duty you mentioned & the price difference i think youd be happy with the kyb.. if you want much stiffer shocks that need new springs & hassle of installing the springs (although its not that difficult) then go with the 5100 for double or more the cost. kyb have a lifetime warranty too & are about $100ea for fronts & $50ea for rears.
Old 09-22-2021, 10:11 PM #18
paulcho paulcho is offline
paulcho is on a distinguished road
newparts.com part number NP-3054271-KIT Monroe front struts and rear shocks included, free shipping $327.95 plus tax, Plus 2 year warranty, They ship very fast.
paulcho is offline   Reply With QuoteReply With Quote
Old 09-22-2021, 11:17 PM #19
KeepingMy_ShirtOn KeepingMy_ShirtOn is offline
KeepingMy_ShirtOn is on a distinguished road
Originally Posted by Mr_Dobalina View Post
Well, looking at an upgraded package - Bilsteins - but sold out....
Bilstein Height adjustable front and matching 5100 Rear shocks
03-09 4Runner 4WD Bilstein 5100 Adjustable Leveling Shock Kit
Where i just ordered mine from. Quick shipping too. Says they're out of stock but they aren't.
KeepingMy_ShirtOn is offline   Reply With QuoteReply With Quote
Old 09-23-2021, 11:36 AM #20
would stay away from the monores, heard lots of bad reviews on them & that they are very soft feeling, softer than OEM... & only 2 yr warranty.
KYB are lifetime & have 10% stiffer valving & spring rate than stock per KYB.
Old 09-24-2021, 01:36 AM #21
thank you for the detailed recommendation. This will help in deciding.
Old 09-24-2021, 06:23 PM #22
L4Time L4Time is offline
L4Time will become famous soon enough
I recently replaced my XREAS suspension with an Eibach PRO kit. I am extremely happy with it.
https://www.toyota-4runner.org/3662967-post12.html
Tire Rack had an incredible deal at the time, but even now it's only about $825 for the parts. If you use freeshipping.com, you'll get another 10% off.
https://www.tirerack.com/suspension/...oModClar=Sport
Hope this helps!
2008 Sport V6 ~100K miles, Eibach Pro-Truck Lift Kit, TRD Off-Road Premium wheels (5th gen), Michelin Defender LTX M+S 265/70R-17
L4Time is offline   Reply With QuoteReply With Quote
Old 09-28-2021, 01:25 PM #23
B.E. Coyote's Avatar
B.E. Coyote B.E. Coyote is offline
B.E. Coyote is on a distinguished road
I also just did the Eibach. It isn't what I wanted but everything else was out of stock and my suspension was shot.
I'm pretty happy with it but will probably add a 1" spacer under the rear.
B.E. Coyote is offline   Reply With QuoteReply With Quote
Old 09-30-2021, 11:04 AM #24
Mr_Dobalina Mr_Dobalina is offline
Mr_Dobalina will become famous soon enough
I am the OP and just noticed my post is still alive almost a year later. I went with the Bilstien 5100's. They have been great so far.
Also, for a couple of bucks, I replaced the sway bar bushings front and rear and all of the "Thunk" noise from hitting bumps has completely gone away.
Mr_Dobalina is offline   Reply With QuoteReply With Quote
Old 01-23-2024, 05:11 PM #25
bht2109's Avatar
bht2109 bht2109 is offline
Real Name: Ben
bht2109 is on a distinguished road
bht2109's Avatar
Real Name: Ben
Originally Posted by Seymore Butts View Post
I installed a brand new suspension from a new 5th Gen 4R TRD Off-Road. It required two minor modifications. I've never been so happy with a comfortable suspension as I am with this one. My 4R has a smoother, softer ride than my friend's Lexus GX.
These suspensions are all over Craigslist around here for about $150. Taken off brand new 4Rs due to aftermarket upgrades.
This is quite a sales pitch! Would you mind detailing the modifications required for this? And just so I’m clear, I can feel safe purchasing used 5th gen OEM coilovers and installing them on my ‘09 4th gen?
Thanks in advance….
Currently getting groceries in a 2009 SR5 V6.
bht2109 is offline   Reply With QuoteReply With Quote
Old 01-24-2024, 04:45 PM #26
MikeinNH67's Avatar
MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light MikeinNH67 is a glorious beacon of light
MikeinNH67's Avatar
Thanks in advance….
I installed non-TRD Gen 5 strut assemblies on the front of my 03. All I had to do for mods is trim about a 1/16" or so of metal off the lower strut eyelet so it would fit. That part was easy. Getting the old top hat to release from the strut tower was not so easy. A big chisel and hammer was needed to break it free. The new assemblies were a huge ride improvement and brought the front up to where it should be.
I think the Tacoma and FJ assemblies will fit with the same trimming.
Mike
03 4runner Limited
1GR-FE V6 w/199k miles
good , holding , shocks , struts , time
Looking for Recommendations for Shocks and Struts Tstebb10 Engines / Suspension / Wheels / Tires / Audio / Accessories 3 01-03-2018 07:14 PM
Replacement of Front Struts, Rear Shocks, Rear Springs, and Bushings foyaboya Engines / Suspension / Wheels / Tires / Audio / Accessories 14 01-17-2016 10:01 PM
Door lock actuator failure after recent replacement AppSt92 4th Gen T4Rs 2 01-05-2016 02:41 AM
97 Shocks and struts replacement question fblainen11 3rd gen T4Rs 28 11-23-2015 10:44 PM
Shocks/Struts replacement vegimate Maintenance/Detailing 0 04-15-2006 01:42 PM
