Old 01-09-2021, 12:36 AM #1
Zplis's Avatar
Zplis Zplis is offline
Zplis is on a distinguished road
Zplis's Avatar
Unhappy RPMs surge while driving and at idle
Hi T4R, I am currently having an rpm surge problem on my 2003 v8 2wd runner with 206k miles, it is an intermittent issue but when it does happen the driving is affected pretty bad. First happened while driving on the freeway with cruise control on, suddenly felt like my brakes were being pumped and the car started to stutter. I pulled over popped the hood and everything looked and sounded fine but I did notice the serpentine belt stopped spinning for a split second then continued. Had no CEL and just got it towed to a shop.
- Cleaned MAF sensor
- Cleaned throttle body
- Replaced an o2 sensor that the shop diagnosed as faulty
- Battery and Alternator test good
- No CEL code at all
I recently got it back from the shop and it appeared after the cleaning and o2 replacement it was running normal again until yesterday the same problem is happening. I noticed that the exhaust pipe smells a little like sulfur on startup now after the cleaning and the car sounds louder near the 3rd cat. I am completely stumped and can't find any info on this problem so I am hoping one of the fellow members could help me out, don't know if my cat is clogged or if it is the exhaust manifold issue on the 4th gens but any ideas would be much appreciated.
Zplis is offline   Reply With QuoteReply With Quote
Old 01-09-2021, 12:50 AM #2
Zplis's Avatar
Zplis's Avatar
2003 4runner idle surge - YouTube
Here is a video of the surge couldn’t get in in an attachment
Old 01-09-2021, 04:35 AM #3
quientus quientus is offline
quientus is on a distinguished road
Do you have an ODBII reader to plug in to check your long / short term fuel trims?
quientus is offline   Reply With QuoteReply With Quote
Old 01-09-2021, 09:39 AM #4
81runner's Avatar
81runner 81runner is offline
Real Name: Elliott
81runner has a spectacular aura about 81runner has a spectacular aura about
81runner's Avatar
Real Name: Elliott
Could be an issue with the throttle position sensor, which is riveted to the throttle body.
2007 SR5 V6 4WD 205k, Titanium Metallic. 5100s, OME 885/895, extended rear links, ST Maxx 255/75 R17 on 17x8s, mud flap delete,TB spacer, Spectre CAI, DRL delete, HCF delete, DAC delete, K&N cabin filter, TPMS bypass, Fog light mod, USB galore, dash cam, LED lights all over, rear bumper lights, cbi ditch light brackets w/lights, atrac off, OBA w/2 gallon tank/hidden hook up, Trailgear welded sliders, Rocksteady skids, custom swing-out, 3⁰, SE hood w/working vent, Sprint booster, JET MAF, Kenwood TM-V71a w/motorized antenna, custom dual battery, custom roof rack/lights, custom TRED mount, external 12v, rear diff breather, pck, Freedom UCAs, custom stereo, Aluminum rad, trans cooler, 240A alternator...for now...
81runner is offline   Reply With QuoteReply With Quote
Old 01-09-2021, 05:26 PM #5
Zplis's Avatar
Zplis's Avatar
No I don't but I think my buddy might have an obd that will give me the fuel trim info I will check that out thank you
Old 01-09-2021, 05:27 PM #6
Zplis's Avatar
Zplis's Avatar
Thank you ill try and test it and see if it's bad
Old 01-18-2021, 03:11 PM #7
Zplis's Avatar
Zplis's Avatar
Thanks for the info checked the fuel trims everything was good turned out to be the tps
Old 01-18-2021, 03:14 PM #8
Zplis's Avatar
Zplis's Avatar
Thank you you were right was the tps got it replaced everything is fixed, appreciate it
Old 01-18-2021, 09:35 PM #9
81runner's Avatar
Real Name: Elliott
81runner's Avatar
Real Name: Elliott
Thanks for the update, happy to help!
cel , driving , problem , shop , surge
Idle RPMs? majbjb 4th Gen T4Rs 8 09-21-2019 07:52 PM
2001 ELECTRICAL POWER SURGE While Driving - VIDEO 4runner1983 3rd gen T4Rs 10 06-14-2018 11:38 PM
22re idle surge 88yota Classic T4Rs 4 08-08-2013 05:32 PM
Weird idle/surge? RylerTust Classic T4Rs 14 01-01-2013 04:11 AM
2007 V8 Idle Surge nytefog Problems & Warranty Issues 4 02-05-2008 08:16 AM
